Question about Black & Decker String Trimmer Cordless 12" 18V
String is cut always
I am not an expert in gardening. Whenever i use the string edger for the grass cutting, the string is cut short faster than the grass. I tried different angle but it didnt' work any better. Would you please instruct me the right way?
Thanks.
Vivian
    Sergeant:
    Champion:
  • 208 Answers
First of all be carefull of what you hit with the trimmer string if you hit sidewalks and rocks or dirt it will cut it short also you might make sure the tensil strength is strong enough to withstand the abuse the trimmers being subjected to :-)
Posted on Jun 22, 2009
Black & Decker GH3000. String is stuck on reel.
We live in a townhouse so our yard is't very large. We had actually skipped a few weeks of cutting the grass since our reel mower blades were too dull to cut the thick weeds and grass. This thing got the job done and did't break a cord. Really love Black & Decker tools. More details about the tips and tricks about the Black & Decker Click the link String is stuck on reel
Jun 02, 2018 | Black & Decker Garden
What do i need for replacement string? Can i go heavier or stay with the smaller string? This is for mastercraft 20v grass trimmer. thanks
the size of the string is critical in electric driven trimmers
it does have mass and the thicker string will over load the motor
stay with the recommended string size and keep to the recommended distance to the grass being cut
string line cutters work on the principle that the tip speed of the string is what does the cutting and that means that the first 1/2" of string cuts the grass
the rest back to the hub acts like a brake as it is dragged across the grass and slows the cutting speed and loads the motor
remember that the machine is designed to trim edges and not to cut down growth-- that is a job for heavier duty units
May 13, 2016 | Garden
Grasshog GH700 spins but doesn't cut the grass
Most likely the string is not the right size in length and/or diameter.
Check instructions in the user manual available at this site.
http://servicenet.blackanddecker.com/documents/English/Instruction%20Manual/90563741,GH700.pdf
Sep 02, 2014 | Garden
My grass hogger line extending unnecessarily and never get line short ( i meant extra line never get cut off. I think i have two problems here Why line is extending unnecessarily? & why it's...
If you look closely inside the shield, at what would be the leading edge as the string approaches, you should find a little cutter that trims the line if it is too long. This can get dull. I have had to sharpen the one on my B&D with a file before.
Sep 03, 2011 | Black & Decker Grasshog 12 Inch 18 Volt...
How to put together a black n decker grass trimmer,has assembled the trimmer it's not cutting the grass should there be a blade in the trimmer
No, it is not heavy duty enough to drive a blade. It should have cuttting line in it and it only can use up to .065" string (factory recommended).
Oct 12, 2010 | Black & Decker 14" Grass Hog Xp...
It looks like its working fine, but it doesn't cut the grass. Looks like the string is spinning with the turn instead of against it, if that makes any sense.
If the string is spinning it should cut no mater which way it is turning. maybe you aren't getting the trimmer close enough to the grass.
Apr 17, 2010 | Black & Decker String Trimmer Cordless 12"...
String trimmer cutting attachment doesn't turn fast enough
Take the shaft off at the motor,see if any thing is worn there.Also,take head off of end of weed eater,check for grass or any build up in there.
Aug 29, 2009 | Troy Bilt Tb70ss Gas Trimmer
I need directions to replace string on black and decker cordless 18v grasshog
Go to home depot. look at the floor model and the replacement spools they sell there. Reverse engineer the stringing process or but a pre-loaded spool.
Otherwise,
1. Squeeze the tabs on the side of the head of the unit to remove the spool cover.
2. remove spool.
3. place end of string in small hole in center ring of spool.
4. wide spool with string in the direction of the arrows printed on the spool. DO NOT OVERLOAD!.
5. snap string into notch on spool and cut string leaving 6" exposed.
6. thread 6" of string through hole in side of unit head, replace spool, and replace cover.
7. go cut grass.
Jul 07, 2009 | Black & Decker String Trimmer Cordless 12"...
Black & Decker String Trimmer Cordless 12" 18V Logo
198 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
