Question about Dirt Devil CE6000 Featherlite Wet/Dry Vacuum
Shampooer dispensing my dirtdevil shampooer does not dispense water throughtout all holes in bottom. how do I unclog them?
  • eltabe Apr 28, 2008
    Mine Featherlite is also not dispensing water. The motor is running. Any suggestion is appreciated.
I occasionally run some water and vinegar (equal parts) through the machine, just as I do for clogged holes in my steam iron. So far it has been doing the job.
Posted on Aug 31, 2008
Rainbow e2 aquamate
Hello ,
U r missing a wee screen that fits on the hole where the little hose plugs into the tank. Check inside the hose end or down inside your shampooer box.
May 26, 2008 | Rainbow E series Canister Wet/Dry Vacuum
No water comes out of my bissell shampooer. How can I fix it?
look in your bottom where the water comes out it might be clogged there you should try vacuuming it out
Jun 29, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Instuctions on how to use them together
youhook up the shampooer the same way you would hook up the vacuum head. you can put jut a little bit of water in the basin and it basically works like the vacuum except it dispenses cleaner and water when you posh the button in on the handle.
Apr 02, 2009 | Rainbow E series Canister Wet/Dry Vacuum
My Kirby shampooer - G4 - hardly used any water from the tank and no suds at all. Pet hair did blow out of the small slotted holes in the tray as I moved the shampooer back and forth, but the carpet was...
Few things:
Make sure the sponge and the valve under the sponge (water tank) is clean.
Make sure you follow the instructions (f you do not have the manual you can find one HERE)
See if the straw inside the water tank is not clogged (happens when you use toilet tissue or some other paper to dry inside of the tank after you shampoo)
Noise - if it is noisy al the time - it may need new shampooer brush roll. Also check the tray - bar brush roll bearings overheat and melt the tray... Never submerse brush roll in water when cleaning it. Clean it simply by lifting the shampooer nozzle and letting it spin for 10-20 seconds. If you have tu put it under running water - put it back in the shampooer nozzle (with tray and shield) put on Kirby and turn it on for 20 seconds or so. If it stays soaken wet - moisture damages barings.
Good luck
Feb 28, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Bissell carpet shampooer wont dispense water
Bad Pump. You pump is where the belt attaches to spin the brushes and also puts water on the floor. Take it to you local Best Buy to be serviced or a local appliance shop which may service it.
Dec 15, 2008 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell power washer 1694 shampooer
First off is the gasket on the bottom of the tank vavle or sitting in the hole. It has to be on the bucket. May have a problem with the handle not pushing the valve (in the handle)open when you squeeze the trigger. Check the back end of the top cover to make sure it hasn't broken loose from the base, if it has, that raises the top so water won't dispense from the tank. The draw back is that Bissell has obsoleted some parts for this model.
Sep 20, 2008 | Bissell Powersteamer 1694 Upright Vacuum
Want to Buy a Repair Manual for Bissell Proheat 9500 Clean Shot
I have the manual and would be more than willing to me at
Aug 19, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
No WAter
Does water squirt out of the hose nozzle, if it does, then check the heater inside the handle asm. Make sure that where the tubes hook up to it are not clogged. If water doesn't squirt, check for the seal at the bottom of the tank, it needs to be on the tank, not in the hole, this is for the soap bottle also, there is a seal on the bottom of it as well. The flow indictor cap is leaking air or maybe is too tight. If you had the top cover off, make sure that the tubes are routed right so as not to get pinched when the cover is put back on, the smart mix knob should be in the water setting and that the piston is on the bottom of the smart mix knob. Pump is bad. Try running a mix of vinegar and water to see if that unclogs the lines. Is the top cover and the base tight together in the back, sometimes the top breaks loose and it will raise up and it can't spray, just re-fasten it down.
Jul 13, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Dirt Devil CE6000 Featherlite Wet/Dry Vacuum Logo
328 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
Tim Venetis
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
