Question about IBM ThinkPad R40 2722 Notebook
IBM R40 2681
My Hdrive crashed and had to replace it. Everthing reloaded just with Windows XP Pro disc. Everything seems to work OK except there is no hibernate any more. The function key and -Start/Turn off computer/hiberbate is ghosted. How can I restore this function?
  • 132 Answers
Re: IBM R40 2681
Here is a link to all the drivers and software you need to put back on your R40 laptop. The one you were asking about is a bit more than halfway down the page, listed under ACPI Power Management.
Posted on Nov 16, 2007
0 characters
3 Points
Restore IBM Thinkpad R500 Windows Vista to factory settings, erasing all passwords
You need a recovery disc for this operation. If you're any good with computers at all, and do not do this lightly, you can download dukes ban. Again this is not for novice pc users. This will literally and completely wipe your entire computer. Nothing will be recoverable and you will have to set everything. even the Hard Drive sizes. You will then need an OS disc like windows vista, windows 7, windows xp, etc and reload the entire OS back onto the hard drive.
Aug 05, 2013 | IBM ThinkPad R50e Notebook
I have an IBM T41 type 2378 Windows XP Professional. I have been using and external monitor as the screen does not work. A while back I wanted to reformat my C drive and installed a windows XP disk I...
I would try to start it up in safe mode. This can tell you whether it's a display (physical) issue, or a driver (software) issue. You can do this by hitting the F8 button as soon as you start the computer and it brings up a prompt. At the Advanced system prompt, choose "Safe Mode with Networking" and see if it works then. If it does, I would suggest you undo an changes in the drivers that you made before.
Apr 01, 2011 | IBM ThinkPad T41 Notebook
My system configuration has been lost. When I sign in I cannot even get to the XP screen, the machine locks up.
Boot into safe mode by tapping the F8 key, select the option "best last known start that worked" reboot. If no go you will have to boot with Windows CD in and select reload Windows WITHOUT FORMATTING, this will reload Win and save all files EXCEPT you will have to reload all programs.
Apr 30, 2010 | IBM ThinkPad T43 Notebook
I have a thinkpad t20 and a 570e, both with
The IBM Recovery Disk that comes with those laptops is set up for Windows 2000, not Windows XP Pro. The answer is No, you cannot use the IBM Recovery Disk for them, if you install Windows XP Pro.
However! You will have a recovery disk, because you will have the Full Installation disk for Each laptop. Windows XP Pro Full Installation Disk.
(Microsoft Users License states "One genuine copy of Windows per One computer" That means you need Two, genuine copies of Microsoft Windows XP Pro)
Sep 06, 2009 | IBM ThinkPad T20 2647 Notebook
I cannot load windows xp pro
Go to BIOS and disable "NATIVE SATA SUPPORT"
Mar 20, 2009 | HP PC Laptops
Hal.dll corrupt or missing
Does the Hard Drive have Windows on it? If not, install the Windows Me Floppy disk. Select Run With CD-ROM Support or RUN With Out CD-ROM Support. Any of the two. After it gets done loading. type the following. fdisk
It will ask you do you want to use extended Hard Drive use? Y/N
Press Y. Then you'll get a screen with 4 options. If Windows is on there type 4. And see what it says on your hard Drive.
If you wish to erase Windows and reinstall it, click 3. to delete the partition and it will ask to restart the computer.
Restart the computer and reload to the fidisk screen and press 1. and it Will install a partition "Not Windows" After the Partition is installed restart the Computer and remove the floppy. If it comes up saying No Operating System found. Then the Hard Drive is set to install Windows.
The cheapest Windows XP you can buy Is Home Edition for $99.98, witch some stores still sell, like BestBuy.
If you want to send the Laptop to me I can install Windows on it for you. I have Windows 95,98,ME,2000 Pro, XP Home, XP Pro and Vista Home Basic. Thats if you don't want to spend money on Windows. Just pay for shipping.
Dec 12, 2008 | IBM ThinkPad G40 2384 Notebook
Ibm thinkpad t20 wont load o/s
Try to check the memory of your laptop.
Oct 09, 2008 | IBM Thinkpad T20 Notebook
I can't re install windows XP Pro on my IBM T30 2366-86u
its oem, you either need IBMs restore cd for your particular laptop (model) or an xp pro (any service pack will do) OEM disk.
You can not get the OEM disk at best buy, circuit city target etc those are retail versions and will not work. or frys electronics are your best bet, but by buying it from them you are getting another copy of xp pro, just use the cd with the keycode on your laptop and then you can install xp pro on another pc using the code that came with the disk. MAKE SURE YOU ARE GETTING AN OEM VERSION AND NOT A RETAIL VERSION.
Some technical stuff:
 For the xp pro disk you MUST have the COA product key available, this is usually on the bottom of your laptop, for IBMs disk you just have to have an IBM WITH an IBM motherboard as without the motherboard it will not work. For example, the motherboard goes out and you replace it with a non ibm board it will only boot for 3-5 times, the ideaa is that this gives you time to get your documents off. This is per Microsoft agreement with ibm and all other Original equipment manufactures this include hp, dell etc.
sorry if this is too technical for you please let me know.
Oct 30, 2007 | IBM ThinkPad T30 2366 Notebook
IBM ThinkPad R40 2722 Notebook Logo
105 people viewed this question
Top IBM PC Laptops Experts
John mullen
 Mike M
Mike M
Level 1 Expert
Are you an IBM PC Laptop Expert? Answer questions, earn points and help others
