Exhaust torque
Tighten the top nut of the front cylinder head exhaust flange to 9-18 in-lbs (1-2 Nm), then tighten the bottom nut to 100-120 in-lbs (11.3-13.6 Nm), final tighten the top nut to 100-120 in-lbs (11.3-13.6Nm), then tighten the bottom nut of the rear cylinder head exhaust flange to 9-18 in-lbs (1-2 Nm), tighten the top nut to 100-120 in-lbs (11.3-13.6 Nm), then final tighten the bottom nut to 100-120 in-lbs (11.3-13.6Nm), tighten the transmission exhaust bracket clamp bolt to 60-96 in-lbs (6.8-10.8 Nm), tighten the two bolts with lockwashers, tighten the four TORCA clamps to 45-60 ft-lbs (61- 81 Nm) in the following order, crossover pipe to left side muffler, then rear header pipe to right side muffler, then front header pipe to rear header pipe, then rear header pipe to crossover pipe, tighten the Keps nut securing the bracket tab to the exhaust support bracket, open the worm drive clamps and install the six heat shields onto the exhaust pipes positioning each clamp so that the screw is on the outboard side in the most accessible position and then tighten them to 20-40 in-lbs (2.3-4.5 Nm).
SOURCE: need the torques specs for the 2 nuts on the clutch on a harley
50 ft lbs and it is a left is tight nut...don't worry about adjuster nut on clutch just good ole tight will work on that one. compensating nut ( one in front) is 150 ft lbs.
SOURCE: torque specs for derby , inspection cover, &
what is the torque specs for a derby cover on my 2009 Soft tail?
SOURCE: Need the torque specs on clutch for a 85 FLHTC
The torque specs are the same as with any Evolution engine. The compensator sprocket 150-165 foot pounds.
Clutch hub nut (left handed threads) 60-80 foot pounds.
Use Loctite 271 on threads. Two lines in nut on Compensator and one line in clutch hub nut.
SOURCE: what are the torque specs on a 2001 harley fat boy
Maximum Torque: 106 Nm (78.2 ft. lbs) @ 3200 rpm
SOURCE: 1982 Harley davidson shovel head , i need the
I always pull them to 70 foot pounds in a criss cross pattern. Start the engine up and allow it to warm up. When cool, retorque the heads in the same manner. I only use Fire Ring head gaskets.
Good luck
Steve
