Question about Car Audio & Video
Kicker 8 inch 4 ohm subwoofer 200 watts rms?
How many watts in an amp do i need to properly play this subwoofer?
    Problem Solver:
  • 10 Answers
Max 200 W. You could bridge 2 channels of a 4 channel amp (or get a 2 ch amp and bridge it) and connect the sub. Bridging = connect + of sub to + of one channel, and connect - of sub to - of *other* channel. Check amp manual for instructions.
Don't get a mono - most are 300W or more - might burn the coil during loud passages.
Posted on Jun 22, 2009
I have a kicker 10 comp d dvc 4 ohm 600 watt. How do I run a obcon 2000i 2 channel amp to it
You can't. Total mismatch of power and impedance.
You need a mono amp that can push the RMS watts of the sub @ 2 ohm (sub wired parallel).
More info here - http://sparky3489.webs.com/
Jan 22, 2015 | Kicker Car Audio & Video
I have 2 15" dvc 4 ohm kickers 1000 watt / 500 rms &a1000 watt avionixx 4 channel amp what would be the right wiring scheme?
need to know the ohms on the amplifiers then might can tell you best solution for system
Mar 05, 2013 | Car Audio & Video
I have 2 12
To be on the safe side without further information I would hook the two subs up in series leaving you with an 8 ohm load.
Nov 12, 2012 | Kicker Solo-Baric L7 12'' Car Speaker
What kind of amp can adequately power P112 S8 subs
you shouldnt run it at 8 ohm it shows what ohms it can handle . to run it at 1 ohm you would need 2 subs to do this. and no i wouldnt run an 8 ohm sub on the amp.
Aug 23, 2012 | Rockford Fosgate Punch Stage P112 S8 Car...
What watt amp would be best for my 1100 watt 10 inch xplod?
I have a 1100 watt sony xplode the silver one 4 ohm rms 3 00 with a 3000 watt 400 rms pyle amp? 8 ohm
Sep 16, 2011 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Which will hit harded 2 ohm or 4 ohm
In general, the 2 ohm speaker will be louder than the 4 ohm with most amplifiers. For example with this amp being sold at Best Buy you have 400 watts rms at 4 ohms or 600 watt rms at 2 ohms. However, being the same model sub they should 'hit' the same.
Hope this helps
Ray
Mar 30, 2011 | Kicker CVR15-2 Car Subwoofer
What size amp do i need to run 4 1000 watt pyle 10's bridged
well first of all you cant bridge subs... you can bridge an amp... and for 2 they are probablly not 1000 watts, make sure you understand RMS and what the sub can ACTUALLY HANDLE properly... i would get a 1000 to 1500 watt RMS that is RMS RMS RMS RMS amp not one that says 2000 watts MAX POWER cuz thats cheap ****... get a kicker JL hifonic alpine or something in that category that actually tells you the TRUE power output of the amp... then run those 4 subs in a parallel circuit so its like really only having 2 subs. make sure then these subs do not run less then 2 ohms at the terminals while in a parallel, then bridge these subs acting as 2 subs not 4 to your TRUE 1000 watt amp and you should have a good powerful system
Mar 19, 2010 | Pyle 10'' Subwoofer Tube w/Amplifier Car...
SHOULD I GO AHEAD AND BUY A 400 WATT AMP?
All amps aren't created equal. More exspense amps put out "cleaner" power. You need to know what the RMS power rating is for the amp at 8 ohms and 4 ohms. Also, is the speaker an 8 or 4 ohm speaker? How you wire a speaker or speakers (series or paralell) can change the ohms (resistence) which will change the power put out of the amp. Also, I'm assuming you are setting it up in mono?
Jun 22, 2009 | Pyle 2 Channel 4000 Watt High Power MOSFET...
Price check
that is 2 12 hitting 150 db you got to know what you are doing
Sep 14, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Sub+amp configuration
With a single 4-ohm subwoofer, usually the best choice is a 2-channel amp that can be bridged to a single channel. In your case, the sub is rated for 1000 watts. Not many amps are rated for that kind of continuous power into a 4-ohm load. Kicker doesn't list a minimum power rating, which isn't unusual in subwoofer specs. Depending on your budget, I'd look for an amp rated for 300-500 watts minimum; the higher, the better, up to 1000 watts. Most amps will have several power ratings, based on the load impedance and number of channels driven. A typical 2-channel amp might be rated like this: 150 watts x 2 channels at 4 ohms 300 watts x 2 channels at 2 ohms 500 watts x 1 channel at 4 ohms. The power rating you'll want to look at will be the 1-channel, 4-ohm rating. You can look at mono amps, too, but in the power ranges you're looking for, a 2-channel amp will probably give you the best value. However, if you can find a mono amp with a high enough 4-ohm power rating, it would run cooler and might last longer than a 2-channel amp with comparable power. When looking at mono amps, you'll find their highest power output will be at 2 ohms or 1 ohm; make sure you're checking the 4-ohm rating when making comparisons. Some amplifiers that might work well for you: Kicker SX900.2 Kicker ZX850.2 Alpine PDX-1.1000 Rockford T600-2 Hifonics ZXi 1006 Premier PRS-D2100T Power Acoustik OV2-2200
Jul 05, 2007 | Kicker C12-4 Car Subwoofer
Car Audio & Video Logo
212 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
