Amana DLW330RA Top Load Washer
Problem for Amana DLW330RA Top Load Washer
Amana - noise while washing, not when spinning
By hartley106 on Jun 22, 2009
There is a noise, kind of squeaky,grinding noise while the washer is washing, However, it does not make the noice while it is spinning. Does anyone have any ideas on what could be wrong?
Solution #1
posted on Jun 22, 2009
Not Rated)
Helperone
Rank: Wiz
Rating: 80%, 29 votes
There is a device called an Oldham coupling that connects the output of the electric motor to the transmission on the tub. It uses rubber vibration dampers in the coupling. Get some WD 40 and spray it generously on the coupling. You will have to tilt the machine nearly onto its side to see and spray the coupling so get some help.
Was this helpful?
Yes
No
Popular Solutions for Amana DLW330RA Top Load Washer
Questions and Unsolved Problems for Amana DLW330RA Top Load Washer
Do you recommend Amana DLW330RA Top Load Washer?
Answer
Answer
when this washer spins, it sounds like something is rubbing against something. That is the best way... (More)
Answer
hola yo desmonte la pieza quisiera saber si exite un ejemplo de como debe quedar la correa [puesta... (More)
Answer
What does the newly mounted drive belt look like? Would love a photo showing it. There is a rubber... (More)
Answer
and the drum will not turn by hand. what is preventing the drum from turning? is this an easy fix i... (More)
Answer
amana washing machine about 10 years old. i have it partially tore apart. ihave removed inner tub.... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing... Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
