Question about LG LRSC26925 Side by Side Refrigerator
Lg fridge lrsc 26925tt inop fridge lights-inop display
Looked like the power was off on this fridge first time this morning..first off noticed no lights inside fridge then found the display to be dark as well. verified breaker and voltage at receptacle. unplugged the unit and re-plugged it in and it did work fine for miutes or an hour or two at best .Did find inside freezer lights working at all times. when the unit resets and all is on ,compressor seems to run and sound fine and will keep temp with no problems. there are no diagnostic codes displayed or any abnormality noticed when the unit is on and running. suddenly unit goes off except freezer lights as if it lost power all together. It might come back on its own but seems to reset almost every time by removing and re-installing power cord to receptacle
  • 8 more comments
  • Jeff Barton
    Jeff Barton Jun 22, 2009
    fridge is totally inop except for freezer lights...no compressor no fridge lights no electronic display ....un-plugging fridge and re-plugging brings it al back.It might last for 5 seconds or 1 hr
  • Jeff Barton
    this ubit does not display any trouble codes such as FF .The ice maker was problematic from the word go and is not in use. The only thing that functions to this fridge while in this state is the freezer lights. As time goes along un-plugging and plugging the unit back in will bring everything back but will only run several seconds now.(yesterday it seemed to stay running considerably longer and now items in the fridge are warm)I do hear the compressor starting and it does appear to sound fine so far.This unit has been down long enough to be defrosted and I am removing rear panels to verify condenser fan operation.Ive assumed the whole time the thing could be popping off on high head temp and shutting down.would not be suprised to have failed circuit board as some of our other fine LG products has required these allready ...machine is under 3 yrs old.curious if any recalls or warranty could be in effect here.
  • Jeff Barton
    Jeff Barton Jun 23, 2009
    i did thorougly clean the condenser coils and compressor area and verified condenser fan operation .The fan looks like a toy ...prob ought to order that along with a very pricey main board or go down to the hvac store and put a real fan in it.
  • Jeff Barton
    Jeff Barton Jun 26, 2009
    compressor fan lights display work fine ....suddenly all goes out...unplug/plug back in ..all works fine for a few seconds
  • Jeff Barton
    was looking for more prolific diagnostic pertaining to this specific model.oredered service manual from LG
  • Jeff Barton
    Jeff Barton Jun 27, 2009
    stiil seeking solution
  • Jeff Barton
    new advise please
  • Jeff Barton
    still not working
  • Jeff Barton
    It was in fact the control board...330 bucks for the thing delivered.
  • Jeff Barton
    thanks for the answer...I had fixed it yesterday but was waiting for the right response instead of a bunch of mumbo jumbo like three phase power and refrigerator was outside...lol thanks
    President:
  • 744 Answers
You have a problem with the control board it sounds like...after while overheats and then shorts out and shuts down. pulling the cord resets it and the cycle begins again.
Posted on Jun 26, 2009
    Champion:
  • 220 Answers
Sounds like controller board faulty.charges power than discharges.
  • 296 Answers
well i my view u should take it to service center as it is 3 years old so it needs some maintenance and fridge generally has 5 years warranty so it would be advisable to go to service center.
Posted on Jun 23, 2009
  • 331 Answers
Jeff are you located in Vegas?
Posted on Jun 22, 2009
  • 10,515 Answers
Check the below mentioned points :-
  • Make sure the refrigerator is plugged in securely
  • Check for a blown fuse or tripped circuit breaker
How to check fuse :-
http://www.acmehowto.com/howto/homemaintenance/electrical/fusebox.php
How to reset circuit breaker :-
http://www.acmehowto.com/howto/homemaintenance/electrical/circuitbreakers.php
  • Test the power outlet for current
How to test outlet for current :-
http://www.acmehowto.com/howto/homemaintenance/electrical/voltage_test.php
  • Inspect the electrical cord for damage
How to check an electrical cord :-
http://www.acmehowto.com/howto/homemaintenance/electrical/corddamage.php
  • Eliminate use of an extension cord, if any is being used
  • Check the outlet damage
How to test outlet voltage :-
http://www.acmehowto.com/howto/homemaintenance/electrical/outletvoltage.php
I hope the above points would be more than enough to fix the issue.
Thanks for using "Fixya".
    President:
  • 1,952 Answers
More than likely the main control board has failed. It is located behind the metal panel, on the rear left of the unit. I know of NO way to actually check it. When you replace it, the new board must be programmed properly, or it will not work. :)
A test lead is a wire that allows you to directly connect the solenoid to 120V for testing purposes. The solenoid is located in the rear of the unit, near the compressor. I would suggest that you call for service, if you are having questions such as these. :)
, there are line voltage switches that will carry your 23 amps, a contactor is normally used, I will look for the switch.
