Question about DeLonghi DEFSGG36-SS Gas Kitchen Range
Electrics not working
The electrics appear to have gone with my delonghi range cooker. The display doesn't light up, the ignition has stopped and the electric oven doesn't work. This happened after the plug fuse went and the trip switch in the fuse box also went. Both fuses have been replaced but the electrics are still not working. Any ideas of why and how to fix this?
Re: electrics not working
Sounds like the board on the b ack where the main cable goes in,this happend to mine,very cheap to fix
Posted on Nov 24, 2007
0 characters
3 Points
I have power but not switching on at Knob no grill or oven no fan
Beko OIF21300B Electric Single Oven not heating - Repair
Jun 11, 2015 - If your Beko OIF21300B Electric Single Oven is not heating or tripping the ... Now the cooker turns on and the display lights come on but the cooker does not seem to work and start heating up. ... The grill element doesn't work
[PDF]Download Manual - Beko
Congratulations on your choice of a Beko quality cooker which ..... Before you startusing your cooker, clean ... if an appliance burner doesn't light, press again.
Dec 13, 2015 | Beko D533AW Single Fan Oven Electric...
I have a delonghi Beta90ss rangehood (No. 0238). Fan and lights not working but indicators light up. Any idea if this problem can be fixed please ? Some electrical repair people say on the phone that...
The DeLonghi model's problem appears to be the same as the Parex one found here: Solution is described therein.
Oct 26, 2010 | DeLonghi Kitchen Ranges
Ignition wont work, there is an electrical supply to the cooker
yes there will be a cooker switch located somewhere in the kitchen & from that there will be a supply to a cooker point witch is a white box that is no bigger than a single socket.
there should or should have been a 10mm heat resistant flex running from that to your cooker.
if there is a flex then your ignition mite run off a 3volt battery.check your manual if not then try this web site :,MGQJD.aspx
Jul 02, 2009 | Rangemaster Classic 90 (Electric) Kitchen...
Delonghi px906 oven symbols have come off
Hi, I've just bought one of these with manual included.let me know if you're still having problems and I'll mail you a copy.
Apr 09, 2009 | DeLonghi Kitchen Ranges
New World Classic 100 cooker
The closk and ignition is no longer working, how do I solve this?
Aug 27, 2008 | New World Ellingwood 100 (Gas) Kitchen...
DeLonghi DFS 090 SO DUAL FUEL ELECTRIC COOKER NO LONGER HEATS UP. The grill and fan works but the electric oven no longer works.
I had the same problem,it was something to do with the oven knob switch ,i got an engineer out to fix mine or else just buy a new knob hope this helps
Jul 12, 2008 | DeLonghi Kitchen Ranges
Stoves 900DFa dual fuel cooker
check to see if one of the oven elements are burned into if you have an oven cord on it turn the breaker off and check the cord where it connects to the oven
Mar 15, 2008 | Stoves 900DFa Dual Fuel (Electric and Gas)...
Cooker not heating up
removed broken element and replaced it. You have to access the fixing screws from the back of the cooker to remove it
Feb 14, 2008 | Smeg A2.5 Dual Fuel (Electric and Gas)...
DeLonghi DEFSGG36-SS Gas Kitchen Range Logo
488 people viewed this question
Top DeLonghi Kitchen Ranges Experts
Paul Bade
Dan Webster
Dan Webster
Are you a DeLonghi Kitchen Range Expert? Answer questions, earn points and help others
