Question about HP Compaq d220M (829160054797) PC Desktop
My pc doesn't boot up window i have a hp and xp it try to but stop half way
  • zazonker
    zazonker May 11, 2010
    Please be specific on what happens and how far it gets before it fails. For example, what do you mean by half way? What screens do you see? What don't you see that you normally have seen?
    Scholar:
  • 94 Answers
Try this:
Turn Off the computer
Turn it on, then press F2 to go to the BIOS. (while your pc boots the black screen)
Then, look for the Advanced Menu, where it will display your drives.
Do a hard disk test, to see for any hard drive errors.
If there is any, that is a sign that you must replace your hard drive.
Hopes this helps! ^_^
Posted on Jun 22, 2009
Cannot display on monitor
If your PC gives single normal beep while booting then try connecting your monitor to another working PC. If it doesn't display then check the VGA cable by replacing it with new one. If the beep is not normal then tell us the beep behaviour.
Nov 30, 2011 | HP Vectra VL420 Desktop PC - Intel Pentium...
My hp pavilion laptop dv9030us doesn't boot up
Try to check the SAFE MODE by pressing F8 on windows startup. Even in the SAFE MODE, if you are unable to boot windows properly, try to install/ Repair the operating system.
Jun 17, 2011 | HP Pavilion dv9030us Notebook
How to fix a dell inspiron 8100 boot.When i tryed to boot frome a driver cd that was not for my computer i tryed to boot frome it but would not boot so i turned it off and tryed to boot frome my hard drive...
Hi ethandown,
From my experience, you most likely have a corrupted hard drive which has affected your Windows Installation. Your only option may be to boot from a Windows XP cd.
-When your computer starts, press F2, sometimes delete to enter the system options and change the boot-up priority device to cd/dvd 9(1st).
- Restart the computer putting your windows xp setup cd inside. It will ask you to press a button to run from the cd.
- follow instructions and when on the blue screen, use the repair windows installation.
-if that doesnt work, you may have to reinstall windows however your old files will still be on the hard drive.
Hope this helps,
kc
Feb 21, 2011 | Dell Inspiron 8100 Notebook
I instol windows xp by pan drive but it stop working installing time driver.com
Check on this link on how to Install Windows XP using USB flash drive. Also try using a different flash drive or if you trying to install XP onto a Netbook, you can also using a USB DVD drive and boot to the external drive.
Jul 07, 2010 | HP Computers & Internet
I had a compaq pesario cq40-421TU laptop .when i boot it with a windows xp cd the set up stop at the point of ''SATRTING WINDOWS'' and shows a blue screen and says some information like a number and the...
The stop error code is most likely STOP:0x0000007B because windows XP doesn't have the correct SATA controller driver to install without assistance.
Options:
If available, try setting the SATA controller in BIOS to ATA or Legacy Mode.
If not available, then you will need to download the SATA controller Driver and slipstream the driver into the XP version you are trying to install
http://www.fixya.com/support/r4439741-integrate_slipstream_sata_drivers_into
Jun 19, 2010 | HP Compaq Presario CQ50-110US Laptop
Dell dimension wont boot after power outage and stops half way through the boot page
The problem is with the corrupted boot files .In my opinion you have one solution
Steps for solution
1. Download an operating system called ' Linux mint ' which can be installed in the pen drive having minimum 4 gb capacity . Using this operating system you can access the computer .
2. Copy the file and folders to an external storage device (external hard disk, pen drive etc..)
3. Reinstall the operating system ( XP,Vista ,Window 7,Ubuntu etc )
Hope you be successful
Mar 12, 2010 | Dell Dimension E521 PC Desktop
PC BOOTS HALF WAY
Try booting into safe mode. If it's a driver problem, safe mode will allow you to start Windows with only the bare minimum of hardware and drivers being engaged. To get to safe mode, press the F8 button on your keyboard during the Windows boot process until it takes you to a screen to let you select Normal, Safe Mode, Safe Mode with networking, etc. I would suggest not using anything other than just Safe Mode. From there, uninstall any software or new drivers that you recently installed. Alternatively, you can use the System Restore feature to rollback to a previous restore point.
Aug 10, 2009 | HP Computers & Internet
WHEN I START MY HP LAPTOP AFTERTHE WINDOWS XP APPEAR IT JUST STOP
It's not booting to the OS I take it. THen you need to do a recovery it you have one. First try F8 key when you turn laptop on try safe mode see if that boots. If it does restart F8 again try last know see if that one work that would be your last start up backup if that works you should be ok. If not then go to setup do boot from CD install your Windows CD restart your laptop and try doing a windows repair if that does not work then you will have to do a complete reinstall.
Good luck
Mar 20, 2009 | HP OmniBook XE3 Notebook
How to restart hp pavillion 7965 desktop
Hi there. Try these steps:
1. On restart, press F8. This should bring you to a screen with various boot options.
2. Select "Last known good configuration". Windows then may load correctly.
3. If this doesn;t work, try the same thing. This time select "boot in Safe Mode". If Windows now loads in Safe Mode you should be able to restart and Windows may load correctly after this.
4. If these two both fail, you may have to repair Windows...
Jan 09, 2009 | HP Pavilion 7965 PC Desktop
My Hp Pavilion dv4000 screen stays blank
have you got a bootable cd or recovery cd , boot from it and do a fresh installation, i think your windows has got corrupt
Nov 05, 2008 | HP Pavilion dv4000 Notebook
HP Compaq d220M (829160054797) PC Desktop Logo
65 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
