Question about RCA P52926 52" Rear Projection Television
My T.V. won't come on.
T.V. was working fine then made a loud pop and turned off.
I checked the fuse at the power cord and it's good but still
nothing. RCA M#P52731wk, S#433380314, CH#PTK169PGB.
HELP
  • doylefam4 Jun 23, 2009
    Thanks, I'll take a look
  • Loughlan May 11, 2010
    I wouldn't think a fuse would be such a loud 'pop'.
    If you have the unit open, have a look for a blown capacitor (little cylindral tube).
    Most capacitors nowadays have a little cross on the top to prevent them from exploding, however if one has gone, you will see the top opened up.
    I realise this isn't a 'solution' per-se. Hence why it is posted as a clarification request. Sorry I couldn't help much further than this.
  • 668 Answers
I would guess that the HV Block has failed. A very common failure. I would hesitate trying to replace it unless you are familiar with Projection HV circuits. You did good supplying
the Model # and Chassi #. both are required to get the proper part# if you try to get the part yourself or calling a service shop to fix it.
Hope this helps,
Skyassoc
Posted on Jun 22, 2009
Fuse rx 570 pioneer stereo
Sounds like you have a much bigger problem than just a fuse. Popping sound and burning smell means something much more serious.
Jun 18, 2013 | Audio Players & Recorders
My asb light comes on when starting and stays on. Lights won't come on , power locks won't work, power windows won't work, radio won't work. All fuses are good and car runs fine.
Those are all really common symptoms of the alternator going bad on those cars. I would have it checked to make sure it's charging properly.
Dec 15, 2012 | 1996 Oldsmobile Cutlass Ciera
After moving dryer to new apartment, worked at first but now won't turn on
Did you check the power source? You could have popped a breaker (or fuse) if the dryer circuit in the new apartment is inadequate. Might have been good for one shot, then no more.
Sep 03, 2012 | Maytag Dryers
Samsung plasma tv made a really loud pop and the screen and sound do not work but the red power light won't come off unless the tv is unplugged what happened?
The main power supply regulator board has the fault. Check if any electrolytic capcitor/s has bursted out. Replace them if any. If this do not help you. repalce the board as card basis.
Replacing it as card basis is fine, rather than making 'surgery' to it.
May 28, 2012 | Televison & Video
CH-DVD 320-won't come on at all. Used to work fine. Now won't come on, it's dead.
If your unit has no led light lit on the front panel, this is an indication that the power supply board is not working(dead).
First thing to check is the basic, I'm assuming that your outlet is live. Check the continuity of the power cord using the multimeter. Sometimes it has an internal broken wire due to frequent pulling and bending. If the power cord is good, open the top cover of the unit and check the internal fuse. Sometimes due to voltage surge and aging, fuse fail. If this is the case, replacing with same current(ampere) ratings will cure the problem.
Let me know if the fuse is intact or blow again after the replacement to determine the next steps.
Jdvillanueva
Jul 11, 2011 | Televison & Video
Dryer will not turn on. Checked outlet with
unplug dryer and take back panel off. plug back in. use caution your working with 220v. get a reading on power cord where it connects to dryer. if your good there look for a micro fuse, two small wires connected to it very small component. sounds like you have a bad power cord or power surge popped micro fuse. good luck and be safe!!
Jan 09, 2010 | Magic Chef CYE3005AYW Electric Dryer
Loud pop and now Vizio 37 TV will not work
This sound like the power supply board went bad. You should check that. See if the fuse on the board is blown first.. You can get a "pulled" power supply board on the net if needed.
Mar 07, 2009 | Vizio L37 Television
TV made a loud popping sound and quit working
The loud pop you heard was a part just blowing up and becoming non functional. Look for a bad capacitor - they can go out with a bang!
Since the set is dead the issue might very well be in the power supply - start there since those units are very vulnerable to failure.
Mar 12, 2017 | Televison & Video
TV popped when turned on
My sons tv did the same thing, 3 trips by the repairman before they finally replaced the "brain" Works fine now
Dec 25, 2007 | Hitachi 50UX26B/27K 50" Rear Projection...
RCA P52926 52" Rear Projection Television Logo
266 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
