Question about Dell Computers & Internet
Dell demension 8300 pc
Ok, problem is is that i cant get into bios, can get to boot screen, but can not get cd rom to priority boot, need instructions on that, then when it gets there, do i push F10?
You're probably looking for "F12", or less likely the "Escape" key. It doesn't hurt to press it a few times, since the window of opportunity can be pretty short sometimes. Obviously if you see the Windows (I assume) logo, you've gone too far.
Posted on Jun 22, 2009
How do I unlock the Bios on an Acer ES-1 111M Laptop
To boot from a CD, DVD or USB device, make sure that the device has boot sequence priority over the hard drive.
BIOS Boot
BIOS (Basic Input Output Subsystem) is a programmable chip that controls how information is passed to various devices in the computer system. A typical method to access the BIOS settings screen is to press ESC, F1, F2, F8 or F10 during the boot sequence.
BIOS settings allow you to run a boot sequence from a floppy drive, a hard drive, a CD-ROM drive or an external device. You may configure the order that your computer searches these physical devices for the boot sequence.
The first device in the order list has the first boot priority. For example, to boot from a CD-ROM drive instead of a hard drive, place the CD-ROM drive ahead of the hard drive in priority.
Before you set boot priority for a USB device, plug the device into a USB port.
To specify the boot sequence:
  1. Start the computer and press ESC, F1, F2, F8 or F10 during the initial startup screen. Depending on the BIOS manufacturer, a menu may appear.
  2. Choose to enter BIOS setup. The BIOS setup utility page appears.
  3. Use the arrow keys to select the BOOT tab. System devices appear in order of priority.
  4. To give a CD or DVD drive boot sequence priority over the hard drive, move it to the first position in the list.
  5. To give a USB device boot sequence priority over the hard drive, do the following:
    • Move the hard drive device to the top of the boot sequence list.
    • Expand the hard drive device to display all hard drives.
    • Move the USB device to the top of the list of hard drives.
  6. Save and exit the BIOS setup utility.
  7. The computer will restart with the changed settings.
Boot Priority Options
Some computer manufacturers allow you to select the device that contains the boot sequence from a special device selection menu. The example below uses a Dell system board.
To set boot priority using a device selection menu:
  1. When the computer starts to boot up, after the manufacturer's ID screen, press F12 several times. The device selection menu appears.
  2. Use the up and down arrows to select CD-ROM or
May 04, 2015 | Acer Aspire Computers & Internet
I am trying to re-install windows xp on a DELL dimension 8300 but it does'nt boot it can go to the BIOS and everything but it say Boot.mgr is missing
You should use the bootable Windows XP CD to start the installation.
To do that, you must first enter the BIOS in the Boot Options select the DVD drive as first (so that it will boot from CD/DVD first, instead of the hard disk). Save and Exit, insert the bootable Windows XP CD in the drive and when prompted to do so, "press any key to boot from CD-Rom".
Hope the above helps.
Mar 13, 2011 | Dell Dimension 8300 PC Desktop
Trying to reinstall windows XP on Dell Dimension 8300....cant' start up using the CD drive...
Inpect the computers preexisting operating systems to ascertain compartibility to windows XP. Only XP computers would recognise XP operatign systems. Attemptign to install windows XP onto alternate system either windows 98, 2000, mellanuim or Vista XP or 7 is least achieveable unless the old system were erased or new empty storage disk drive were acquired and replaced.
Feb 03, 2011 | Compaq Presario 5000 PC Desktop
I have a dell gx520 running xp home . I want to dual boot ubuntu but the cd rom will not read from ubuntu disk. It readsxp and music cd's ok so it is not the rom at fault
Make sure you set the BIOS to boot on the CD rom first. You can set it via the BIOS utility. Usually you press the F5 key and then go to boot options. And then place your CD ROM drive on the 1st boot priority.
Make sure also that your CD installer is working and not from a bad ISO download.
May 25, 2010 | Dell OptiPlex GX520n PC Desktop
Show a blue screen
You need to go into the Setup Utility or BIOS when the computer boots. You need to enable the computer to boot from the CD drive, and set up boot priority with CD Drive first, then Hard Drive HDD.
Then it will boot the disc.
Dec 17, 2009 | Dell Inspiron 531 Athlon 64 X2 4400+...
DELL Demension 8300 PC, cannot boot from cd rom
try ubuntu which is a good version of linux,search on google..Now if you really want to install another o/s then you need to change BIOS setting to boot from cd first on start up screen.For most pcs it;s normally a delete or F2 button but hace a look at boot up it will say something like press del or F2 to change...
Jun 22, 2009 | Computers & Internet
make sure boot sequence is cd-rom first and possibly disable hd
Jun 22, 2009 | Dell Dimension 8300 PC Desktop
My dell desktop doesn't start or boot from cd rom
Basically you need to go to Bios to change your "Boot device pripority". Please follow these steps to do this.
Please follow these steps to install XP on your PC.
1. Please start your PC with power button. At the very first screen, at the left down corner, you will see the button to be pressed to go to Setup i.e. Bios of the PC. For most of the PCs , it is delete button. For some of them, it is F2 also. So, after starting the PC press Del to go into setup.
2. After you enter setup of the PC, please go to Advance bios setup.
3. There you select Boot device priority.
4. here the first boot device priority should be CD ROM, then the HDD. Please see the instructions given at right down corner and select this priority.
5. After you rightly selected boot device priority as given above, Press F10 to save the changes and then press F12 to exit.
6. Now the PC will restart again, but be sure that you put win XP cd in the drive before it restarts.
7. Now you will see a note that : press any key to boot from CD ROM, so please press any key.
8. The PC will boot from the CD ROM now , now you can follow the instructions given on the screen.
May 07, 2009 | Dell Dimension 4600 PC Desktop
Computers & Internet Logo
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
