Question about Packard Bell GCD-R580B (gcdr580b) Internal 8x CD-ROM Drive
Cd rom my tray is jammed. any idears?
  • e5boy13 Oct 07, 2008
    my cd drive was stuck in but i got a knife and pull it out however only some came out.if i press the eject button nothing happens
  • 170 Answers
Its very simple .remove the outer cpu case.then remove the cd rom open itplace THE TRAY in RIGHT MANNER ONCE AGAIN . donot try to move the tray of your cd rom without opening the cd rom ,it might result in a permanent damage
Posted on Nov 05, 2007
How do I get a cd that is jammed into a cdrom drive out when the drive will open.
there is a little hole in the cdrom\'s door.....prick it with a pin and the cd will come out
Oct 15, 2014 | Gateway Computers & Internet
How do I get a cd out of a cd rom that is jammed in but the drive will open?
There is a small pin size hole between the tray and the eject button. Push it with a paper clip and manually pull out the tray. 12e679d7-0444-4257-8340-46f126b73236.jpg
How do I open my jammed door on my e machine
Use a paper clip end and stick it into the small hole on the face of the DVD Tray surface. It is tiny , and hard to see, but it is there. Pus the clip into the hole and it will let the tray slide open.
Mar 02, 2014 | Acer (91.AB264.023) Internal 32x CD-ROM...
Cd jammed in a dell pp31l
There are two ways toopen the CD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drivetray next to the Eject button. Push the paper clip gently until the drive traypops out, then pull the tray until it is fully out, then you can remove the CDdisc.
If you continue having problem opening with the Eject button, then the CD driveis faulty and needs replacing.
Jan 20, 2012 | SIB USB External CD-ROM Drive for Dell...
Acer CD is not getting ejeccted
The mechanism is physicall jammed.
Take a Norwegian paper-clip, and straighten one end.
Push that end into the small hole in the faceplate of the CD-drive.
Push until you feel resistance, and then push another 1/4 inch (10 mm).
The door should "unlock" -- gently pull the tray the rest of the way open, and remove any disk.
Then, it's time to spend $40, to buy a new CD/DVD reader/writer.]
Sep 20, 2010 | Acer (91.49C37.001) CD-ROM Drive
Cd drive door was jammed and so i deleted the High and Low filters using regedit and now the dvd rom will not write however it will read. How do i fix the using a Dell xps 400 which has a...
You can go to dell's website to download the firmware of the dvd/cdrom. if you want to knpw the exact model of your drive you can check it at device manager,to dell's website Use your service tag to see the list of the drivers for your system when you go to click drivers and downloads.
Jul 20, 2010 | Dell DVD-rom DVD Drive
Cd is jammed
What you can do is look for a paper clip and make it into a long pin by straightening it. Then insert it into a small pin hole which you can find on the CD Rom. Push the pin a little hard and you will find your CD Rom Tray opening up about an inch out. Now you can pull the cd tray out and take out your CD. Read more at
May 06, 2010 | Apple 17 MacBook Pro Notebook Computer...
CD-Rom Drive tray came off
If the tray came out of the drive, it's toast. If the face plate came off the tray, it usually slides back on from the top down. If the face plate came off the drive itself, it should pop back on if you line up the tabs properly.
Oct 31, 2008 | E-Machines emachines (emachinees) CD-ROM...
CD ROM is jammed-wont open
This has happened to me. Sometimes when I'm in a hurry I'll place a CD or DVD in the tray and start to close it without making sure that the disk is seated flat in the tray. If it's ****-eyed the CD wil shatter when the tray is closed. The only way to remove the pieces inside the CD drive is to take apart the CD drive. Might be easier just to replace the unit. They run from about $25.00 to $75.00. One other note: You can try to open the tray manually by inserting the end of a paper clip into a small hole on the front bezel of the drive.
Oct 17, 2008 | E-Machines emachines (emachinees) CD-ROM...
Your CD-ROM may still be functional. The tray may just be stuck, instead of broken. First let's remove the CD.
Get a large paperclip and bend the end out straight. Look for a tiny hole underneath the CDS tray. Push the end of the paperclip into it, and it should open the CD tray a little. Then pull it out the rest of the way and get your CD out. Then try pushing the eject button on the CD-ROM to get the tray to go back in. It may take several trys. If that does not work push the tray in, slowly. Then try the eject button again. I hope that works.
If it does not you can continue to use the CD of course (lots of CD-ROMs have paperclips hanging out of them. And I've seen the problem go away, occasionally, after continued opening and pushing back the tray.
Mar 10, 2008 | Acer Aspire L100 PC Desktop
Packard Bell GCD-R580B (gcdr580b) Internal 8x CD-ROM Drive Logo
185 people viewed this question
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
