Question about GE GSH22JFR Side by Side Refrigerator
The condenser fan is not running and our ref. and freezer are not staying cold
  • 286 Answers
If the condenser fan is not running then the compressor will overheat and go out on overload. Replace the fan motor and that should correct the problem
Posted on Jun 22, 2009
Ffa52 hotpoint diamond freezer running too warm
change condenser fan clean condenser coil dust at bottom of ref stopping cooling processes.Just like if you put cardboard in front of your car it will over heat or if fan is not blowing air on condenser coil
will not cool it fan and coil at bottom of ref. remove back you will see the dust pet hair a big problem with ref.
Mar 04, 2015 | Hotpoint Refrigerators
Product # 921 1481 10 serial # 54800070 I turned my unit on and only the freezer got cold. what can I do?
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Check cold control (thats where you turn it colder)
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME If this was helpful
Jul 30, 2011 | Dometic Refrigerators
I have a GE Profile side-side refrigerator - model PSS26SGPASS. The refrigerator and freezer stopped cooling completely all of a sudden. All controls on the display are working but it does not cool even...
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
Then check to see if FREEZER CONTROL is turned warmer which makes REF. colder or vice versa.
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
May 28, 2011 | Refrigerators
My Samsung Mdl #RS265LABP-XAA will cool the refrigerator section, then stop cooling. The freezer section stays cold. I think the refrigerator fans works intermittetly but I cannot find it. Where is it...
Freezer fan located in freezer section.
Try These
NOTE: This
Leo Ponder
imufo2
May 22, 2011 | Refrigerators
My fridge/freezer isn't staying cold
adjust temp. control to coldest. check the door leakage of cold air.check comp. operation if continues if not check condenser fan ok stock appropriate load to the refrigerator observe operation of compressor if normal. adjust the location of ref. unit
Jan 23, 2011 | Refrigerators
Refrigerator compartment cools correctly for a few days then no longer receives cold air from freezer. The freezer continues to operate and gets much colder than it should.
does your fan blow? freezers have a fan that pushes cold air to the fridge side if fan is bad freezer will run extremely cold and fridge won't cool down and since frige won't cool down thermostat in fridge doesn't tell compressor to stop
Feb 26, 2009 | Refrigerators
Freezer works fine but fridge side stays at about 45 degrees
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
Now, why is that cold air not getting over to the Ref side?
1. The little door is not open.
check your control setting. You should be able to feel air coming through the channel on the Ref side.
2. The fan in the freezer is not working.
You can hear this fan running when you open the freezer.
3. The coils on the freezer side are clogged with ice which won't let the fan circulate the air over to the Ref side.
This is a failure of the defrost system.
Jan 10, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Fridge not working, freezer is
First, I think it’s important to know that the Ref area has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
Now, why is that cold air not getting up to the Ref side?
If you want mor info to DIY check out: ronbuice.com
Dec 16, 2008 | GE GBS22HCP Bottom Freezer Refrigerator
Refrigerator/freezer not staying cool
If there is no frost on the freezer side it may be low on coolant.
Dec 03, 2008 | Admiral 26 cu. ft. Side-By-Side...
Fan keeps running
freezer fan runs when freezer calls for cooling
ref fan runs when fridge calls for cooling
condenser fan up top runs with compressor
lower unit condensate fan runs with compressor
fans should not be noisy
control monitors temp and will give alarm if temp rise
please contact viking as your fridge may have a safety recall on door hinges
Jul 03, 2008 | Viking VCSB483 Side by Side Refrigerator
GE GSH22JFR Side by Side Refrigerator Logo
93 people viewed this question
Top Refrigerators Experts
Sal De GO PATS
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
