Question about Ergotech ET-HD1021 MP3 Player
Proview lcd monitor has permanent white screen
I recently aquired a proview lcd monitor product# pl226afw Model #: 2200w from a friend and it work for a bit, Then the screen went white all of a sudden. Sometimes when i turn it on u can see some lines but thats it.Even when I press menu nothing happen . Whats wrong with it and is there a way to fix it.
I had this exact same problem with the 2200W. I was afraid it was the logic board but that wasn't the case.
I replaced all of the capacitors on the power supply board and now it works perfectly. At first I only replaced the bulging capacitors but that didn't fix it. Most of the bulging caps were the 680's and 470's. It ended up being a 220 (which didn't even look bad) closest to the cluster of 680's.
Save yourself some time and replace ALL of the caps. I used this image from a post on this site as my guide: http://www.ccl-la.com/pl926.jpg
Posted on Sep 19, 2009
Testimonial: "Hey gerren_k i have some time off and i want to see if i can fix the proview 2200w monitor. I was wodering if u could give me some omre advice ,may by dicribing the process and maybe a picture of what ui have to replace. I would really appriciatre it as i cant afford to get a new one. I'm still in college so moneys tight, i would really appriciate it."
Solution #1 works! I just got my board back (paid someone else to change the caps), put it back together this evening and it WORKS! So, ignore Solution #2. Solution #1 with replacing the capacitors does the job, and costs less than replacing your monitor!
Thank you so much garren_K!!
Posted on Jan 30, 2010
    Problem Solver:
  • 10 Answers
Get a new monitor. This one is dead (the logic board is kaput).
Posted on Jun 22, 2009
Model 2200W Proview LCD Monitor - How do I connect it to HP Laptop?
Since you don't provide the laptop model, I assume your PC has at least a 15 Pin VGA connector. You will need a 15 pin male VGA to 15 pin male VGA cable, just plug it at the laptop and the monitor, that should do. If your laptop has also an HDMI or DVI or Display Port, you will need a proper cable or adapter.
Jul 30, 2014 | Proview Computers & Internet
Product NO. PL916s Model NO. 900P I have a Proview monitor, which has always worked wonderfully. Recently my computer broke down and I'm using another computer with a small screen. I have misplaced...
Product NO. PL916s Model NO? This trouble maybe power supply or inverter boards is defective. first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
AI 0088 Proview 860 ALZ M713W Power Supply for PL916S
Jul 21, 2011 | Proview PL916S2 Monitor
My moniter has a black screen and is blicking blue light. i have a proview model 2200w? Was working fine until i shut down yesterday. I unpluged, nothing happened. Could it be in a sleep mode? If so, how...
this is so common in lcd monitors, its the power suply board.... most likely a capacitor.. so type a model# into google following the words "power suply" it will probably be close to $50-$60... thats better than buying a new one
hope this helps you
Feb 06, 2011 | Proview PL576Ws 15.4" Widescreen LCD...
I have a proview 22 inch monitor model 2200w it will not come on
Check power supply DC filter caps first.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Aug 22, 2010 | Proview PL713S 17" Flat Panel LCD Monitor
Where does it go? what does it look like.
heres the proview site http://www.proview.com/Product/Product_Sub-category.aspx?ii=212
I suspect it uses a kettle type plug - that looks like this https://www.cashgenerator.co.uk/_images/product-details/BE991.jpg and the connector looks like this http://acimg.auctivacommerce.com/imgdata/0/1/2/8/8/9/webimg/1310841_t.jpg See what you have on the back of the monitor - if it does look like that connector - those cables are avaibable at most store - what country are you in ?
Apr 15, 2010 | Proview PL713S 17" Flat Panel LCD Monitor
Proview 15" screen turns white
probably failure in the LCD controller IC in the lcd controller board. that no signal was sent out to the lcd driver ic thus you could only see white display. A replacement of LCD panel is the best solution. I suggest to bring it to an authorized service center. best regards
May 22, 2009 | Proview PL916S2 Monitor
LCD display Proview
If the screen is pinkish chances are the panel is defective.Should follow-up with Company Proview and do some correspondence.
Samir
May 23, 2008 | Proview PL926WBi 19" LCD Monitor
1,016 people viewed this question
Top Ergotech Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Ergotech Audio Player and Recorder Expert? Answer questions, earn points and help others
