Same Problem - Sony Trinitron picture dies out
I have a Sony Trinitron, cant remember what year (90's). Sound is working, but the picture fails in two ways: either it doesn't come on at all when the standby lamp flashes continuously, or when it does come on, horizontal lines begin to distort the images as the picture decreases in width and height gradually towards a single straight white line across the middle of the screen. At this point the screen goes blank (as if it was off).
I am still looking for an answer but I thought I'd drop this in: if it's on its last legs and you aren't keeping the thing anyway, I hit it over the top with a hammer fist of varying strengths when the picture begins its series of steps toward failure. Usually, the vibrations from the TV being smacked realign whatever connection is loose and can reset itself to normal. Be quick though! This only works if you notice the picture dying out as I described. Once it goes to the blank screen, you have to turn it off (give it a smack) and start again. Ive been taking my chances with the thing for about 6 months now, and its still working.
Also I noticed: once the TV's warmed up from use it usually stays on without failing. It takes more effort to turn it on in the morning when it hasnt been used all night. Once you get'er goin, she'll hold for a reasonable amount of time.
  • 668 Answers
You are probably dealing with loose solder connections in the horizontal and vertical deflection circuits. I am surprised it hasn't failed in a massive way yet. Too many times that is the way it ends unless those solder connections are taken care of.
Hope this helps,
Skyassoc
Posted on Jun 22, 2009
I have a sony kv-27fs100 when i try to power it on it blinks 14 times after that its just 5 times over and over again what is a fix for this and if someone has a list of the placement of the componets on...
Sony Televisions have indicators like blinking lights to give you a clue what parts have failed.
In your case it could be the worst your picture tube.
Do you remember how it normally would start (blinks) and if it was lacking ant color in the picture or if it just wasn't really clear any more?
10 years was a good life without any service.
Oct 18, 2010 | Sony FD Trinitron WEGA KV-27FS100 27" TV
My sony trinitron kv-32v65 has no picture - standby light blinking - sound works through the bose sysytem, just no picture - help
if you cant repair a tv take it ot a w/shop and have it checked. let your tech check that an ht voltage of 95-105 is reaching a line transistor, also a transistor be checked for leaks, also let him check a line transformer, and the surrounding tin capacitors for leakages and change of values.
Mar 11, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony HDTV
check the line transistor near the line transformer
and make sure that 90-115 volts is reaching a transformer.
Feb 22, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Have sony 36 trinitron about 5 years or older..the picture just shakes. never lose the picture or the sound. just cant get it to stop shaking.
U have magnatic degausing coil problem.Take the tv aparts,there a solid back coil all around inside the front frame of ur tv.That the cause,unplug that coil,should not effect the tv pic if have no magnatics problems.
Feb 22, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Know picture on screen but sound
check the line power transistor near the line transformer
make sure that a 90-115 volts is reaching a transformer, oscillation is not there.
Feb 20, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony trinitron kv-36fv26 (2000) tv wont show picture
Trires unplug,replug about an hour later see if it reset it self.Not take to the shop the two power ICs help the power it dead.Need it replaced.
Jan 27, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Sony Trinitron
Take it to an authorised repair agent. Sonys can be very complicated for both amateur and professional alike. I have spent hours on some of them.Most probably a failed voltage regulator though very common for Sonys and expensive.
Oct 08, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron - Picture Disappears
Hi, IK circuit is engaging which basically means the picture tube is getting tired, the only "fix" is temporary (may get another year out of it). You have to increase the "screen control clockwise".
Remove back of set, follow large black or red wire attatched to picture tube down to the flyback transformer, mounted on flyback are two black controls, one is focus (leave it alone) the other is "screen", adjust it clockwise approx. 1/4 inch, remember that this is a high voltage circuit so use one hand in the set the other hand out of the set at all times,any questions ? e-mail me back, good luck, BMW Rider
Feb 27, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony CRT TV stops working
No, this set is well known for BAD picture tube Bad Flyback Transfomers I myself really cant tell you how many of these sets i have throwed away. first the FBT goes bad then you put a new one in then you find out it was the picture tube that was defective to begin with, save some buy you a new set! ThankYou for using FixYa. Have a Nice Day.
Feb 09, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron 32" TV will not come on and stand-by light blinks
It cant hurt to try...
While I was reading some other post about this problem, one guy said to try using a hairdryer on the right side of the TV1.gif for a few minutes to dry out humidity, becuse the trinitron has some kind of feature that causes it to 'protect itself' when too much humidity is in the air.
Hmmmmm sounded silly, but we had nothing to lose and tried it.
Lo and behold, our TV is back on.
Dec 31, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Televison & Video Logo
318 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
