Question about AMS Lutron S2-L Skylark Single Pole 300 watt Dual Slide-to-off Incandescent
Describe your AMS Lutron S2-L Skylark Single Pole 300 watt Dual Slide-to-off Incandescent Problem / Aloha Where can one find the little tabs that the kids seem to break off, darn kids... lol. thanx Jeff.
    President:
  • 704 Answers
These are typically available at most general hardware stores or the big box Lowe's and Home Depot stores. They are inexpensive and typically come in packs of 2 to 3 slider knobs per package.
If you don't have a local hardware or big box store near you, check your local phone directory for an electrical supply distributor, as they usually will carry them, if they are a Lutron dealer. Just call them and ask, if they don't have them, they can order them for you and you can purchase them over the counter, even if you don't have an account with them.
Hope you find this Very Helpful and best regards!
Posted on Sep 10, 2009
How do you reverse the fan with the Lutron S2-LFSQ dimmer? The actual fan does not have a switch on it?
Sorry, its not something you can do from the wall-control. Unless the fan had a an embedded/built-in control module, the fan manufacturer's rarely make the "reverse" setting available from the wall control.
Mar 02, 2011 | AMS Lutron S2-LFSQ Skylark Dual...
S2-LFSQ my switch has worked fine for years. Now when the light is on it flashes on and off over and over. The fan switch works fine. Any ideas?
The only obvious idea I can think of is that someone swapped the light bulbs out for a different kind (replaced an incandescent with a non-dimmable compact fluorescent).
If it isn't directly related to the light bulb, then I would call Lutron's tech support number to help them diagnose. They're at 1-800-523-9466 and are available 24/7.
Feb 15, 2011 | AMS Lutron S2-LFSQ Skylark Dual...
I have two black wires in box attached to regular light switch & want to know if I can install a Skylark S-603PG single pole dimmer switch which has one black , one red&white, red and green wires
This is single-pole -or- 3-way dimmer
Manual shows on following link:
http://www.lutron.com/TechnicalDocumentLibrary/0301107A.pdf
1) Manual says: The red/white wire is not used in a single-pole application. Twist a wire
nut over this wire for a single-pole application.
2) Green wire connects to bare ground wire. Or bare ground to bare ground.
3) Connect dimmer-red and dimmer-black to either insulated wire that came off of old switch
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on dimmer or any do-it-yourself project.
We are always less expensive than a service call.
Jan 14, 2011 | Lutron S-603PG Skylark Single Pole/3-Way...
Lutron skylark s-10p 1000w dimmer. why is one
This video from the Lutron site shows the Diva switch but it is the video for the Skylark single pole switch also. It makes no mention of one wire being a larger gauge and does not differentiate which wire connects to line power and which to load. I do not think the wire gauge makes any difference.
Aug 11, 2009 | Lutron 1000-Watt Incandescent Dimmer...
Trying to hook up a Lutron fan control and dimmer
The old switch is just a single pole switch. The new one is for fan speed control. You need to use a regular single pole switch like you had. Or you can use a single pole switch on the Lutron you bought if you can figure out which wires to use. Do you have a meter?
Jun 27, 2009 | AMS Lutron S2-LFSQ Skylark Dual...
I want to disconnect my lurton skylark dim light switch? I don't see a preset to disconnect
No you knead to replace the light switch with what you want. There is no reset button. Just a toggle at bottom to turn on or off or the slide.
Mar 30, 2009 | AMS Lutron SFSQ-LF Skylark Slide-to-Off...
Have a Lutron Skylark SF-10P need to wire to existing 3 wires
You have to have a special ballast on the light to dim fluorescent light fixtures. You also have to have a special dimmer.
Nov 28, 2008 | AMS Lutron SFSQ-LF Skylark Slide-to-Off...
AMS Lutron S2-L Skylark Single Pole 300 watt Dual Slide-to-off Incandescent Logo
77 people viewed this question
Top AMS Electrical Supplies Experts
Craig Butler
Craig Butler
Ottoniel
ashburton
Are you an AMS Electrical Supply Expert? Answer questions, earn points and help others
