Question about Dell Dimension 8300 PC Desktop
Dell demension 8300 pc
Cannot get bios to boot from cd rom to install an OS
  • 2 more comments
  • donaldhantzs Jun 22, 2009
    press F2 to get into bios, goto boot, mve arrow to cdrom, but cannot move to priorty, and if i can, do i then press F10
    can get to bios, get to boot, arrow next to cd rom, but can not move to priority boot
  • Loughlan May 11, 2010
    Do you mean that you cannot get into the bios or that you cannot set the bios to start off CD?
  • chrisbock May 11, 2010
    Can you access the bios if so put the cd rom 1st in the boot priority then save and exit. it should then boot right from your cd rom drive.
    Sergeant:
  • 199 Answers
I am not 100 % sure but bressing the Plus sign and minus sign to change priority some times page up or page down does it too. debends on the bios is it pheniox or award BIOS
Posted on Jun 23, 2009
  • 25 Answers
In order to access the bios, press F2 on startup (prior to reaching the windows start screen)
Posted on Jun 22, 2009
  • Loughlan Jun 22, 2009
    Try pgup/pgdn or + or - when you see have the boot priority option specified.
    It also usually gives options at the bottom of the screen saying what are valid keyboard options.
  • 508 Answers
Make sure boot sequence is cd-rom first and possibly disable hd
I have a pc, model dell optiplex 360. i got a hard disk. i install to the pc and then try to install the win xp os. i had set the boot seqence to decect the cd room first. but the pc not detect it. so i...
Ensure the disk and ROM compatibility.
check the CD/DVD in other drive and vice versa (another CD/DVD in PC CD/DVD ROM.
then ensure the booting sequence in BIOS setup. if every thing is ok and fine then the problem is with your CD/DVD ROM.
vote me if found helpful.
Aug 06, 2011 | Dell OptiPlex GX260 PC Desktop
I am trying to re-install windows xp on a DELL dimension 8300 but it does'nt boot it can go to the BIOS and everything but it say Boot.mgr is missing
You should use the bootable Windows XP CD to start the installation.
To do that, you must first enter the BIOS in the Boot Options select the DVD drive as first (so that it will boot from CD/DVD first, instead of the hard disk). Save and Exit, insert the bootable Windows XP CD in the drive and when prompted to do so, "press any key to boot from CD-Rom".
Hope the above helps.
Mar 13, 2011 | Dell Dimension 8300 PC Desktop
HELP
ok
For that check in bios that first boot device is your cd or dvd rom.
When you power up the computer pressF2 or "del" key to enter in bios then go to boot option then set first boot device as your cd or dvd rom then save settings then exit.
then check.
Also you can boot your cd or dvd with F12 key
Press F12 when you power up then select your cd or dvd for boot.
Please rate solution if it helps you.
Thanks for using fixya.
Jul 18, 2009 | Dell Dimension 8300 PC Desktop
You're probably looking for "F12", or less likely the "Escape" key. It doesn't hurt to press it a few times, since the window of opportunity can be pretty short sometimes. Obviously if you see the Windows (I assume) logo, you've gone too far.
Jun 22, 2009 | Dell Computers & Internet
DELL Demension 8300 PC, cannot boot from cd rom
try ubuntu which is a good version of linux,search on google..Now if you really want to install another o/s then you need to change BIOS setting to boot from cd first on start up screen.For most pcs it;s normally a delete or F2 button but hace a look at boot up it will say something like press del or F2 to change...
Jun 22, 2009 | Computers & Internet
Dell Dimension 8300 - Can't Boot from XP Disk
When in doubt do without, that is remove the new hard drive cable and power, remove the DVD drive and try loading booting the XP from just this CD device. Enter the BIOS and check if the system sees the device. If it's not found in the BIOS then you'll never boot anything. Address it as the Primary device on the cable (I don't use CS) and see if the BIOS sees it.
If you get CD device seen in the BIOS then try to boot the CD in it. If it boots then power off and connect up your 40gb drive (optioned as Primary) on the other cable. Now power on as check the BIOS for the drive and the DVD device. If both are seen then boot the cd and try to load XP. After it's up and running install the other CD device as a Slave on one of the cables.
May 28, 2009 | Dell Dimension 8300 PC Desktop
NOT DETECTING CD ROM
Although the BIOS in this old machine has a boot from cd option, it is quite possible the DVDrom drive simply doesn't support the feature. Many P2 machines were like that. Chances are you will need a bootable DOS/WIN95/WIN98 floopy which will allow you to get it running with a CD driver.
Once you have this accomplished you can simply use the command prompt with cd support boot option and use the command prompt to load the installer on the CD. Once it finishes it's initial setup it will be able to use the cd drive for everything BUT booting.
Hope this Helps FixYa,
Chris
May 20, 2009 | Dell Computers & Internet
Boot problem
open your bios setup and check the cd rom is recognized and check the boot priority is set to allow to boot from the cd rom first.
Feb 20, 2009 | Dell Computers & Internet
My dell optiplex does not boot and when i try to reinstall it wont boot from cd
I wonder what error message you're getting.
Click here to enter your service tag and to find out if your PC is under warranty. If it is then call Dell and your're good to go.
http://support.dell.com/support/topics/global.aspx/support/my_systems_info/details?c=us&l=en&s=gen
Run the on-board diagnostics: (essentially F12)
http://www.mss.net/Links/DellDocs/OptiGX260/UserGuide/advtshoo.htm
If it's not making it to the Windows splash screen then this should lead you in the right direction.If you have decided to reinstall and are booting with the OS CD-Rom, but it's not booting you will need to adjust the boot order to include the CD-Rom in the BIOS.
Jul 17, 2008 | Dell OptiPlex GX260 PC Desktop
Dell Dimension 8300 PC Desktop Logo
205 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
