Question about Initial Televison & Video
Initial hdmi tv, no signal received
Recent purchase does not show picture, all shows is a blue screen with message "no signal received
  • 47 Answers
If you are trying to get 'off the air' signals then you must scan for the new digital channels in your reception area (this info should be in your owners manual). If scanning doesn't find any signals, you might have to add a VHF/UHF line amplifier(s) between your antenna and the TV set or improve your outside antenna or the cable leading from it to your set. You might have to resort to subscribing to HD cable or satellite TV.
Posted on Jun 22, 2009
How do I get Amazon Fire TV resolution set so I get more than a blue screen?
Select the input channel for your Fire TV - Turn on your TV and select the input channel for the HDMI port you used to connect your Fire TV. You should then see a loading screen with the Amazon Fire TV logo 4.
Jul 04, 2017 | TV Box Televison & Video
Mac Mini - Signal is not compatible with this intput
Can you change the signal format in the display settiings? 1080p is the native one on your monitor, try difrent ones if availabe. also test difrent resolutions.
Jul 06, 2008 | Sharp Aquos LC-45GX6U 45 in. HD-Ready LCD...
I'm back.my mitsubishi ws-48413 tv only has a blue screen when i turn it on. Ive tried several things. I tried turning on the receiver first and waiting 10 seconds and the opposite. I rebooted the tv...
There is a communication error between the source & the TV. When powering up the units, try turning on the receiver first, then turn the TV on, that way there is a signal for the TV to detect at initial start-up.
Dec 12, 2014 | Mitsubishi Televison & Video
My tv doesn't show picture and there is no sound it only shows blue screen and the remote don't want to operate.what can I do? Panasonic
Most likely an analogue antenna or satellite dish connection, and or set-up problem! Don't you get a "NO Signal" warning? Check physically your antenna or dish, and connection cables, to ensure that all are correctly connected and not detached or loose. Check your TV menu set-up - make sure you have selected TV from the other possible options such as video, HDMI, USB etc. If that is all OK then call your TV specialist to correctly align your aerial or dish. The remote is likely a separate problem. Been dropped or something? Buy a new universal remote.
Aug 11, 2014 | Televison & Video
I have connected the HDMI cable from the home theatre system into my TV but when I select to receive the Home theatre System signal (HDMI) on my TV it does not show the SONY Screen (It flashes as if it is...
Change/ reduce HDMI resolution in DAV-DZ810 so your tv can get proper video signal because it seems DAV-DZ810 is set on bit higher picture resolution and tv is unable to present that picture.
Thanks.
Jan 10, 2011 | Sony DAV-DZ810 Theater System
2004 hlp4663w component and hdmi signal error message
Chances are the analog board ( One with the Inputs) need replacement. You can get one at the following link. www.tvrepairworld.com
Jan 02, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
I recently purchased a new Samsung Blue Ray player. My previous Sony DVD player used the blue,green, red cords plugged into DVD imput, and I used Coaxial for sound. The Blue Ray only uses HDMI, which the...
Optical carries only 5.1 sound, no video. HDMI carries both video and sound. If your receiver doesn't have HDMI, check your TV for optical output. You can go BluRay to TV via HDMI, then TV to receiver via optical.
If you don't have optical out on your tv, you're going to need either a receiver with HDMI or a BluRay player with component output (blue, green, red).
Dec 06, 2009 | Sony STR-DG500 Receiver
Toshiba DLP 60" TV not showing TV programs, sound ok
Have the tuner signal board replaced. HDMI does not use the regular tuner bands, it is bypassed when using hd inputs.
Aug 25, 2009 | Toshiba 52HMX94 52" Rear Projection HDTV
Unable to get HDMI signal into TV
In the setup guide, try going to the HDMI option where you turn the montior out to "on" for the HDMI output. I don't believe that the receiver comes with the HDMI out already turned on...
Dec 31, 2007 | Onkyo TX-SR605 Receiver
Televison & Video Logo
208 people viewed this question
Top Initial Televison & Video Experts
Jim Goldsmith
Jim Goldsmith
Are you an Initial Televison and Video Expert? Answer questions, earn points and help others