Your hoist, is it single phase?, I am assuming both comp and hoist are. If so wire the hoist up like the compressor.
12/3 wire, I am assuming is two for power and one for safety ground?
Problem is I don't know how far your runs will be, and wire size is a function of many things, but the main two are current [amps] and DISTANCE for voltage drop calculations.
The wire size is easily resolved, go to where you buy the wire, take the amp data for both with you, tell them you need to run it X distance and they can figure it right there and then, plus whatever might be on sale.
They may have your in line switch too, which is a GREAT IDEA< breakers are horrible switches.
Slow down. A three phase motor that has three leads, can be any color or combination it makes no difference, they simply made one lead white to give a marker for rotation and reference, they are all the same.
You have a single phase supply taken off something to allow the pressure switch to trip the relay and start the motor.
You think it is 480. but it measures 240 to what L1 2 3?
Three phase is measured line to line to line, and it sounds like you have 240 if it measures that way from terminal to terminal.
The ground is simply frame or chassis usually a green wire, and has nothing to do with the operational circuit, only safety.
Look up some common compressor wiring diagrams for three phase, I think all you need is the three lines on the L terminals, and one should give an indication of which lead goes on one of the terminals.
In other words the white wire is designed for keeping you from running the motor backwards and destroying the compressor.
There should be something obvious somewhere that tells you where this white line goes, but make sure you know what direction it should run, and take no chances or you will crash the compressor.
Are you sure that the freezer is getting power? If you can't tell if anything is on at all, plug something else into the same outlet, such as a small lamp or hair dryer. If you have power, it's time to troubleshoot. If you don't have power, check the fuse or circuit breaker. If you do have power, does the interior light work, or do you hear a fan turning inside? You can try setting the thermostat to a colder setting. Does the compressor kick in? If that doesn't work, you can begin checking the same items that would cause the freezer to freeze poorly.
Your thermostat controls whether the compressor is running or not. When the thermostat senses the internal temperature is lower than the setting, it turns off. If the thermostat won't cycle off, the thermostat may be bad and you will have to replace it. You may also have the temperature set too high in the freezer. Try adjusting the thermostat to a lower temperature. If this turns the compressor off, you may have had it set too high. With the help of a freezer thermometer, you can find a more ideal setting that will keep your food cold, but not so cold that the compressor is always running. If raising the temperature setting doesn't help, it may be a problem with the thermostat and you will need to replace it.
If your thermostat is working properly, there's a chance that you have low levels of refrigerant in the sealed system. If this is where the symptoms lead you, you need to contact a professional appliance repair person. Only an EPA certified technician can legally work on a sealed system. If you attempt to do work on this system, you will void the warranty.
If this is a new refrigerator/freezer, it will run for a long time, almost constantly, before it gets cooled enough to stabilize the interior temperature. Allow up to 24 hours for it to stabilize.
Another common cause is a leaky gasket. Try putting a dollar bill between the gasket and the frame of the freezer as you close the door. If the dollar comes out without resistance, then you need a new door gasket.
When installing a refrigerator or freezer door gasket, you should allow the gasket to adjust to room temperature before removing it from the carton. When carrying or handling the gasket, you want to carry it by the corners. This will help to prevent breakage of the flexible magnet. Should the magnet be found to be broken, it will NOT impair its effectiveness. If the gasket is deformed or twisted from long storage, you can heat the deformed section with an electric heater, hair dryer, or a 150-300 watt light bulb. Holding the heat source about 1 inch to 3 or 4 inches from the gasket, move the heat source back and forth to maintain even warming. Apply heat until gasket has resumed its original shape. This can also correct an already installed, deformed gasket. Make sure you use caution so as not to damage the inner door panel.
Make sure that the freezer has enough air clearance on all sides. There is a condenser coil on the back or under the back near the compressor that needs to radiate heat away from itself. If it can't radiate enough heat, it will cool poorly and will run for longer periods of time.
Verify that the door light switch is working properly. Push the switch with your finger to verify the light is turning off. If the light stays on, it will actually warn the interior of the freezer. Fix or replace the switch if it is faulty.
Modern freezers start and stop very frequently to maintain an even temperature. They may run for a long time initially. This is especially true if you have just put a lot of warm food in the freezer, or if it is very hot and humid. It can take several hours to get back to the cool temperature you have it set for after putting a large amount of food in it.
  • 2 more comments
  • mohammed marika thambi
    mohammed marika thambi Jun 22, 2009
    the condensor fan motor is bad!! Pretty soon the compressor will be
    too! Take the back cover off and put a fan blowing on the compressor
    this will help until the fan is replaced!!!
