Question about Epson Stylus DX4200 All-In-One InkJet Printer
EPSON CX3650 Have replaced my cartridges and cleaned heads but printer will still not print when I do test print
  • Anonymous Nov 29, 2007
    Epsom DX4050 - same problem
  • Anonymous Apr 22, 2008
    When I do test print all I get is blank lines - nothing prints out, looks like I either have duff cartridges or blocked holes
  • 121 Answers
You typically test print when you install it but if you need to realign it, you can go into printer proterties and change your settings to default..
if it's printing still and it won't stop, then you can right click on the printer icon located in your tast bar at bottom
--it will show a printer pic--
you can click on the task you want to cancel then right click to cancel all work in progress..
that should take care of, it, if not please let me know if i can be of further assistance to you.. thanks, d
Posted on Feb 27, 2008
I have Epson C45 printer, i just replaced both black and colored cartridge with new one and its printing but no print in my paper appears. I already clean and make print test but still same problem no...
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Aug 11, 2011 | Epson Stylus C86 InkJet Printer
Have changed all cartridges on epson nx400. test shows 3 ink cartridges printing, except for the black ink. have run clean head utility, ink has charged. downloaded and installed printer driver. Found an...
The ink reservoir doesnt have to be completely empty to fail. Replace the cartridges. Some of the jets or all of them may be clogged especially if you have not used your printer in a while. If there are cleaning instructions in the manual clean the jets and then try to print from the printer's self test
Mar 09, 2011 | Epson Stylus NX400 InkJet Printer
My epson cx5500 does not print (test print ) I've been through a nozzle check and have fresh cartridges.... just end up with a blank page
If the inkjet printer has not been used for some time, and the ink cartridges are full then the print head nozzles may be blocked. If running the maintenance nozzle cleaning does not clear the print head nozzles then the print head will need to be replaced.
NOTE - inkjet print heads are not cheap, it may be better to purchase a new inkjet printer.
Jan 17, 2011 | Epson Stylus CX5400 All-In-One InkJet...
Printer Epson DX6000 ... all new cartridges .... will not print any text. I can print the head clean test page as well as the head alignment page ... but no text
You said all new cartridges.. But are they Epson Genuine Cartridges???? I had the same problem when I replaced with new, but generic cartridges.
After finally, going thru 2 sets of each, removed them and put in Genuine., and finally, everthing started printing fine. Weird , but true.
I suggested my answer problem below.
Good Luck :0)
Problem for Epson Stylus C84 InkJet Printer
Re: C84 I'm using generic ink, but the red
By mclamemo on Nov 12, 2009 re: C84 I'm using generic ink, but the red doesn't work at all. I've done all the printer cleaning programs and swabbed inside the printer with alcohol, and re-inserted the cartridge multiple times. it still doesn't print at all.
Also now even the black every few lines prints the top half of the line or the bottom half of the line, or its smeared, etc...
Best Solution
posted on Nov 12, 2009
cns assoc
Rank: Wiz Expert
Rating: 84%, 22 votes
I have learned from experience, that Epson does not like generic ink. You must use Epson Genuine Cartridges. Hopefully, you haven't screwed up the printer, like I did. I did try cleaning the heads and doing everything possible. Use 2 cartridges of ech set, for cleaning, cleaning, cleaning. ......But Nothing.
Had to go out and purchase a new printer.;
Good Luck :0(
Asker's Testimonial
" Thank you. Called Epson also and they didn't say it as directly, but advised real Epson ink too. Hope I didn't kill the printer! Generic ink for sale " - mclamemo
Nov 12, 2009
- Funny. hahahahah,
Me too! I would say, about 2 dozen cartridges to be exact.
lol :0) :0) :0
Nov 15, 2009 | Epson Stylus C86 InkJet Printer
When I print/copy it is missing lines of ink and not getting the whole image. I replaced the ink and have cleaned the head
Sometimes it requires several head cleaning passes to fix missing lines. Make sure the test pattern after cleaning has no gaps. Print the test page. If test page is bad and you have replaced all ink cartridges, then junk the printer or call Epson for a replacement. Even if out of warranty, the may give you a great deal.
Sep 30, 2009 | Epson CX8400 All-In-One InkJet Printer
Epson CX4800 cannot clean the print heads
Please remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Please snap the cartridges back into the cartridge carrier and please try to print a printer self test.
May 27, 2009 | Epson Stylus CX4800 All-In-One InkJet...
Epson CX3650 printing gaps
Remove ink cartridges one by one and put it back in. If same thing happens, try to do head cleaning and nozzle checks consecutively from the computer.
Start -> Control Panel -> Printers & Faxes (Windows XP) / Printers (Windows Vista) -> Printer Icon (right click) -> Printing Preferences -> Maintenance
You should be able to see nozzle check, click it and follow the prompt. Line patterns that corresponds to the colors of the ink cartridges would be printed. If breaks on the patterns appear, continue with head cleaning. Try to do this about 3 times until all patterns are complete.
Dec 21, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Not printing even the test page,full ink ??
I have the same problem, I re-loaded the software, checked all the settings, went through set up procedures and nothing??????? I goes through all the motions, spits out the paper..........blank
Apr 10, 2008 | Epson Stylus CX6400 All-In-One InkJet...
White lines in the printout
If the lines are horizontal (across the page) it is quite possible that your refilled carts are at fault. I would suggest you try the underhead cleaning method as described in my previous post - If this has little effect I would suggest you bin the refilled carts and get a full set of genuine ones to put in. The refill process can easily introduce air into the sponge which retains it and causes the ink to foam. This is then dragged down into the print head and and causes problems with print quality. If you still have issues after the underhead cleaning and new carts have been installed, get in touch with The Service Manual Shop and get the Epson software they have which allows you to make lots of adjustments to the printer. You should try running the alignment routines to check the Bi-Di printing is inline.
Jun 14, 2007 | Epson Stylus DX4200 All-In-One InkJet...
Epson Stylus DX4200 All-In-One InkJet Printer Logo
123 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
