Question about Minn Kota Riptide St Saltwater 80 Bow Mount Trolling Motor
Will not run
Would work sometimes and then only on 7 speed now not at all. at first it appeared when you would twist the handle changing the speeds it would start working then only on speed 7 now not at all
    Problem Solver:
  • 6 Answers
Defective potentiometer if used. Some may use a photocell.
Posted on Nov 24, 2009
My bajaj discory 100cc bike not running in idle mode. it's getting off. but some times its work normally. sometime idle speed is auto changing
Hi, Anonymous and the usual suspects are:
1. Idle speed improperly adjusted.
2. Inlet system air leak.
3. Leaking accelerator pump.
4. Loose low-speed jet.
5. Plugged low-speed jet.
6. Contaminated or plugged low-speed circuit.
7. Enrichner valve is not seated or leaking.
For more information about your issue please visit the websites below. Good luck and have nice a day.
How to rebuild your Chinese scooter carburetor
How to diagnose carburetor vacuum leaks on your motorcycle
DOWNLOAD BAJAJ CT 100 SERVICE MANUAL
http://www.marutibajaj.com/pdf/ct100.pdf
Bajaj Auto Ct 100 2015 User Manual
Apr 07, 2014 | Bajaj Motorcycles
I have a 2005 Yamaha ttr 90 for my son. I cleaned the jets. Then itwould not idle so I adjusted the Idle on the handle bars. Now it hesitates when I twist the throttle. And before I adjusted the throttle...
2. Air fuel mixture screws not properly adjusted.
3. Inlet system air leak.
4. Leaking accelerator pump.
5. Loose low-speed jet.
6. Plugged low-speed jet.
7. Contaminated or plugged low-speed circuit.
8. Enrichner valve/choke not seated or leaking.
9. Multi carburetors out of sync and need to be balanced.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
2002 ttr90 won idle
TTR90 Carb Fix
YAMAHA TTR90 Owner Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-tt-owners-manuals
Oct 29, 2013 | 2005 Yamaha TTR 90 E
My perodua myvi,suddenly appear od/off.My car cannot change gear like normal and only running at low speed.My perodua myvi is Auto trans. After change the speed sensor and timing belt, the issues still...
Problem: My perodua myvi,suddenly appear od/off.My car cannot change gear like normal and only running at low speed.My perodua myvi is Auto trans. After change the speed sensor and timing belt, the issues still same.
Solution:
I had a similar problem in my Lexus and a friends Mercedes. It turned out to be a button on the console that locked the gear. Just turned button to off.
Why not ask your deales Parts counter what part you would need to fix it yourself.. He might tell you.
Sometimes I type the problem on YouTube and discover that others have had the same problem and that they post a video on how to fix it
Hope that helps you..
cmilton
Oct 28, 2013 | Cars & Trucks
Mixer works fine with speeds up to 6, but changing to 8-10, speed stays the same.
Sometimes can be caused by running too fast on the lower speeds. Should be 13 to 15 revolutions in 15 seconds on speed 1 then a slight increase only on speed 2.
Aug 01, 2013 | KitchenAid K5SS Heavy Duty Commercial...
Yardman mower wont run in lower speeds how to adjust
the pulley in the center the one that the belt from the engine and the other to the rear axle needs to slide the pulley changes where the belt rides in turn changes the speed most times the pulley can be removed and cleaned and reused
May 21, 2012 | Garden
When i turn on its taking time to get my disk that is my proplem
the best way is to upgrade ur PC , or format your harddisk or apply this settings as follows ===
Speed Up Windows 7 Boot Up Time Don't Try This To Make Windows 7 Faster:
Try ReadyBoost:
  • 1. Speed Up Windows 7 Using ReadyBoost
  • 2. Check ReadyBoost
  • 3. Speed test your SD Card, CF Card, Flash Drive, HDD
Speed Up Windows 7 BootUpdate 04/21: This tweak does not seem to have great effects on your boot time. Instead use a startup programs manager for Windows 7 and remove as many startup programs as you possibly can.
Do you have a dual-core or quad-core processor? Great, let's lower the boot time of Windows 7:
1. Click on Start, enter "msconfig" into the search field
2. Open the "boot" tab
3. Click on Advanced
4. Check "Number of proccessors" and select "2′ or "4′ from the dropdown menu. (obviously, you can only select it if you have a dual-core/quad-core).
Full Image
Speed up Windows 7: Change Taskbar Thumbnail Preview Time1. Click on Start, enter "regedit" into the search field.
2. Goto: HKEY_CURRENT_USER\Control Panel\Mouse
Speed Up Windows 7 Taskbar Thumbnail Preview
3. Double-click on "MouseHoverTime" and change the value to 100 or lower:
Change the mouse hover time to 100 or lower
4. Voilà, your thumbnail previews should appear a lot faster now. For another great tweak to speed up the Windows 7 taskbar, click here.