    ER FF is a freezer fan error. Basically the mainboard is not receiving
    a feedback signal from the freezer fan motor within 65 seconds. When
    this happens the error code will come up and then none of the buttons
    will work.
    You can clear out the error code by unplugging and
    plugging the machine back in. The error code will come back if the
    problem persists. Check around the freezer fan motor fan blades to see
    if ice buildup is interfering with the operation. Clearing out this ice
    may fix the issue.
    If the problem comes back, then the fan motor may be getting ready to go out or the unit may not be defrosting properly.
    Regardless of the configuration of freezer location to
    fresh foods compartment, as a general rule when the compressor is
    running the evaporator fan (in freezer) and the condenser fan (near
    compressor) should also be running. If all OK, look for frost build up
    on freezer wall (usually the back wall) indicating a defrost problem
    (most often a defrost heater failure, but can be an electronic control
    board or other component) Check that the door gaskets are sealing. Is
    there an ice maker?
    www.fixya.com/support/p94926-lg_lrsc...side.../solutions
    The problem is most likely that it is on the porch and not that its not working properly.
    When
    its cold out a fridge does nt usually get enough run time to keep
    things frozen in the freezer,,,thats usually what I would get a call
    for. "It would be the freezer thawing".
    To test this and as a
    matter of fact to continue any diagnosis you must move the unit into a
    warmer room. I would recommend at least 58 to 60 degrees minumal.
    Oh
    and one thing I forgot to mention. The oil in the newer Refrigerators
    that have the R134 coolant tends to thicken when its cold and the
    compressor does nt run much.
    R12 refrigerators which had mineral oil would work totally differently out on a porch.
    When
    the r134 oil sits in the cold it tends to get waxy,,,not a big deal
    until the compressed freon makes its way to the tiny capillary tube,,
    at this point the freon flow could be halted by the waxy parts of the
    oil not flowing through that tube. In a room thats warm the oil remains
    oily and mixes with the liquid freon easily then makes its way to the
    capillary tube as a liquid,,,at this point in the system
    the liquid freon and oil mix is warm so it easily flows through the
    tiny orifice in the capillary tubing. At the other end of that tube
    that liquid sprays out into a much larger tube this is where the cold
    is created. Since the size of that tube is much larger the cold oil is
    not a problem, it can still freely flow back to the compressor which is
    quite warm and start the process all over again.
    I hope
    that explanation is easy to understand. So there are the reasons why
    the newer r134 refrigerators do nt do well outside and work differently
    than the older R12 models. To verify which you have find the plate on
    the refrigerator where your model and serial number is,,right on there
    it will say which freon is installed. It will be in the fridge part.
    The freezer is not defrosting itself, and frost is building up in the
    freezer (where all the cold is produced) this will block the airflow IN
    to the refrigerator section. The offending part is usually the
    "Adaptive Defrost Control Board"...you will need to totally defrost the
    freezer, at least 24 hours with the machine unplugged and both doors
    wide open, then replace the control board (located in the top of the
    refrigerator section) and usually available from your local appliance
    parts distributor.
    If the dispenser is lighting up but nothing is happening then
    either a door switch is bad or the main board which has relays on it
    may be bad, no real way to test this, other than to replace the parts.
    I would replace the main board with all the relays on it IN the
    dispenser, as it is the main control unit.
    You may find a schematic behind the refrigerator, a sticker on the
    back, or sometimes a folded up piece of paper hidden behind the
    kickplate, at the bottom front of the refrigerator.
    mohammed marika thambi Jun 26, 2009
    I found out that if I shut the system off and turn the PSU off (or
    unplug the system) whenI come to turn the system on again it will boot
    up fine first time. Obviously I have to turn the PSU on or plug it back
    it. So it would appear the PSU is being stupid LOL
    Someone mentioned that it sounds like the new Antec PSUs have a power
    disruption detection on the 12V line. Obviously I've never heard of
    this and wonder if there is any weight to this claim.
    Right now I am contemplating purchasing yet another PSU, I think this
    one will be an Enermax (just to be safe LOL). If it works the Antec
    will go in my upcoming system, if not
    came to power up about an hour ago and still got the same **** I've been getting for a while now.
    I could possibly try a different PSU, my brother says I can borrow his,
    but that's a no-name 400watt POS so there's no guarentees it would work
    even if the Vapochill were fine.
    keeps going on about the sensor and that
    there most likely is a problem there. He also said something about
    changing the voltage to the compressor won't help
    Run me down exactly what it does and which sensor we're talking
    about.... I haven't owned one personally but we 404'd Fliptones 404PE
    and played with that for nearly a year and had alsorts of probs so just
    need reminding of error codes etc etc...
