Question about Cuisinart DLC-2011 PowerPrep Plus Food Processor
Cuisinart food processor
My processor indicates by the on button that it is receiving power but nothing happens other than that.
  • Anonymous Dec 28, 2007
    I have exactly the same issue. Can anyone help
  • juliekt Oct 22, 2008
    I have the same problem.  Wish I could offer a solution.  Cuisinart walked me through setting it up.  It IS locked but there seems to be some kind of disconnect between the motor and the on button.  It lights up but the motor will only run if I hold down the black reset button located on the front of the food processor.  I have only used it once.  They were no help and just suggested that I mail it to NJ from WA for repairs.  At my cost.  Hopefully someone has an answer.
    Problem Solver:
  • 5 Answers
I went through the same thing...as it turns out, everything was locked into place but I had the handle in the back rather than the front where the sensor is. Good luck. I hope that helps you.
Posted on Feb 06, 2008
When i try using it, nothing happens. i cannot
Remove the work bowl, blades, etc from off the base.
Plug the processor in and press the ON pedal down.
Use a pen to press in the rubber button on top of the base - you should hear a sound.
Now reassemble the bowl - lock the bowl in so that the handle faces front; insert blade of choice; place the tab under the feed tube of lid slightly left of center of the work bowl handle and slide the lid counter-clockwise until it clicks into place; insert pusher and make sure it locks into place.
You should be good to go again.
Sep 30, 2009 | Cuisinart Food Processors
It won't turn on
The work bowl and lid must be locked together in a specific order or else the processor will act dead. If your DFP-3 has a "tower" on the back, make sure the tab on the lid connects to this tower. If your model does not have a tower, call Cuisinart to verify the correct assembly - 1-800-726-0190
Aug 16, 2009 | Cuisinart DFP-3 Handy Prep 3 Cups Food...
Power is available (light is one) but nothing
Sounds like a safety feature working. Unplug. Take apart as if you are going to clean it. Check all parts carefully to see if there is anything broken, like a nub.(Are all parts there?) Put back together, making sure they are fully engaged. Plug in and try. This happened to my food processor and it was a bit of dried food stuck in the bowls sliding track that kept it from clicking fully connected. Hope this helps!
Jul 19, 2009 | Cuisinart DLC-5 Food Processor
Tried to use my powerprep pluss cuisinart food processor and nothing happens. The on button lights up but nothing happens when i press the pulse button.
Remove the work bowl from the base of the food processor, and separate the bowl, lid, and pusher sleeve.
Plug the base into the wall outlet, turn the food processor ON, and then use a pen to press in the dark grey or black button on top of the base of the food processor - if you hear some kind of noise, then your motor is still good.
Put the work bowl on first, with the handle facing the front of the food processor.
Put the lid on, with the lid lined up with the handle of the work bowl.
Put the pusher sleeve in the lid, with the metal piece facing the front of the processor.
Your processor should now turn on.
If it doesn't call Cuisinart and see if you are still in-warranty (3-year warranty).
-Tha Mp3 Doctor (also loves Cuisinart)
Mar 23, 2009 | Cuisinart DLC-2014 PowerPrep Plus Food...
None of the buttons work on my Power Prep Pulse 11-CUP
Put the lid on, with the hollow feed tube facing the back of the processor.
Put the pusher sleeve in the lid, with the sliding lock switch facing the front of the processor.
If your food processor still does not turn on, call Cuisinart and see if you are eligible for an in-warranty repair - it has a 3-year warranty.
Mar 23, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
Cuisinart won't pulse
I started from scratch with the assembly instructions. Got it together correctly and now everything works.
Mar 03, 2008 | Cuisinart DLC-2011 PowerPrep Plus Food...
Cuisinart 11 cup processor
Oct 13, 2007 | Cuisinart DLC-2011 PowerPrep Plus Food...
Cuisinart DLC-2011 PowerPrep Plus Food Processor Logo
317 people viewed this question
Top Cuisinart Food Processors Experts
Colin Stickland
Colin Stickland
Greg Cann
Greg Cann
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
