Question about LG LSC26905TT Side by Side Refrigerator
. water despencer have a tiny stream.
It takes forever to fill a glass of water the stream is so small if someone can help me with this it would be great. Thanks
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 99 Answers
I would replace the inline filter. My guess is you have never replaced it and its probaly clogged. Just follow the water line and it should go into a round cylinder and the a line comes out the other end and goes into fridge. Most hardware stores carry generic replacments that are much cheaper than factory and they seem to work better.
I’m happy to help further over the phone at https://www.6ya.com/expert/david_c087e4b7d13c0163
Posted on Jun 22, 2009
When washing machine does not take fabric softener in still left in draw at end of wash
Hi,if you start the cycle again open draw despencer you should hear and see water wooshing inside if nothing then the valve that lets the water through must have packed up or despencer is blocked if you can hear the water clean despencer draw.
hope this was some help
Mar 28, 2015 | Washing Machines
Why would my water dispenser not not let a full stream of water out with the filter engaged it is new about 4 weeks old ?
Not filling at all or just a small stream? It is not uncommon for water fridges to have reducers in the water line to restrict the water flow. If the fridge lets water go through too fast, it wont have time to cool down and after only 4 or 5 glasses, you will have tap temperature water and have to wait until it cools again.
Jan 03, 2015 | Kenmore Refrigerators
Ge side by side ice maker not filling up
most of the time when that happens first thing you do is make sure water is getting to the solenoid for the ice maker if you have a water despencer you have water the solenoid for the ice maker is normally found in the back of frig near bottom pull frig out till you can get behind it look where water line goes into the frig solenoids for water and ice maker should be there. leave frig plugged up have someone use the water despencer feel whitch one that is replace the other one
Aug 20, 2014 | GE Refrigerators
Bosch compact Logixx dishwasher (8401) will not start after it did turn on to start a cycle. Pump made laboured draining noises then seemed to cut out. Water remains in the bottom after last cycle.
My dishwasher started to act up in not filling properly. Timer would not descend. To cut a long story short, I detached the filler hose and found a very small plastic filter which pulled out, but very carefully, with some small straight nosed pliers. At first I thought it threaded but as it loosened ,came out quite easily.
I made sure the filter was clean and then looked into the recess from where the filter came. I saw a small valve surrounded by a black rubber washer. this pulled out with long nosed pliers. the valve had four tiny holes in it and I found I could not blow through the holes.I blew harder and suddenly I could blow through the tiny holes and the blockage was obviously free.I couldn't believe that these minuscule holes in the valve's disc could cause such misery but after reassembly the machine worked like it was new. i hope this may help someone.
Mar 24, 2012 | Bosch Dishwashers
My water preasure in door is terrible takes forever to fill glass
Either replace the water filter or replace the water valve ( located behind the refrig where the wall water line connects to ) or , install the water filter bypass piece which came with the refrig . ( This will tell you if the filter needs replaced ) .
Sep 08, 2010 | GE GSS20IEP Side by Side Refrigerator
Slow filter water stream and hollow ice.
You have a mesh screen in the water supply line where it connects to the water inlet valve. It can be stopped up with sediment.
Sep 27, 2009 | Freezers
Kitchen aide ksrg22ftss fridge wont make ice and
check your fill solenoid located at the bottom back of fride the valve may have a verry fine filter inside the valve ether clean it or replase the valve valve cost aprox 20,00 thanks from gilles
Mar 15, 2009 | Refrigerators
LG LSC26905TT Side by Side Refrigerator Logo
189 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
