Question about Home Theater Systems
How to flip image on ceiling mounted benQ MP622C front projector
Help - has anyone done this image flip on benQ MP622c front projector
0 characters
1 Points
Hi i have just connected up panasonic home cinema system via my projector and the titles etc are back to front any ideas ?? Regards
Trying to understand your problem. Sounds like an orientation problem with your projector. Check your manual to get image orientation setup correctly for your projector. Look for projecting image onto the front of screen instead of projecting image thru the back of screen. Some times the application calls for projecting from behind screen just like a projection TV.
Feb 14, 2015 | Panasonic 5.1 DVD Home Cinema System 1000W...
How can i invert the picture on my sony vpl-cx21 projector?
Go into the main menu of the projector and look for mount settings or advanced picture settings. choices should be Front, Back, Floor, Ceiling or worded like that. Hope this helps
Jun 21, 2009 | Home Theater Systems
I can't get surround sound from my theatre system
Read your manual , there is a level setting for each channel as well as a test function. Also remember most media on pro-logic mode dont have to loud sound from the rear speakers. Only a forced mono mode may give you louder sound at the rear. Regards PSP
May 12, 2009 | Home Theater Systems
HTS 3450 subwoffer off
I have a similar problem. I inspected the power board and found IC901 burned completely. I cannot find out the part number and have tried to get a reply from phillips but have not heard back from them. Anyone have a schematic or can give me the part # of IC901?
Sep 06, 2008 | Philips HTS3450 System
Projector won't switch on
You may have a failed power supply or a blown lamp. If you have access to a spare lamp, try changing it. (as described in the user guide). If you know the lamp is good for sure, then it is better to call service folks.
Aug 23, 2008 | Home Theater Systems
Hooking up surround sound
do you need a reciever to get ceiling mounted speakers to work surround sound
Jul 11, 2008 | Home Theater Systems
No Image nec vt465 and yamaha rx v540
You must use the projectors menu to choose the type of input for video out. Your projector is capable of 720p or 1080i high def, but not through s video. If you want high def you must use the component output from your receiver to input on your projector. I hope this helps.
Jan 23, 2008 | Home Theater Systems
No diolougue
cheak audio setting try hitting the audio buton flip throw the modes it has ok in manel shows how to do factory reset also or in menu in the unit
Nov 11, 2007 | Samsung HT-Q40 System
Koss KS5190 Display mode stuck
I'm not ranked and I'm not a Guru, but I can solve this picture rolling when the problem is "the video was accidently changed from NTSC to PAL and you can't see what your doing to get it back". You will need the remote control unit. First, remove the disc from the tray. Now, turn the unit off with the power button. The tray will close by itself. After the display on the front of the unit goes out, turn the unit back on using the remote control. This will let you know the remote control unit is working. When the power comes back on and the display on the front of the DVD player says, "NO DISC", with the remote control and (very important) while pointing the remote at the player, (Remember to point the remote before pressing any buttons) press the "Down Arrow" button 3 times. This will take you to the "Display" box. Now, press the "Right Arrow" button 1 time. This will take you to the "TV Image"box. Now, press the "Down Arrow" 1 time, this will take you to the "PAL/NTSC" box. If you have done everything as I have tried to clearly lead you blindly to your destination. Press the "OK" button 1 time and the picture on the screen will stop rolling and change from black & white to color. You will have now changed your video output from PAL to NTSC. If you press "OK" again, it will start to roll again. If this did not take care of your problem, turn the player off and try it again.
The previous problem solvers were on the right track, but the track was rough and they just about derailed the train. Thanks to them, I had a track to follow. I had no other information, except what I found on "". MR. CD
Feb 03, 2007 | Koss KS5190 System
Home Theater Systems Logo
234 people viewed this question
Top Home Theater Systems Experts
Gyula Lacz
Are you a Home Theater System Expert? Answer questions, earn points and help others
