Question about Maytag Neptune Washer
Maytag Neptune Front Loader MAH4000AWW was in rise cycle when it made a loud noice and now just sounds like gravel being turned in a rock tumbler or something. Will resstart on any cycle but will just go back to the gravel sound within 60 seconds or less.
    Sergeant:
  • 199 Answers
You have stripped a gear. I hope it is under warrenty if not you will need to get a technition to replace the transmission.
Posted on Jun 22, 2009
Won't spin or drain, have tried to rerun cycle and checked drain hose
Check pump / outlet filter , refer to instruction book , clean and replace then re- try
Nov 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Front Load Washer Model MAH4000AWW low last spin
two problems here,
your shaft seal is running on its last leg
the sound is unmistakeable and always described the same...
the water issue, you probably have a trickle leak through the cold water valve
the mixing valve is quite an easy repair, but I would have to say with all honesty, it probably time for a new machine
the hub seal is a tub replacment call
2 hrs of labor if hes good
and the tub runs around 500.00 dollars
sory for the bad news
Oct 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
We have a front loader MAH4000AWW and it sounds like the discharge pump is going bad. It is making a gravel sound when it is pumping the water out.
take the plug/power lead for the machine OUT so machine no power then.
safety first.
you need to clean the filter and also may need to take the pump to clear it
Jul 25, 2009 | Maytag MAH2400A Front Load Washer
Loud at the end of cycle. Like it is going to land somewhere
your bearing are out. this is an esy fix, about 1-2 hours. buy your parts on line and rent the tonytool (ebay).
parts about 75, tool rental about 75.
repair man cost about 400.
rod
Apr 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
Strange growling sounds on rinse and spin cycle
I would check the motor control board located near the floor on the right side for burnt components. The motor is a 3 phase unit and if one of the phases are working the motor will growl and won't be able to supply the proper torque.
See www.neptunehelp.com for disassembly photos and for more info on the faulty door latch wax motor.
Jan 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune MAH4000AWW Very loud noise when spinning
I found this on line ... 6/15/09 . Does your Maytag Neptune front loader sound like a runaway freight train when it is in high speed spin cycle? 2. Is your Neptune getting so loud that you cannot be in the same room while it is spinning your clothes? It sounds like your bearings may need some attention if you answered YES to the questions See www.neptunebearing.com ... Frank frankbusch@comcast.net
Sep 08, 2008 | Washing Machines
Maytag Neptune MAH4000AWW
email me at b4829@yahoo.com also it may not be the motor matags had a promblem with a resistor burning out on the control bd on your mail put maytag motor as the topic and will reply
May 21, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Maytag Netune Mah4000AWW
Makes a loud humming noise. Does the machine go thru its cycles ? Is the humm ther all the time ?
Jan 06, 2008 | Maytag MAH6500 Neptune Front Loading...
Washing Machines Logo
208 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
