Question about Black & Decker String Trimmer Cordless 12" 18V
Sprinkler my sprinkler elbow fell off from the pipe. I tried to fix by putting back the elbow connector to the pipe with a clamp. But there is no water sprinkle out though it did stick out,
How do yo adjust and install sprinkler
The sprinkler just unscrews from the underground supply pipe counter clockwise..
May 20, 2016 | Orbit 55059 Saturn III Sprinkler w
Why does my pump loose pressure
Sounds like your not using enough water, and or your pipes to sprinkler is to to small, causing pump to build up to cut off head. I cant lay my hands on a performance chart for your pump, but 60 psi cut off and 20 on sounds about right. Try running another tap when your sprinkler is running, and see if this keeps your pump running
Mar 25, 2015 | Utilitech 1-HP Cast Iron Convertible Jet...
The sprinkler system is shut off but there is still little water coming out of the sprinkler head. What is the cause of this problem?
Water will continue to run back down the hills to the lowest Heads and Some water will come out.It will stop once the water in the lines has Drained out.
Oct 02, 2014 | Garden
What is an ESFR sprinkler?
ESFR sprinkler is a fire sprinkler, more specifically an early suppression response sprinkler. They use fast-response fire sprinkler technology to provide fire suppression of specific high-challenge fire hazards, like in the piping system. Before these came about in the 90s, protection systems were used.
May 07, 2013 | Home
My tractor sprinkler was running fine and then suddenly stopped. What should I look for as the problem?
My sprinkler did (something like) this a couple of times (very infrequently) - the arms seemed "seized" (cannot rotate clockwise or counter clockwise) but, I was able to get them moving again by picking up the sprinkler (a couple of inches) by the sprinkler arm T-pipe. Picking it up this way, vertically, seemed to "un-stick" the arms.
Of course, if your sprinkler is very old (12 years?) the gear box may be worn, it would cost about a quarter to a third as much as a brand new sprinkler to replace. You can find the parts you need by reading the question about where to get parts at FixYa.
Jul 02, 2011 | Nelson Sprinkler: Traveling Tractor
I have low water pressure on my rainbird sprinkler system. how can i adjust it?
There are several ways to adjust water pressure on sprinkler systems. First you have to determine if there is a problem with the sprinkler system itself. Things to look for:
1.) make sure that all valves including the main are all the way open.
2.) Inspect the sprinkler heads for clogging. Sediment and debris can also clog your sprinkler heads. Some debris removal may be required.
3.) You make have too many sprinklers operating by one valve. You may need to divide a zone and add another valve to increase water pressure.
4.) If all else fails. You can install a breather intake cap to allow air into your sprinkler system thus increasing GPM (gallon per minute)flow.
5.) one of the biggest mistakes that peopel make is that they undersize the water pipe size to save money. Typically you want to use 3/4" PVC pipe for your main runs and tee into 1/2" PVC for your sprinkler heads.
Good luck. I hope this helps.
Jul 20, 2010 | Rain Bird Hardware & Accessories
Flotec Sprinkler Pump not priming
it might be that the pump is prewired at 230 volt and you are running a 115 power supply to it, if motor just humms and little water comes out this might be your fix
Mar 13, 2009 | Flotec 1 - 1/2 Sprinkler Pump Composite...
Black & Decker String Trimmer Cordless 12" 18V Logo
20 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
