Question about Dell 2 Button Mouse 6u226
Left click on mouse pad doesn't work!!!
Everytime i left click on my Dell's mousepad it does what the right click is supposed to do when you click on that one. It's very annoying dealing with this problem. soif you see this, please help!
  • 35 Answers
I think u must have switched the primary and secondary buttons on ur mouse.i assume ur using windows.goto control panel-->mouse-->choose buttons tab-->u'll see a check box which sud read switch primary and secondary buttons.remove the check mark from here.sud solve ur issue...
Posted on Jun 22, 2009
Mousepad doesn't work
what does it say in device manager click on mousepad ,click on properties does it s device working ok . in control panel go to input devices /mouse and check if mouse pad is selected to use.
Jul 29, 2014 | Dell l Latitude 620 9300 9400 1...
Tapping on gateway nv 53 trackpad not working
This just happened on my HP2730P. I always used the click on the touchpad, plus used the right click button at the bottom. Yesterday it just decided to stop working and went haywier...it started doing the selecting and dragging while I was moving the mouse around and my left click stopped working. Obviously my enable tap click was already on cuz I used it all the time.
My solution was disabling the buttons under the "buttons" tab. Then my mousepad tap started working again, I regained function in the scrollbar on the mousepad again, and if I need to right click I can use the point stick buttons right above the pad.
OR
Does it start working when you reboot? If so, try changing the "Touchpad Sensitivity" option :)
Jan 24, 2012 | Computers & Internet
My mousepad is working but the cursor between left and right button doesn't work? I have a ACER Aspire 9300
1) Go to control panel (either with the help of keyboard or mouse)
2) Open Mouse
3) On Button Tab Select Button Configuration ( Switch Primary and Secondary Buttons)
4) Also Check your Touch Pad Driver Software
Thanking you
May 16, 2011 | Acer Aspire 9300 Notebook
Logitech mouse stopped working when using my right hand on the mousepad. Will work with my left hand on mousepad or anywhere else. Also will work with right hand if I move the mouse pad to another area. ...
you might have to uninstall the mouse then restart your computer then reinstall the mouse and its drivers
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot also you can select properties under driver you will have options to update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
hope this helps
Jan 17, 2011 | Computers & Internet
Both my keyboard mouse buttons act as right clicks
Hi
Access BIOS settings and search for mouse / peripheral settings, you may find one to activate left and right mobo clicks.
Cheers cbacer
Aug 12, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
My mousepad won't work on my Aspire laptop. Ok, the mouse pad works (the pointer will move around), the physical button right click works (not double clicking), but any click on the mousepad and the left...
Check for dirt under the keys. See if you can blow under key and turn the laptop on it's side while you're doing it so anything under it can fall away.
Jun 01, 2009 | Acer Aspire One PC Notebook
Right click not working
go into the mouse icon in the control panel and make sure its not disabled in there. If it is then enable it. If its not disabled in there then the board underneath your mousepad is bad. The right tactile button undernath the right mouse button is bad so the whole board would need to be replaced cause it comes as one whole board. You can get it directly from Dell or get one from Ebay.
May 17, 2009 | Dell Inspiron 1501 Notebook
Asus mousepad stopped working after windows vista update
1.) Try reloading the touch pad drivers, should be on the CD that came with it or check the Asus website for new ones.
2.) Have you accidently disabled it? There is a Fn key combination to do this. Try Fn+F9. Also, there is an option to automatically disable the mouse pad when a USB mouse is plugged in. And of course, you can disable it from the Device Manager.
3.) Try going into :: Control Panel, find "Mouse", select the "Device Settings" tab, select the touchpad and click the "Settings" button). Check the settings in the "Tapping" section.
Mar 16, 2009 | Computers & Internet
Dell latitude c610 touch pad left button problem
Will your laptop work properly with an external mouse? If so, check your touchpad settings in "Control Panel" by selecting "Mouse". Here you can reassign your Buttons. Try setting your Right Button function to "Double Click". If the "Double Click" function works on your Right Button then chances are you have a problem with your Touchpad Assembly which means it will have to be replaced. Dell refers to it as a "Palmrest" which they will replace if still under warranty.
Sep 20, 2008 | Dell Latitude C610 Notebook
Mouse pad is not working but usb mouse is!
Try pressing the FN+F7 buttons together.. This enables / disables the touchpad
Jan 17, 2008 | Acer Aspire 3000 Notebook
Dell 2 Button Mouse 6u226 Logo
769 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
