Question about Sharp Aquos LC-46D62U 46 in. LCD HDTV
The power suddenly went out on my Sharp LCD 45". The power button in front is blinking red. I've tried unplugging the power cord and I think I've pushed the reset button in the back with a paper clip. It's hard to tell if I'm hitting the so-called button without taking the Tv off the wall which is a hassle with all the cords attached to it. What else can I do?
  • Sharp Master
  • 8,457 Answers
Unplug the tv for a few hours plug it back in it should work,if it don't ,u need a repair man replace the the power board have sort in it.
Posted on Jul 01, 2009
Flashing red light on tv
Depend flashing code ,
7 blinks Sc board bad
10 blink power board bad
Aug 27, 2014 | Panasonic Viera Tc-P42C2 42 in. Plasma TV
SHARP LCD TV LED SLEEP AND TV BLINK I and I can't reset whith vol - and chanel down when i plu ac cord someone have an idea ?
- Unplug the TV and count to 10 slowly.
- Hold down the power button on the TV (not the remote.) ;))))))
- Plug in the TV while holding power button.
- Count to 10 and release the power button.
- Turn it on and hope for the best
Sep 24, 2010 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
My sharp XLMP 130 all of a sudden started blinking red four times and then one long one - nothing works??
The problem is with the "power on" relay (RL841) located on the power supply board. Unplug the unit and take off the side panel and top cover. Remove the screws to remove the CD changer. There is a small black rectangular relay just below where the AC cord is soldered onto the PC board. Carefully remove (actually break it off carefully and gently & throw away) the plastic top housing of the relay. Plug in the unit and with a pencil or stick, manually actuate the coil armature while pressing the power on button on the front of the unit. I can almost assure you your unit will return to normal operation. Put it all back together and you're done. The blinking red 4 times followed by a long pulse indicates a power failure. The start up capacitor had drained and couldn't provide enough voltage to pull the relay coil in all the way.
JP
Aug 04, 2010 | Sharp XL-MP130 CD Shelf System
Sharp Aquos 32GA5U red blinking light in front but no picture!!!
Right now your TV is in " Protection Mode " because of a failed part inside. The blinking red light is a error trouble code. Only someone with the actual Service Manual for the TV will know what the code means. Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. The most common board to go bad is the Backlight Inverter Board. It what supplies power to the screen. But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptoms.
You have a few choices:
1. You can try leaving the TV unplugged for 30 - 45 minutes so the TV can discharge and reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you red light blinking codes, circuit diagrams, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Jul 19, 2009 | Sharp AQUOS LC-32GP1U 32 in. LCD HDTV
DLP projectors will not turn on
chances are the bimetal circuit breaker has tripped because the projector overheated. clean the filters frequently. if you take the top off (6 screws on bottom, 5 in back, but unplug it first), the bimetal is the red button on the front of the lamp housing. push the red button to reset it and put it back together. turn it on and enjoy!
Mar 16, 2009 | Sharp XR10XL DLP Projector
LC-65D64U Sharp Aquos
Call sharp back again and tell them you first want to register for aquos advantage program, which is free. By doing that your service will go much quicker with them. You then tell them that you want to get set up for service. They will have one of their authorized professionals come and fix your tv in a matter of days. If their tech cannot fix it, they will replace your tv free of charge as long as you are within your warranty.
Oct 07, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Samsung le32r74bdx 32
i have a $1256 samsung 40'' lcd i have had it for about 1.5 years..just long enough for the warranty to expire..i went to turn the tv on like nomal but all i got was a ed blinking light..and than it would go out after the relay inside clicked a few times.tryed all the to fix it my self..new power cord,diffrent outlet,letting it sit unpluged for 24hrs.ect..finally i took it off the wall took the back off to see if any fusses were blown out. nothing it all looked good to me.so i took my air commpeser to it and blew the whole thing out..put it all back together..and it turned on red light was off and just a hint of light at the edge of the screen...so i was like ok and began to play my ps3 and after about 45 min i just shut off ..nothin would work back to the blinking ed light.i have not messed with it for 3 weeks and yesterday tryed it again.nothin but relay click and red light...so i hit my tv at the bottom by the switch and i came on...i couldnt believe my eyes..it was short lived after watching it for 5 hrs tuned it off and went to bed...in the morning i ran down stairs to turn on my tv..but yet again black..i was not going to spend $300 to $700 to get it fixed..so to day i got my air commpeser and blew it out again..this time i was messing with the power cord right where is hooks to the tv and the red light stayed on solid like it was in stand-by so i pressed the power button and it turned on..so long story..check the power cord and blow out you tv.."but be carful"
Aug 09, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Blinking power light.
i hve the same problem. I turned on my Sharp Aquos lc-32d62u HDTV last night for the first time, but it is black and a blinking green light.
did you find a solution?
Mar 06, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Red light on power cord
try unplugging the power brick from the wall and the power cable from the 360. Then reconnect these cables and try powering the system on again. if the problem still continues, look at the front of the console, you should see a circular light. If 3 of the lights are solid red you will need to contact 1-800-4MYXBOX, as that indicated hardware failure.
Aug 16, 2007 | Microsoft Xbox 360 Console
Sharp Aquos LC-46D62U 46 in. LCD HDTV Logo
365 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
