Question about Oreck Cordless Speed JP8100CA Iron
No steam when ironing and no burst steam
When I iron I get no steam or burst steam
  • Anonymous Jan 05, 2008
    I plugged my iron in, all lights came on, and it even shut off automatically, but it won't heat up. The lights are on, but on one is home. Any answers out there would be appreciated.
  • bDrakeEnt Jan 27, 2009
    My Oreck Iron heats up OK, but I no longer get a burst of steam when I push the button, only water pours out of the holes and it's usually brown and stains my clothing. I've already sent one iron back to Oreck for doing the same thing.  How can I fix this problem?
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 19 Answers
Bad connection to heating coil. Not worth fixing.
Posted on Feb 22, 2008
I got this iron for christmas, it shot steam 2 times and thats all. I had it set on cotton, linen. I used reg bottled water, should i use tap and why no shots of steam.
take it back for a warranty exchange after you check that the thermostat setting is on steam
distilled water is recommended for irons
bottled water ( filtered water) and tap water is the same product and will have minerals and contaminates that affect irons
Jan 02, 2016 | Oliso TG-1100 Continuous & Burst of Steam...
How to clean inside of iron
Please don't take Landsend advice, as it contadicts this whole "fixya" site! Let's keep it going by not giving in to this throw away world! Some people can't afford a $20 iron @ Wally's!
All the solutions above (besides Landsend) are on it!! Your City water is still too, hard for these delicate, devices. Filtered, as Alan Serna mentioned, is the way to go!! Dump your water out of your iron, when not using-maintenance is key, for everything, even your families!! : ) Have a G8 day!
Sep 28, 2012 | Sunbeam 3017 Iron with Auto Shutoff
Frigidaire stack washer and dryer water pump air bursts
follow this steps and use the common sense. God bless you
f the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below). If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat (see the Appliance Controls Fix-It Guide).
If the iron does not spray properly, inspect and clean the nozzle (see below).
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water
Sep 25, 2012 | Frigidaire Stacking Kit for the Affinity...
DG 5030 steam generator-first time used and after...spits water
Common problem if you have the temperature or steam setting set too low (not enough heat/steam to vaporize water droplets or the unit is not up to full temp. I would have a clean towel alongside the iron to give a burst of steam prior to your first press...
May 29, 2010 | Rowenta DG-980 Iron
Stopped producing steam
Iron not heating up sufficiently to produce steam. Threw it out!
Jun 24, 2009 | Euro-Pro Shark GI490 Iron
Brown steam bursts coming out of my G1490 Shark iron
make sure you do a self clean as often as possible to remove debris and scale from iron
Jun 12, 2009 | Euro-Pro Shark GI490 Iron
Steam Question
Found the answer. The steam button is built into the handle. Push the button and you have steam.
Feb 27, 2008 | Steam Fast SP-660 Iron with Auto Shut-off
Burst of Steam
if no steam at all, there is most likely a small port where some particles have clogged...fill it with vinegar and water (50/50) and allow to soak 24 hrs, then reheat then shake vigorously to drain then rinse then retry
May 23, 2007 | Conair DPP4000 Iron
Oreck Cordless Speed JP8100CA Iron Logo
297 people viewed this question
Top Oreck Irons Experts
Kevin Getz
Kevin Getz
Are you an Oreck Iron Expert? Answer questions, earn points and help others
