Question about Peg Perego John Deere Utility Tractor
Peg perego john deere powerpull tractor will not run
When my son drives it, it will stop.
After a short time or if he pushes it, it will start running
again. Then it will stop a few minutes later. Is this a
circuit breaker issue or is it a pedal accelerator switch
problem. Is there a way to tell before I start replacing
stuff.
  • 1,165 Answers
Could be the gears hold unit of gound and push pedal try to hold wheel if it stops gears are worn..best way to test it id say would be by pass switches 1 at a time let it run see if it does same thing if it dont theres your problem
Posted on Jun 22, 2009
Battery is full on my sons peg perego john deere but it wont run
did you verify the battery voltage with a multimeter, could have a bad charger that gives a green light making one think that the battery is fully charged, also check the fuse on the battery
Dec 14, 2015 | Peg Perego John Deere Turf Tractor
Ac works fine when fan is on low but fan cuts off after a couple of minutes on high
Bad fan motor. Multi-speed motors have a set of windings for each speed. Your high speed is bad so the only solution is to replace the complete motor. When motors are going bad they will over heat and kick out on the heat safety. As it cools back down it will start again for a short time again until it gets hot again.
Jul 12, 2015 | Coleman Dometic Duotherm Rv Air...
Car loses power for short time after normal running and cooling down for ten minutes
sounds to be symptomatic of a CTS (coolant temperature sensor). there are two, one is for the interior temp gauge, the other is for the ECU/PCM while both are basicalty the same part, often even the same P/N, they both do extremely different things.
Feb 24, 2014 | Ford Ka Cars & Trucks
2003 Jetta starts for a second and dies after turning off car after drivena few miles
have your alternator checked,it may not be working and is not charging your battery,thats why it dies so fast and won't start again.
Dec 18, 2013 | 2003 Volkswagen Jetta - Sedan, 1.8T -...
John deere tractor runs in 1st gear but in 2 gear it starts and stops, maybe a connection issue but not sure
if it only runs in first then the gears for 2nd gear are probably stripped or worn down
Aug 07, 2013 | Peg Perego John Deere Turf Tractor
Engine acts like it is out of gas keeps stalling i can turn it off for a few minutes will run for a mile or two then does it again
Vent valve has failed closed or cannister is clogged up. Have the evap system checked from the tank to the charcoal canister. If you need to drive to a mechanic, try driving with the gas cap loose.
Dec 16, 2017 | Hyundai Motor 1999 Elantra
I have a 1994 toyota camry and while driving the engine dies off,then after i stop a few minutes later it starts then i can drive off again
It does sound like fuel pressure is low or intermittent. Here are some check procedures p172 on
http://www.turboninjas.com/camry/eg1.pdf
Is the check engine light showing a trouble code on the instrument panel? That may pin the trouble down.
Apr 03, 2012 | 1994 Toyota Camry
Peg Perego John Deere Utility Tractor Logo
454 people viewed this question
Top Peg Perego Toys Experts
Adam Fjeld
Adam Fjeld
Gary
Gary
Marvin
Marvin
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
