Question about HP OfficeJet 6110 All-In-One InkJet Printer
Hp officejet 6110 wont print - makes grinding sound
Trouble screen keeps saying remove and check cartridges. I've removed them and reinstalled. Cleaned the contACTS. wHEN WE TURN THE PRINTER ON IT MAKES A GRINDING NOISE THEN THE TROUBLE CODE COMES UP.
  • dennis bullard May 11, 2010
    not overly fam,iliar with this particular model BUT others have had this and I recommend taking a lint free rag and cleaning the ink off the carriage rail/s the wiping a TINY amount of sewing machine oil on the rails and then wiping again. restart the printer and see if that odd grinding noise still persists
  • 99 Answers
SOURCE: error code 1517--remove and check cartridge
Solution Follow the steps below until the above issue is resolved. All of the following steps may not be necessary to resolve the issue. Step one: Clear any paper or carriage path obstructions Right-click the link below to open a new browser window with specific instructions about how to clear paper jams. When you have completed paper jam removal instructions, return to this point in these instructions to continue resolving a carriage stall. Click here for information on resolving paper jams (c00107909). (in English). Moving the carriage
  1. With the product turned on, open the print cartridge access door. The print carriage might try to move into the access area. If so, allow it to move to that position.
  2. Without turning off the product, unplug the power cord from the back of the all-in-one. Unplug the power cord from the power source. The power cord must be unplugged to allow the parts to be moved by hand and to reset the paper feed mechanism, without the risk of an electrical shock.
  3. Looking in through either the print cartridge access door or the output paper tray, verify that the print cartridges are locked into the carriage and have not come loose. Also verify that there are no obstructions under or around the carriage to block it from moving.
  4. Verify that the print carriage can move freely across the width of the product by gently pushing the carriage to the left and then to the right. Clear any obstructions found. You may have to reach through the output paper tray to access the print carriage.
  5. Close the print cartridge access door and plug the power cord back to the back of the product. Plug the power cord into the power source.
  6. Press the On button to turn on the product.
  7. Try the print job again to see if this step resolved the issue.
    • If the issue is resolved , you do not need to continue with the rest of the instructions on this page.
    • If the issue is not resolved , continue to the next step.
Step two: Ensure correct installation of the front panel overlay If the front panel overlay, or bezel, is incorrectly installed, the product may indicate a false carriage stall error condition. If the product has not been set up before, ensure correct installation of the front panel overlay by following the instructions below. If the front panel overlay is already installed, and your printer has been working for some time, do not attempt to re-install the overlay. Press firmly on the overlay to ensure proper installation of the overlay adhesive or pins.
NOTE: 12If the front panel overlay is already installed, proceed to the next step.
  1. Insert the two tabs of the bezel into the top slots on the unit. Figure 1: Inserting the tabs c00303994.gif
  2. Tilt the bezel down and press firmly. Verify that the tabs lock into position and that the cover is even with the edges of the unit. Figure 2: Locking the tabs c00303995.gif
  3. Try the print job again to see if this step resolved the issue.
Step three: Plug the product directly into a wall outlet Verify that the product is properly connected to a suitable power source by following the instructions below.
  1. Verify that the computer and the all-in-one product have a three-prong power plug.
  2. Unplug the power cable from the back of the all-in-one.
  3. Unplug the product cable from any power strips or surge suppressors, and plug it directly into a grounded (three-prong) wall outlet.
  4. Plug the power cable into the back of the all-in-one.
  5. Try the print job again to see if this step resolved the issue.
      NOTE: If the product prints when plugged directly into a wall outlet while unplugged from any power strips or surge suppressors, the power strip or surge suppressor may not be allowing sufficient voltage to reach the product.
Posted on Feb 09, 2008
SOURCE: grinding noise on startup
Problem The Resume light continues to blink after the paper jam is cleared.
OR
The carriage is stuck or making a grinding noise. Solution 1. Lift the top cover to the printer. 2. Turn the printer off and then on again. 3. Unplug the power cable from the back of the printer when the grinding noise starts. 4. Move the carriage towards the middle of the printer (this procedure may take a couple of tries to get the timing correct). 5. Take out the cartridges and close the top cover. Turn the printer back on! 6. Reconnect the power cord. 7. Open the top cover, reinstall the cartridges, and then close the top cover
Posted on Mar 25, 2008
joecoolvette
  • 5660 Answers
SOURCE: Remove and check cartridge
I suggest that the inkjet ports on the ink cartridge, and perhaps on the printer, are clogged with dried ink. The ports I'm speaking of are tiny, minuscule holes, in the ink cartridge. Ink comes out of the cartridge, and through these tiny holes. The size we're talking here, is almost microscopic!
On the printer itself, there are holes that match. Match the holes for the ink cartridge. These become clogged also.
