Question about HP Pavilion dv4000 Notebook
I cant enable my wireless adapter
I own an Inspiron 6000 Dell Laptop, I was online using my wireless internet feature, I was on a couple of websites, and I noticed my system started taking more and more time to load a web paige, now I tried to repair the connection and after it disabled the network adapter, it cant be re-enabled, and I need to know why, and how to fix this, anyone have a fix for this?
If so you can reach my at my email below...
    Scholar:
  • 94 Answers
First, check if the blue light or green light for your network adaptor is turned on. This color light means it is working properly. If it is red, or no lights, it is not working properly.
try checking if your wireless network adaptor's driver is corrupted.
go to "my computer", then right click to go to "properties", then go to the "hardware" tab, then "driver manager". There, look under network adaptor and check if that driver is functioning properly by right clicking it and then "properties".
If it IS corrupted, re-install it here:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=INS_PNT_6000&os=WW1&osl=en&catid=&impid=
Hope this helps! ^_^
Posted on Jun 22, 2009
How to find wireless switch on dell inspiron 6000 laptop running windows XP
There is no physical wireles switch on your laptop. You should however, be able to hold down the "fn" key at bottom left of the keyboard and then hit the F2 key at top left to turn your wireless on or off. If that does not provide the desired effect, then your wireles adapter may be disabled, in which case you should right click on the wireless icon in the bottom right system tray and choose "Repair" or "Enable".
Best of luck to you.
Aug 27, 2010 | Dell Inspiron 6000 Notebook
Tip
Battery won?t charge and AC adaptor not recognized
I have a Dell Inspiron 6000 that just turned two years old.
After one year, my dell 6-cell battery started to falter, so Ipurchased a new 9-cell battery. This worked fine until a couple ofmonths ago when I noticed that my 65W adaptor was frayed. I bought anew 65W Dell Inspiron 6000 ac adapter andit worked well for about a week until I noticed that my battery wasn’tcharging at times. If I was patient, or unplugged the adapter andplugged it back in, the battery began charging and all was saved.
dell-inspiron-6000-laptop-battery.jpg?w=200
This lasted only a short time until my Dell Inspiron 6000 batterywouldn’t charge at all for long periods of time, and sometimes thecomputer wouldn’t turn on, even if plugged into the wall. I thought itmight still be the adaptor, so I borrowed a fully functioning 90W Delladapter from a family member to test the system. This worked better,but still not great.
When I removed the battery and started only fromAC power, the functionality was also intermittent. Usually, if thecomputer actually started, I received the start-up error “The Inspiron 6000 AC AdapterType could not be determined, etc. etc. etc.” After pressing F1, thecomputer booted, but if the battery wasn’t in, the computer didn’tusually last long before shutting off. Unsure if maybe the battery wasthe problem, I put the 6-cell Inspiron 6000 batteryback in, and it too wouldn’t charge, although (together with the 90Wadapter) my computer would at least start more consistently if pluggedin. The error remained however, and sometimes the system stopsrecognizing power and switches to my ever dwindling battery power untilthe adapter is recognized again.
The problem is with the jack on the motherboard inside our Inspiron 6000’s. This is the jack you plug your power plug into on the back of the laptop.
Somehow the jack gets worn and does not make correct contact withthe laptop so the Laptop does not see the power supply as a legit Dellbrand. So the powersupply will not charge the laptop battery and run the laptop at the same time.
DC power jack repair guide. Do-it-yourself instructions.
Modern laptops are all sold with built-in wireless laptop ac adapter.Some power notebooks used by corporate road warriors will have powerfulcellular adapters that connect the laptop to the Internet via the cellphone infrastructure
A bad connection between DC-IN power jack on the system board and the system board is a very common problem with dell pa 12,dell e1505 and Dell Inspiron 6000notebooks. If your laptop is out of warranty, then you can fix theproblem by resoldering DC-IN jack on the system board. If it’s stillunder warranty, it would be fixed at no charge to you. Problem symptoms:
  • Laptop randomly shuts down without any warning.
  • Power LED and battery charge LED start flickering when you wigglethe power cord or the AC adapter tip on the back or your laptop.
  • The battery will not get charged.
  • When you plug ac adapter for laptop, the laptop appears to be dead and there is no LED * activity at all (DC-IN jack on the system board is broken).
To fix the problem, you have to take your laptop apart, remove the system board to resoleder or replace the DC-IN jack. dell pa 12 and Dell Inspiron 6000 disassembly guides will help you to remove the system board. Take a closer look at the power jack on the system laptop board witha magnifying glass. In most cases you get the power problem because ofa bad connection between the DC jack and the system board, you’ll see acrack between the DC jack connector and the system board.
on Jan 22, 2010 | Computers & Internet
Just put a new hard drive in my Dell Inspiron 6000 laptop. I get an excellent signal when connecting to the wireless router, but I get a limited or no connectivity error and cannot access the internet on...
is it only in one location or everywhere, if only at home reset wireless router. if evrywhere, then uninstall wireless driver and llet windows reinstall it by rebooting
Jun 19, 2009 | Dell Inspiron 6000 Notebook
Wireless network connection not working
For some reason known only to Dell, the default setting for the Inspiron 6000 built-in wireless network adapter is 'off' or 'disabled.'
If you used Dell's restore disk to reinstall XP, the radio button is turned off. Go to control panel/system/device manager, find the wireless LAN device, right-click on it and choose 'Properties.' Under 'Wireless radio' check 'on' or 'enabled.'
Go back to Windows network setup wizard and go back through the steps using the 'restore network connection' button. You should be good to go.
There's an EXCELLENT network manager from Cisco named 'Network Magic' that takes all the guesswork out of setting up your internet connection. I highly recommend it. They offer a free trial and I think may even have a 'Lite' version that helps with simple connections without the bells and whistles of the full blown program. I'm not sure about that, but I can't tell you how much time it's saved me troubleshooting and setting up networks for my clients.
Jun 11, 2009 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 won't connet wireless network after reinstall
check DEVICE MANAGER if the wireless card have the right driver installed. if you found that the wireless card have yellow exclamation point on the right it means, you installed a wrong driver.
check also in BIOS if the wireless card is enable and the switch is turn on.
press Fn+F2 to enable wireless radio/anthena (funtion key with wireless icon in blue color)
some dell laptop have hard switch located right side check this and turn the switch on.
if you want to see the icon n task bar, go to control panel....network connection...right click on wireless adapter...select properties...check Show on taskbar
Apr 03, 2009 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 Wifi?
Look on the keyboard and see if it has a key with a symbol for a wireless device. If it does, click it with the FN (function) to enable or disable it.
You can also see if there is a switch on the front or sides of the laptop for a wireless device.
Finally, go to start>control panel>system. Access the device manager. Click the plus next to network devices and see if any wireless devices are listed.
Feb 27, 2009 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 with network card Intel/Pro Wireless 2200 BG
So u can connect to the router, but you arent allowet to access the internet?
The router gave your dell a new ip-number, but it dident gave you access to the net. You ned to do the settings in your router manual, let the router give your dell full access.
Good luck
Dec 05, 2008 | Dell Inspiron 6000 Notebook
Want to have dual monitor feature in my dell laptop
You will have to check and make sure that your video graphics hardware will support the dual option. If not, you will have to purchase a PCMCIA video graphics adapter that supports a second monitor.
Dec 04, 2008 | Dell Inspiron 6000 Notebook
HP Pavilion dv4000 Notebook Logo
251 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
