Question about Kenmore 57029 Side by Side Refrigerator
The ice maker is located in the bottom portion of the refrigerator and currently is only make shall ice cubes. Any ideas?
    Novelist:
  • 145 Answers
The ice maker has an adjustment for the ice cube size.
take your ice maker out and then remove the white square cover
you will see a screw whit a - + symbols our it ours the + and that should solve your problem.
NOTE: if the water over low and end up on the freezer turn it back to the minus a little.
Posted on Jun 22, 2009
NEED PROCEDURE FOR REMOVING THE ICE MAKER FOR INSPECTION AND TROUBLESHOOTING. FRIG IS NEW...ICE MAKER NOT MAKING ICE !!!!!
Are you sure you have the ice bin properly in place?
Ice bin must be locked in place for proper ice dispensing. If necessary, turn auger driver behind ice bin counterclockwise to properly align ice bin with auger driver.
• Press the switch ON to activate ice maker. Slide bin into guide rails located on either side of the enclosure. Push the ice bin in until resistance is felt. Raise the front slightly and push the ice bin completely in. An audible "click" is heard when the ice bin is located correctly.
• After freezer section reaches between 0° to 2° F (-18° to -17° C), ice maker fills with water and begins operating. You will have a complete harvest of ice
approximately every hour.
• Allow approximately 3 to 6 hours after installation to receive first harvest of ice.
• Discard ice created within the first 12 hours of operation to verify system is flushed of impurities.
• Stop ice production by pressing the ON/OFF switch located on the front of the ice maker.
• The first one or two batches will probably contain undersized and irregular cubes because of air in the supply line.
• When the ice cubes are ejected it is normal for several cubes to be joined together at the ends. They can easily be broken apart. The ice maker will
continue to make ice until the supply of ice cubes raises the ice maker arm, shutting the ice maker off.
• Certain sounds may accompany the various cycles of the ice maker. The motor may have a slight hum, the cubes will rattle as they fall into an empty storage bin and the water valve may click or "buzz" occasionally.
Jun 01, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
Model was bought 1/92. Ice cube maker not working although we hear a churning sound that seems to signal something's trying to work! What do you think? KitchenAid KBRP20EMSS Bottom Freezer Refrigerator
Those ice makers get stuck from frozen ice portions. Try feeling around to see if anything in the icemaker is frozen up or any foreign object. Please do this with fridge unplugged. If you can't find any frozen or other obstruction then use the hair dryer to defrost the ice maker. This is only a guess from past experiences. My kids once put pop cicle sticks in the ice maker wanting to make ice cube on a stick. Goodluck Google burdfrenzy
Nov 26, 2010 | KitchenAid KBRP20EMSS Bottom Freezer...
The ice-cube maker on our Sub-Zero 650 has stopped making ice.
try replace the cheapest part first.( vater valve). you only need 2 components to make ice. water valve and ice maker.is simple and easy water valve located in the bottom part of the unit. remove the kick plate. left side. and color blue. ice maker inside the freezer. (DISCONECT POWER BEFORE SERVICE. ALSO TURN WATER SUPPLY OFF.) try main box , garage. and water meter outside your house. good luck
Apr 02, 2010 | Sub-Zero 650 / O Bottom Freezer...
The ice maker is not working
There is a way of testing the ice maker.
Diagnostics for ice maker starts on page 27
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 01, 2010 | Samsung RF265AA Bottom Freezer French Door...
Icemaker not working on a Kenmore Bottom Freezer
if the volve behind the fridg for the ice get 120v for short time when the ice maker ask for water then the volve is bad but if there is no 120v to the volve then the command not coming from the ice unit and it need to be change , the wholl ice maker unit :(
Dec 29, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker dripping water fusing ice cubes
The dual water valve (solenoid) that open and let the water from the line when the ice maker calls for it, is leaking and needs to be replaced.
Aug 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
550 Ice Maker Making Hollow cubes or Small Cubes
Hollow cubes are usually a result of lack of water supply
Jul 12, 2008 | Sub-Zero Bottom Freezer Refrigerator
Kenmore elite 106.54619300 Ice maker just stopped working
sounds like the moter is burnt out and you need to replace ice maker try ebay
Apr 04, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Clumps of ice cubes in back of ice bucket
sounds like your just might not be using enough ice and they are defrosting and clumping together.figure your pulling ice from front of bucket the the backs hardly get used espescially in winter your not using as much ice. or ice maker is slightly over flilling water and dripping over rear of unit
Jan 20, 2008 | Amana ARB1905C Bottom Freezer Refrigerator
Kenmore 57029 Side by Side Refrigerator Logo
73 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
