Question about Compaq Presario 700 470024-192 Notebook
I didnt have microphone hardware's software
So my lapto didnt finds any microphone attached to it
  • Compaq Master
  • 1,165 Answers
Buy a cheap mic at walmart.
Posted on Jun 22, 2009
Inbuilt Mic not working Medion MD96350
I Suggest that you scan your computer with RadarSync so that you will know which drivers are outdated since you have two possible problems here.
1. Hardware - sound card not attached to the computer properly.
2. Software - outdated driver
I suggest that you update the drivers so that you can cover the software side of it. If it won't get fixed, then you would need to contact a technician to get your computer serviced.
David
Apr 06, 2013 | Computers & Internet
No sound
Webcam Audio Getting sound to broadcast with streaming video using a webcam requires a few components to work in unison. Because most webcams do not have a microphone built in, you will need to buy a microphone for your computer or locate your microphone input if you have one built in (some laptops have these). The audio and video are two separate functions and must be diagnosed as such. b> Webcam Software b> If you have a webcam set up correctly and you are streaming video, then you are already halfway there. This details only how to make the sound work, so please refer to an article related to webcam video if you do not have that working already. The webcam audio and video both communicate with your computer via your webcam's software application. Due to this, you will find that there are settings specific to your webcam software for sound. Because there are various software applications that can act as an interface for your webcam, you will want to do a product-specific search on the Internet for your application's settings. Most often you will find the settings for sounds under Tools or Settings, then choosing Options or Preferences. Regardless of the application that you are using to broadcast your webcam video, you will need to ensure that your microphone is plugged into the "Microphone In" jack on your computer or laptop. The microphone input jack is commonly colored pink. b> Microphone Connection b> With your microphone plugged into the "Microphone In" audio jack, test the audio inside your webcam's software application. Most webcam applications allow you test your microphone by reading a sentence and watching a graph move as you speak. If you see this happening, then you have correctly hooked up your microphone. If you have a Windows PC you should also see if your computer recognizes your microphone by clicking on "Start" > "Settings" > "Control Panel" > "Sounds and Audio Devices." Under the "Audio" tab you will find a section for "Sound Recording." From there you can select or change your "Default Device." b> Hardware Troubleshooting b> In the event that your microphone is not recognized by your computer, continue hardware troubleshooting by contacting your computer's support staff. With a properly connected microphone and some minor adjustments in your webcam's software application, you should be broadcasting audio with your video in no time. Hope this helps.
Jan 22, 2013 | Gear Head Gearhead quick webcampro...
Microphone not working using realtec software in windows 7
Click start, then enter control panel, click on performance and maintenance, click system, click the hardware tab, then device manager.. Your microphone will be under "sound, video, and game controller" devices. Find your microphone. Right click the device, click the driver tab, then update driver. If that does NOT work, then you need to download the driver that is compatable for your microphone that runs on the Windows 7 operating system.
Nov 22, 2010 | Logitech (980174) Headset
COMO USAR puedo " El Microfono en mi lapto
como activar el microfono de mi lapto, yo escucho en el mesinger pero la otra persona no me escucha, agradezco su ayuda
Oct 03, 2010 | Philips PH62080 Uni-Directional Microphone...
Compaq presario v3000 internal microphone not working
hi
this is gopal from hp did you see that the microphone is working or not means the hardware not the software.
Sep 15, 2009 | HP Compaq Presario v3000z Notebook
Microphone does not work
Hi
with referance to your problem it seems like it can be look in two ways , first by software and then by Hardware ,
First Check if microphone is not muted inside from the phone , means in its software ,
Then below is the picture where you can find the blue box shows that their is button for microphone to turn on / off during calls,
If these steps not help then , it meght be possible your microphone is defective and you have to change your microphone.
Kindly Rate !
Sep 05, 2009 | RIM BlackBerry 8700g Smartphone
I have blaster 5.1 sound card but have problum with voice when i call any one i am hearing other side but he cont hear me plz help me
Check that the microphone is plugged into the correct jack, and in the sound panel properties, check that the microphone input is enabled, and set the volume level.
Dec 19, 2008 | Computers & Internet
External microphone not working
Check first if your sound card is working properly.
My Computer >> Right click...Properties >> hardware >> Device manager >> Sound
Then go to Start >> Control Panel >> Sound and Audio Devices .........hit ADVANCED
one dialog appears MASTER VOLUME >> Go to OPTIONS >> Then PROPERTIES..........
CHECK the MICROPHONE...........Hit OK.............
This will be fixing your problem (if your sound card is working well)
Oct 30, 2008 | Compaq Presario 700 470024-192 Notebook
Microphone
try to find the latest updates for your hardware and software you are using
Apr 09, 2008 | Toshiba Satellite P105-S6104 Notebook
Compaq Presario 700 470024-192 Notebook Logo
18 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
