Question about Philips Magnavox MWR10D6 DVD Recorder
Can't record to DVD with Uverse DVR after the digital switch over. I was able to do it before the switchover, even using the DVRs HD channels. Now the DVD recorder says cannot record in the +VR mode. Strangely though I can record live to DVD for short times, then it just stops during the recording for no known reason and will not restart. Also this only on regular Standard definition channels. Thanks, Doug
SOURCE: Philips Magnavox MWR10D6 DVD Recorder Cannot record in +VR mode
check to see if the U-verse box is in HD mode. If it is, change it to standard definition and the problem should be solved.
Menu -> Options -> System Settings -> Aspect Ratio
Posted on Sep 29, 2008
skotkolr
  • 558 Answers
SOURCE: how to set up my magnavox dvd player / recorder
http://safemanuals.com/user-guide-instructions-owner-manual/FUNAI/MWR10D6
Posted on Dec 13, 2008
  • 909 Answers
SOURCE: have magnavox dvd recorder record direcTV DVR programs w/ hdtv
I am unfamiliar with this unit.
If you have scart connecters on both, connect av2 on the tv to av in on the recorder. set the recorder to record from av source.
You should now record a program, I think the static is the fact that composite is out from the dvd only, not an input, and in on the tv, not an output.
Posted on Sep 04, 2009
Testimonial: "though unfamiliar with unit, pob-h tried to help solve my problem! that's more than i can say about my own husband! thanks for trying!"
SOURCE: Funai VCR/DVD recorder DVR 2737. My -R discs
I was advised to try another make of blank discs. I bought Sony discs & they worked ok. I had been using supermarket own brand.
Posted on Oct 18, 2009
  • 6 Answers
SOURCE: I Have a Magnavox MWR10D6 DVD Recorder
VR mode or Video Recording mode is a feature on stand-alone consumer and computer DVD recorders that allows video recording and editing on a DVD rewritable disc.
In VR mode, users can create and rename titles for the scenes. Also, if a scene is deleted, the space allocated by it will be utilized later without the need of reformatting a disc.
If the user would like to record on the same disc again at a later time, in VR mode, users may eject the disc and it will not be finalized by the recorder until it is manually initiated. For the sake of comparison, any DVD disc recorded in VR's competitor V mode (or Video mode) will be automatically finalized before it is ejected by the recorder. Disc finalization is still required if the disc formatted for VR mode will be played in another DVD player.
Currently, users can only record in VR mode with the use of DVD-RW, DVD-RAM and DVD+RW discs, (updated in 2000 to accommodate DVD-R (General)) [DVD players marked “RW compatible” and “DVD Multi” can play DVD-VR recorded discs] and on some recorders, also on hard-disk drives.
Posted on Nov 12, 2009
Audio issues uverse
is this a wireless receiver you're watching the DVR though or straight from the DVR unit? If wireless--it could be your network... if you have other boxes that work fine.. its a box issue... call AT&T.
Nov 28, 2013 | AT&T UVerse
Hdd recorder not working following switchover
Try a factory reset , should be in the onscreen menu under setup or something likewise .
Oct 03, 2012 | Sagem Televison & Video
Can't record with dvd recorder from hd digital cable box
Hello, Ciprian -
Your television service provider (cable or satellite dish) provider may not allow DVRs which the company does not provide. We have AT&T Uverse as our cable TV provider and must use the DVR the company provides (and charges for.)
Have you checked the policies of your TV service provider regarding the use of DVRs not provided by the service company?
Dec 21, 2017 | Philips DVDR75 DVD Recorder
I have a Philips DVDR 3575H. using Comcast's
Try this set up-
Use an RCA audio/video cable for this set up (Yellow/Red/White).
Connect from the Video out (Yellow) connection on the back of the cable box to the Video in on the back of the DVR.
Connect the audio (Red/White) cables from audio out connection on the back of the cable box to the "Audio in" on the back of the DVR.
This should still get you a decent picture but not a true HD picture for your recordings.
When you set the timer to record set it to record either E1 or E2 depending on which input you connected the cable box to and ensure that the cable box is tuned to the channel you wish to record.
*** NOTE: If you keep the HDMI cable connected as you have for the cable box and watch normal TV through the HDMI input on the TV you will get HD programming for your general viewing but still have the option to record with the DVR at a lower quality. ***
Good Luck and please rate this solution....
Jan 07, 2010 | Philips DVDR3575H/37
Won't record in HD. DVR shows to be recording, but when you click on the programmed HD channel (the one that's supposedly recording) it's blank and says "searching for satellite". Just started recently.
Have you tried rebooting the DVR and removing the card that came with the DVR if its one that was provided to by one of the satellite company's such as Directv or Dish.
Nov 30, 2009 | Directv HR22 500-Hours HD DVR
My Pioneer DVR-320-S tuner did not pick up the free-to air HD channels I can receive on my new HDTV. I am running the aerial through the DVD recorder to the TV. Can I run the aerial line into the TV and...
You might need a splitter (about 3 bucks at walmart) attach the Antenna to the side of the splitter with only one connection. Connect an RF cable to each of the remaining 2 connections. Run one wire to the DVR and the other to the TV. You can then watch one channel, and record on the other at the same time. You might not be able to record in HD if the recorder is not an HD recorder. Regular DVD recorders only record up to 500 lines, HD is rated at 720 or 1080 lines
Jun 02, 2017 | Pioneer DVR-320S DVD Recorder
Loss of VCR Channels due to Digital Switchover
Comcast is full of it.
If you have a cable box, plug the box directly into the cable feed, then place the VCR inline between the cable and the TV. Leave the VCR on Channel 3 or 4 and use the box to select the channel. You could also use the video and audio out lines from the box and run them to the VCR.
Jun 18, 2009 | Zenith VCS442 VHS VCR
Verizon DVR HD Cable Box
Press the red button tha has a text of REC
Jul 13, 2008 | Televison & Video
How to connect DVR 1600 to LCD HD TV or ATT uverse recorder
has to be scarts, your reciver (sky, cable ect ect) to your dvd recorder, from that to the tv, all scarts, might help, regards mark
Feb 01, 2008 | Cyberhome DVR 1600 DVD Recorder
Philips Magnavox MWR10D6 DVD Recorder Logo
359 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
