Question about Whirlpool RF368 Electric Kitchen Range
Light bulb I cannot get the protective dome off my light bulb in my whirlpool self cleaning oven and I need to change the bulb. Thanks Dennis
  • 3 more comments
  • dilmore67 Nov 11, 2007
    I have an Amana Oven. Do you remove the glass dome cover the same way on it as you do the Whirlpool? Thanks! dilmore67
  • Anonymous Jan 08, 2008
    how do you remove the lite in a whirl pool self cleaning oven to change it
  • Anonymous May 03, 2009
    Whirlpool Super capacity 465 electric range, has burnt bulb and we cannot get the cover off to change it.
  • William Johnson May 24, 2009
    I have the same problem. I hate to put a strap wrench on glass, but I may have to. I sprayed WD40 and I used a rubber anti-slip pad that you use to remove jar lids, and I have large strong hands, but no luck.
  • Anonymous Mar 30, 2014
    I need to replace oven light with new protective glass and bulb. Can I still use the oven?
  • 473 Answers
It just turns counterclockwise to come off. Sometimes it is very hard to turn them. If you have a strap wrench you could try that.
Posted on Nov 03, 2007
    Welcome Back:
    Visited the website for 2 consecutive days.
I sprayed some PB Blaster arond the base of the glass dome were it screws into the stove, tapped it gently with a wooden spoon several times to help work in the PB Blaster, and let it set about 10 minutes. I then took a rubber lid grabber and turned counter-clockwise and off it came. WD40 should work ok if you don't have PB Blaster.
Posted on Nov 14, 2009
It is REALLY hard to get off. It sounds like stuff is crunching in there and it took my like 2 hours to get it off. Hopefully it will be easier next time :)
I did not have a strap wrench, although Sears has a simple one for $4.99. I did however, have some radiator hose clamps left over from an auto repair job. I coupled two together and closed them so they fit over the glass, then gently tightened the combined clamp with a screwdriver until it no longer slipped. That gave my hand enough purchase to twist the glass off without problem.
A little WD-40 prior to this operation might also loosen any possible corrosion and can be wiped off after the glass is removed.
Posted on Aug 26, 2008
If you do not have astrap wrench then ask spouse friend to put their hand onto and turn anti clockwise. Cover will turn and come off.
Posted on May 17, 2008
Thanks for the hint.
Posted on Dec 27, 2007
Whirlpool gas oven light bulb lasted 5 years but now keeps burning out?
all appliance bulbs are not created equal it needs to be specifically an oven bulb to take the heat .
Feb 14, 2016 | Whirlpool Accubake 30" Self-cleaning...
How do I replace the light bulb in a NEFF H7860B1GB/01 ?
Unplug power first. You need to remve the screwa that hold the bulb cover, access the bulb and replace it, I will wee if I can find a diagram.
Oct 06, 2008 | Neff Microwave Ovens
Oven Lighting
Warning: Risk of electric shock! Prior to changing the oven light bulb:
- Switch off the oven!
- Disconnect from the electricity supply.
Place a cloth on the oven floor to protect the oven light and glass cover.
Changing the oven light bulb/cleaning the glass cover
1.Remove the glass cover by turning it anti-clockwise and then clean it.
2.If necessary: replace with 25 watt, 230 V, 300 °C heat-resistant oven lighting.
3.Refit the glass cover.
24472822-skr3uzd4ii43xzwyhmpsswym-3-0.jpg Dado
May 21, 2014 | Electrolux EOB5665G Ultrafan Electric...
How to change oven light
Which model Whirlpool range do you have? For most Whirlpool ranges that I have used , the oven light is covered by a screw-on glass cover. When the oven is cool, unplug the range, open the door and turn the cover counter-clockwise (to the left). Then remove the 40W bulb (again counter-clockwise rotation). Replace the bulb with another 40W appliance bulb. Then replace the cover by turning it clockwise until it is tight. Do not over-tighten either the bulb or the cover. Then plug in the power cord for the range. (Unplugging the unit makes sure that you will not get shocked if anything goes wrong. Sometimes the bulb may break in the socket - in that case, use pliers to unscrew the base of the bulb before replacing it with a new bulb.)
Whirlpool has the manuals for most of their appliances on their support site: .
I hope this helps.
Jan 11, 2012 | Whirlpool 30" Self-Cleaning Freestanding...
How do you get the glass cover off to change the light bulb in the oven?
There is usually a snap on wire over the top of the light lens. Gently push down on that wire.
Jan 01, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
How do I change the light bulb in the oven
You can replace the light bulb(s) in your range/oven, though you may need to remove a glass covering or dome to reach it. Most interior oven lights use a universal 40 watt appliance bulb.
Apr 24, 2009 | Philips Ovens
Can't get light bulb out of oven to replace it
Facing the head of the bulb...away from the base...turn it counterclockwise....that the left. If you like, use a rubber glove to protect your hands in case it shatters. Use a slight jerking motion to break it free.
Dec 31, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Pry back the bulb glass cover wire spring and remove glass cover. Use heavy rubber gloves or a plastic bottle opener(piece of serrated soft plastic/rubber) and unscrew counterclockwise.
Mar 05, 2007 | Whirlpool GBS277PR Electric Single Oven
Whirlpool RF368 Electric Kitchen Range Logo
724 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