    Tis sounding like powerdraw tho by the compressor...
  • 3,230 Answers
First, check to see if the light comes on or if there is any fan, motor, or other sound coming from the appliance? If so, the refrigerator isn't really completely stopped--go to the specific problem you are having. If not, try adjusting the thermostat to a colder setting. If that doesn't work, read on.
Second, check to see if there is power getting to the refrigerator. To do that, plug a lamp or other device into the same outlet the refrigerator is plugged into. If there's no power, check the fuses or circuit breakers. If the fuses or breakers aren't the problem, contact a qualified electrician to restore power to the outlet.
If there is power to the appliance but it still seems to be stopped, there may be a problem in one or more of these:
Wiring
Thermostat
Defrost timer
Compressor
Overload and/or relay
Good Luck!!
THanks
Water leak in fridge.
The most common cause is ice built up and plugged thedrain hole as non Auto defrost in time. Unplug the power de-ice. Locate the drain hole. Insert soft wire or cordto clear drain Open back of fridge. Locate drain tube and pan. And checkinserted wire or cord is coming out. Gently shake wires and pull out. That'sall. Now Drain tube is cleared. Once you defrost manually itself your problem would have solved automatically. Thanks, helpful?
Jan 27, 2011 | LG LRSC-26922 Side by Side Refrigerator
I have a LG refrigerator LRSC 26925TT and I need to replace the Ice Tray - How do I do this?
most ref have ice makers. but if yours does not the the ice tray can be pruchased from l g / they are there own dist and most part supply houses do not have there parts . however sear's is a good source / try there web sight and i think you can order it there . i works for me ... mm
Oct 10, 2010 | LG LSC26905TT Side by Side Refrigerator
We have a LG LRSC 26923 frig. It will make and dispense ice fine. We cannot get water to come through the dispenser. We had this problem a couple weeks ago and it looked like water had frozen up in the...
i believe there is a water filter in the fridge side as well as a storage tank. if the fridge is set too cold the tank or filter will freeze. causing blockage. Try setting fridge to 38 deg or higher for a couple of days. should melt blockage
Aug 26, 2009 | LG LRSC-26922 Side by Side Refrigerator
Describe your LG LRSC-26922 Side by Went to get ice this morning and noticed that the front panel was not lit. The lights go on inside but, there is no sound and the ice in the freezer is solid. When we...
PCB control fault. Don't keep perishables more than 6 hours. If the date on it is "best before" don't worry too much; if it's "use by" keep it refrigerated or use it today, even if you have to cook it and refrigerate it when fridge repaired.
May 03, 2017 | LG LRSC-26922 Side by Side Refrigerator
Removal of broken funnel assembly and installation of new one
You will need to remove the front display panel to get into the funnel frame.  Look at the bottom of the frame and you will see a little slot to slide a screwdriver in.  With your screwdriver, insert it into the hole and pry gently.  You will hear snaps and cracks as it comes apart.  It may sound like the plastic is breaking but that is normal.  Once you remove the display panel, you will see the frame and just replace it with the new one.
May 12, 2008 | LG LRSC-26922 Side by Side Refrigerator
Not getting water dispenser to work
Hold the button to allow the water fill all the lines and water tank.  It will take time but it should fill eventually.  If it doesn't, then have a qualified LG technician check the water valve.
Mar 08, 2008 | LG LRSC-26922 Side by Side Refrigerator
Where is this fuse located on the LG refrigerator is displaying a ER DH code error
Hi. You have an Error Defrost Heater. Its taking too long for the heater sensor to open the circuit during defrost. You normally replace the heater, heater sensor and circuit board(motherboard) located on the back of the refrigerator in this situation. Check your mollex plugs and make sure they are connected tightly at the evaporator coil area. Sometimes they come loose. I reccommend replacing the heater and heater sensor located top right on the evaporator coil. This should take care of the problem. Need parts see me on ebay as user, themackshack. Good luck, Mack
Jan 02, 2008 | LG LRBC22544 Bottom Freezer Refrigerator
Refirgerator goes to error freeze
Same happened to mine. Got an engineer to check it out and he said the motor was gone. He charged 80 euro for consultation and 170 for the part. Seriously doubt the part cost that much. However, in repairing the fridge when he was gone I noticed tha he had broken the covering over the light in freezer. Am having difficulty getting him back.
Apr 12, 2007 | LG LRSPC26930 Side by Side Refrigerator
LG LRSC26925 Side by Side Refrigerator Logo
341 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
