Question about NEC MT1075 Multimedia Projector
My NEC mt1075 projector is projecting a shade of blue all over. The entire screen is showing the correct image, but also with a shade of blue. I think something is wrong with the internal wiring. Is this a common problem?
If you're using component video (red/green/blue rca cables) one of the colors may be disconnected, or the wires may be swapped into the wrong color input. If you are using a 15 pin VGA connector, one of the pins may not be getting good contact at the source or at the projector. Or if the VGA cable is split into 5-wire to make a long cable run, one of the five wires may be disconnected. Any of these problems will cause a global color shift while not affecting the color of the projector's on screen menus.
Posted on Nov 12, 2009
How you can fix blue light problem on NEC projector? Shahid
what does the blue light problem look like on the screen. is it all over the screen, or small dots, or a dim haze etc?
Apr 19, 2011 | NEC MT1075 Multimedia Projector
I have red and blue color tones to one side of my screen. And a slight blue haze at the top of the screen.
You have delamination/polarizar burn requiring factory authorized service.
Good Luck
Aug 11, 2010 | NEC MT1075 Multimedia Projector
Blue haze in top right of screen from NEC mt1075 projector
the light filter on the blue lcd panel is fried due to excessive dust and heat. clean out the projector with canned air. unfortunately, you cannot buy individual parts of the optical engine- you'll have to replace the whole thing. or live with it.
Nov 17, 2009 | NEC MT1075 Multimedia Projector
Pink shade more in NEC WT-610 PROJECTOR
Using the on screen menu, check the hue or wall color settings. [Hue]
Varies the color level from +/- green to +/-blue. The red level is used as reference. This adjustment is only valid for
Video, Component and TV standard inputs (not valid for RGB and DVI digital).
Using the Wall Color Correction [Wall Color]
This function allows for quick adaptive color correction in applications where the screen material is not white.
The following nine options are available.
• OFF • Blackboard
• Blackboard (Gray) • Light yellow
• Light green • Light blue
• Sky blue • Light rose
• Pink
Dec 30, 2008 | NEC WT610 DLP Projector
Nec projector vt 660
could be bad bulb is it setting in right is coler wheel freeley moving
Oct 06, 2008 | NEC VT47 Multimedia Projector
Resetting Lamp Hours Procedure On Nec-MT-1075
Hi - You can download the manual by clicking the link underlined in blue below:
Nec-MT-1075
See page E-55:
As in the note replacing the lamp automatically clears the lamp hours.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 05, 2008 | NEC MT1075 Multimedia Projector
Bright yellow
I can't imagine a setting that would cause this - It sound more like some sort of fault with the projector's blue LCD panel. (The image is created from a mix of red, green and blue light. If you loose the blue, everything will look yellow.)
Is it capable of showing any shades of blue?
Using any graphics or photo-editing software, create a solid blue image (R=0, G=0, B=255 in your colour settings) and if possible, display this full-screen. Is there any output from the projector at all when you do?
If not, it sounds like it need a professional repair.
Matt
Feb 26, 2008 | NEC VT676 Multimedia Projector
VT45 Projector: Blue pixels throughout screen
If the problem is what I describe as a blue haze over the entire image projected, I was told this is a defect in the cable - we have a Dell Video Projector 2300 - and it takes only a dell VGA cable.
So, the problem is in the cable - solution is replace cable.
Feb 28, 2007 | NEC VT45LPK Projector Lamp for VT45
NEC MT1075 Multimedia Projector Logo
763 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