I would like to suggest this. Works for me, printers in my shop, and to many, many people I've suggested it to. (I will repair basic problems on a printer. The computer itself is my forte)
Printer UNPLUGGED from electricity. Open the printer body, remove the ink cartridge. If there is more than one ink cartridge, you may want to remove them as well. Give yourself room to work.
(This isn't really like work. You'll see what I mean)
Use a clean, lint free, cloth. Soak it in very warm water. Actually as warm as you can stand to the touch. Wring the cloth out until it is just damp. No drips of water are present. I suggest you don a pair of rubber dishwashing gloves. Keep any ink from getting on your hands, or wrists.
On the front of the ink cartridge you should see a brass strip of metal, or brass contact pads. If the cartridge has the brass metal strip, the holes are probably in it. If it has the brass pads, the holes are probably nearby. Wipe the area the holes are in. If there is no obvious area that looks like where these holes would be, wipe the entire area that contacts the printer.
As you wipe, you should pick up some ink. I suggest you use a fresh area of the cloth, and continue. When you are satisfied the ink cartridge holes are clean, set the cartridge aside.
Now with a clean, fresh surface, wipe the area on the printer where the ink cartridge meets.
You may want to follow up with a clean, lint free dry cloth on the ink cartridge. It needs to be dry before reinstalling.
You may want to use a hair dryer set on low heat, to speed up the process of drying the printer out.
Keep the hair dryer constantly moving, and about a finger length away as you use it.
I Do Not suggest the hair dryer trick for the ink cartridge.
When you feel satisfied that everything is dry, reinstall the ink catrtridge. Close the printer, and make sure it's down tight. Plug the printer back into electricity. Turn the printer on. Go to the Diagnostic Tools section, and run diagnostics.
Do the alignment test, and print pattern test.
In your Help section, it will show you where the diagnostic tools are, and how to do the alignment test.
Posted on Apr 16, 2009
princegh158
  • 56 Answers
SOURCE: Remove and check cartridge in HP 2210
ok no problem
;go ahead and take out the power cable
:press the power button fr 30 secnds and while u are holding the power button plug the the power cable back
:still it ocurrs ....take out the catriges ..plug out the usb cable ,after 30 secnds plug it in ,,.it will ask fr the catriges..put them in nw
:ur peobelem will be resolveed
Posted on Jul 02, 2009
SOURCE: gear grinding noise when scanner wont work
Unfortunately the problem can only be solved by replacing the plastic gear that is turned by the metal motor gear. The gear becomes loose on the axle and that allows enough movement for the motor metal gear to slip over it. If parts can be found, it is an easy fix but where can those parts be found
Posted on Jan 30, 2010
Will not print and keeps saying remove and check carttridge.
Make sure if it is new cartridge that you took protective film off of copper contact side.. If you did clean the contacts with a pencil eraser.
Nov 05, 2010 | HP OfficeJet 6110 All-In-One InkJet...
My hp officejet 6110 says remove and check cartridge.
Hi
try reinstall your cartridges if it still says the same error
you need to replace them the one or and the both cartridges
If I help you pls vote me
Oct 13, 2010 | HP OfficeJet 6110 All-In-One InkJet...
HP 6110 won,t print. After initializing, I get error messaage to REMOVE AND CHECK CARTRIDGE. and AFTER CHANGING 56 AND 57 CARTRIDGES many times, still doesn't print.. I ve spent 3 hours trying to navigate...
Hi
your cartridges are not good any more
and need to be replaced
Remove and replace your cartridges
try old ones to see if color or black has the problem
Hope I help you
if i did pls vote me
Cartridge
Sometimes just removing the cartridge from the printer and putting it back in can solve these problems. Open the printer and remove and reinsert all print cartridges. Make sure they are secured tightly and close the lid. The cartridges may need to be replaced.
Jan 09, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Cant print and im getting an error message
This generally means that the cartridge is empty or defective and needs to be replaced with a new one.
Sep 23, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Remove and Check Cartridge
One of the cartidges you have purchased is faulty.
you can reinstall the empties one at a time as a process of elimination to determine which new cartridge is the problem
Jun 06, 2009 | HP OfficeJet 6110 All-In-One InkJet...
"remove and check cartridge" error message
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=buu02180&cc=in&lc=en&dlc=en
I resolved the "remove and check cartridge" issue after reading the instructions at the above address. Most importantly, I replaced both cartridges and the problem was resolved.
The color cartridge appeared to be the issue. It had been in for months and used infrequently.
May 30, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Error 1517 still thriving--cartridges have been removed and reinserted, now what?
Hi , does your cartridge ink hp original? If generic ink try to change genuine ink.
Feb 09, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Printer wont print HP OFFICEJET 6110 all-in-one
1-if you are in any application, word, windows etc... click on
File
Print
Is the printer there hp 6110 ( if not reinstall driver)
does it have a checmark next to it? no, then right click
go to properties
set as default
put your mouse over printer, does it say ready? no, check connection or change cable.
Good luck
Nov 05, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
381 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
