Question about Meade LXD55 Telescope
Replace connector on wire from DEC drive Motor on a LXD55 telesco
The 8 PIN Connector on the end of the wire from the DEC drive motor on a meade LXD55 telescope was cut off. Does anyone know the wire color sequence to insert into a new 8 pin connector?
  • 3,186 Answers
If you will post this question on the LX forum on:
www.cloudynights.com someone will know the proper sequence and color to reattach.
Posted on Jun 28, 2009
My Kenmore front load washing machine is showing the F-06 sign. What does this mean and how much will it cost to fix it?
Hello there and welcome to fixya
This is a motor controller issue meaning that either the windings in the motor may be bad or the ends of the wires have became corroded and needs to be cleaned and have a light coat of grease applied to the wire ends so knowing this here is what needs to be done first UNPLUG THE UNIT
Make sure that all connections between the Drive Motor, and the Motor Control Unit (MCU), BASICALLY THE WIRE HARNESS and Central Control Unit (CCU). are all very clean and not full of corosiion it is best to remove each one at a time then clean them and reattach them then once this is done try the machine again if the code is still there then you will have to use a meter and check out the drive motor
CONDUCT a continuity check of the Drive Motor windings. Remove the connector plug and check across pins 1 to 2, 2 to 3, and 1 to 3. All readings should be approximately 6 ohms. HINT: You can also take this reading by removing connector 2 from the MCU and measuring across pins 1, 2 and 3. If the readings are good, this will also prove the wiring and connector good.
- Check the MCU. The connectors are numbered 1 to 3 (L to R). That is, with the MCU installed, connector 1 is on the bottom, followed by 2 in the middle, and 3 on top.
Connector 1 - is the serial communications link between the MCU and CCU and has three wires. At the opposite end, this will be the 2nd connector from the rear on the left-hand side of the CCU.
Connector 2 - is the link between the MCU and the Drive Motor. Pins 1, 2, and 3 on this connector are the Drive Motor windings. Pins 4 and 5 are for the tachometer.
Connector 3 ? is the primary power connector. Pins 1 to 2 should read 120VAC with the door in the locked position. Pin 3 is ground. At the opposite end, this is the 4th connector from the right on the front of the CCU.
If your continuity readings are normal for the Drive Motor and you have verified all connectors, replace the MCU.
If any of the Drive Motor windings indicate readings higher that 6 ohms, replace the Drive Motor.
Sep 21, 2011 | Kenmore Elite 45986 Front Load Washer
Washer keeps on shutting off and light keeps flashing f then 06
The error is an indication a motor speed problem. You will need to check the following:
- Check the wiring harness. Verify all connections between the Drive Motor, Motor Control Unit (MCU), and Central Control Unit (CCU).
NOTE: The MCU is a circuit board located in the vicinity of the Drive Motor on the bottom rear of the washer. To access the MCU, you will need to remove the back panel of the washer.
NOTE: The CCU is the main computer for the washer and is located behind the wash tub. You will need to remove the top panel to access the CCU. This is accomplished by removing the three screws in the back of the washer that hold the top in place. Once the screws are removed, the top panel will slide back, then lift off.
- Check the Drive Motor. Perform a continuity check of the Drive Motor windings. Remove the connector plug and check across pins 1 to 2, 2 to 3, and 1 to 3. All readings should be approximately 6 ohms. HINT: You can also take this reading by removing connector 2 from the MCU and measuring across pins 1, 2 and 3. If the readings are good, this will also prove the wiring and connector good.
Connector 3 - is the primary power connector. Pins 1 to 2 should read 120VAC with the door in the locked position. Pin 3 is ground. At the opposite end, this is the 4th connector from the right on the front of the CCU.
NOTE: All the connector pins are numbered R to L.
(tip courtesy JSRock)
Thanks for using FixYa
Mar 04, 2011 | Washing Machines
I am getting a code F06. What does this indicate?
Thanks for using FixYa$%^^
Jan 20, 2011 | Kenmore Elite 45986 Front Load Washer
F06 code
Jan 18, 2011 | Whirlpool Duet GHW9150P Front Load Washer
What does f06 mean
Thanks for using FixYa*(&^%
Jan 09, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Will not spin error code 06 appears
Assuming this is a Kenmore/Whirlpool unit:
Thanks for using FixYa!!
Dec 10, 2010 | Washing Machines
Kenmore Elite HE3Plus stops prior to the end of the cycle and displays F06. Any idea what this is? I'm suspicious of an elictrical issue based on the vague description in the manual.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 15, 2010 | Kenmore Elite 45986 Front Load Washer
F6 error code, new main controller doesnt solve it
Connector 3 – is the primary power connector. Pins 1 to 2 should read 120VAC with the door in the locked position. Pin 3 is ground. At the opposite end, this is the 4th connector from the right on the front of the CCU.
Jul 24, 2009 | Washing Machines
Getting 6e error
May 10, 2009 | Washing Machines
10" lx200 classic EMC
You will need a socket called an RJ45 (8P8C), which has 8 contacts. Many are available as telephone line (three phone line) extension connectors. This is also like an ethernet Cat5 or Cat6 (8 wire) computer network cable connector You can get these at Radio Shack or Staples or similar office supply. You can take apart the $5-9 connector and use half. Either that, or you will have to go shopping at an electronics store like Fry's or on line (Allied, Digitech or Mouser). But there you may have a minimum order charge.
But are you sure it is the socket and not the cable? Can you swap the cable end for end or buy a new one?
"Recently there have been complaints about declination drive intermittent electrical problems. Many do not realize that there is a second plug on the inside of the fork where the declination cable plugs in. This plug should also be worked from time to time as well and cleaned." from MAPUG
Aug 10, 2008 | Meade LX200GPS 10 in. Telescope
Meade LXD55 Telescope Logo
335 people viewed this question
Top Meade Optics Experts
Experi
Level 1 Expert
Joe Wright
Level 1 Expert
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Meade Optic Expert? Answer questions, earn points and help others