Speed Up Windows 7 Shutdown Time1. Open the registry editor (enter regedit into search field)
2. Go to "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control"
3. Lower the value (12000 is the default value = 12 seconds) to a value of your choice
Speed Up Application Access - Increase your productivityFirst of all create a folder "QuickStart" somewhere on your PC. Right-click on your taskbar:
toolbar.jpgLocate the folder "QuickStart" (you just created the folder so yo should know where it is) and then click "Ok". You are almost done, but we don't want that ugly text on our taskbar that is using a lot of space, turn it off:
texttitle.jpgRight-click on the new toolbar and uncheck "Show Text" and "Show Title"! Now drag the toolbar to the left until it's below the main icons and you will have something like this:
Sep 01, 2011 | Acer Computers & Internet
Speedometer reading 7 mph to fast
have you recently changed wheels or tire size? that is a definite change to speed. it changes everything about speed,stopping distance,control of car,handling conditions,when you go up to 18in or 20in 22in 24in rims or tires it changes the whole handling of the car. maybe you bought it that way,look at tire size,your car should come from factory with 15inch rims and tires max. any changes to that increases the speed.thank you for choosing fixya.com
Dec 31, 2010 | 1996 Chevrolet Caprice Classic
Why won't my vision fitness simple T9500 run? I tried holding down the stop button for 3 seconds. It did clear the screen. Then when I hit start it puts 6000 in the screen and will not run. It beeps as if...
With the safety key in place, press and hold “ELEVATION UP” and “SPEED DOWN” for 5 seconds. The software version will appear in display window shortly before model number appears. Press “ENTER” to accept correct model number IF YOU CANNOT GET INTO CALIBRATION EITHER UPPER CONSOLE ELECTRONICS OR OVERLAY CONSOLE ASSEMBLY HAS FAILED.
• Press “STOP” to enter “ENG1”. Press “ENTER”. PLEASE NOTE: HR Window = “0” for miles, “1” for kilometers, treadmill will calibrate in kilometers if set for kilometers. STEP 2 MINIMUM SPEED • Press “ELEVATION DOWN” button, “P0” will appear in display. • Press “START” button, the running belt will begin to move at minimum speed. • The display window should read approximately “.49 - .51”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “.49 - .51”. Press and hold “ENTER” to save changes. Press “STOP” to return to “P0”. STEP 3 1/4 SPEED • Press “ELEVATION UP” button, “SP1” will appear in display. • Press “START” button, the belt will move 1/4 speed. • The display should read approximately “2.71 - 2.73”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “2.71 - 2.73”. Press and hold “ENTER” to save changes. Press “STOP” to return to “SP1”. STEP 4 1/2 SPEED • Press “ELEVATION UP” button, “P1” will appear in display. • Press “START” button, the belt will move at 1/2 speed. • The display should read approximately “6.72 - 6.73”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “6.72 - 6.73”. Press and hold “ENTER” to save changes. Press “STOP” to return to “P1”. STEP 5 3/4 SPEED • Press “ELEVATION UP” button, “SP2” will appear in display. • Press “START” button, the belt will move at 3/4 speed. • The display should read approximately “9.41 - 9.43”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “9.41 - 9.43”. Press and hold “ENTER” to save changes. Press “STOP” to return to “SP2”.
STEP 6 MAXIMUM SPEED • Press “ELEVATION UP” button, “P2” will appear in display. • Press “START” button, the belt will move at maximum speed. • The display should read approximately “12.10 - 12.12”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “12.10 - 12.12”. Press and hold “ENTER” to save changes. Press “STOP” to return to “P2”. STEP 7 MINIMUM ELEVATION • Press “ELEVATION UP” button twice, “P4” will appear in display. • The display should ready approximately “190 - 205”. • To adjust, press “ENTER” for value which should read “190 - 205”. Use “SPEED UP” or “SPEED DOWN” buttons. Press and hold “ENTER” to save changes. Press “STOP” to return to “P4”. STEP 8 MAXIMUM ELEVATION • Press “ELEVATION UP” button, “P5” will appear in display. • The display should read approximately “750 - 765”. • To adjust, press “ENTER” for value which should read “750 - 765”. Use “SPEED UP” or “SPEED DOWN” buttons. Press and hold “ENTER” to save changes. Press “STOP” to return to “P5”. REMOVE SAFETY KEY TO EXIT ENGINEERING MODE REPLACE SAFETY KEY AND PRESS START TO TEST TREADMILL
Jun 14, 2010 | Dmm Vision Fitness T9500 Treadmill
2000 Pontiac Grand Prix interior fan speeds 1-4 not working
Check the ground, the resistors are accully resisnting the Negitive Current.
Jul 28, 2008 | 2002 Pontiac Grand Prix
Minn Kota Riptide St Saltwater 80 Bow Mount Trolling Motor Logo
195 people viewed this question
Top Minn Kota Boating Experts
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Colin Stickland
Colin Stickland
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
