Question about Dryers
Whirlpool stacker washing machine works dryer doesn't
We had another stacker and we thought it was broken because the washing machine works and the dryer didn't, so we bought a used whirlpool and we are running into the same problem is it our maching or our outlet
  • andrewandcou Jun 22, 2009
    it is an electric one
  • Joe  Marquardt
    Joe Marquardt May 11, 2010
    Is it an electric or gas dryer?
    Problem Solver:
  • 13 Answers
The problem is probably with the outlet. The washing machine motor is 120 v and the dryer is 220 v. If one pole of the two pole breaker is bad you could end up with the symptoms you have. I have seen this happen before. go to the circuit breaker and push it all the way to off (it may feel like you are crunching something inside...don't worry) then turn it back on and try the dryer. If this doesn't work, unplug the unit and test the outlet with a voltage tester. you should read 220-240 volts across the two slots and 120 volts from each slot to ground. If not, it is time to call an electrician.
Posted on Jun 22, 2009
How to fix a broken belt of motor of whirpool wash ultimate care 2
  • Replacing the Belt in a Whirlpool Ultimate Care II ' Home ... homeguides.sfgate.com > ... > Mortgage-Backed Securities Replacing the Belt in a Whirlpool Ultimate Care II by Rogue Parrish. Email; ... The Ultimate Care II washer, ... it may have a broken belt.
  • Whirlpool Washer: Ulitimate Care II - YouTube www.youtube.com/watch?v=bVmjmSzMXHE
    • BY CHERRY HILL
    • 3 MIN
    • 36K VIEWS
    2012-05-30 · Video embedded · Whirlpool Ultimate Care II: ... This is fully funcational washer. Direct Motor Drive works perfectly through each ... Whirlpool Washer: Ulitimate Care II
  • How to replace a broken dryer belt. Whirlpool Ultimate ... www.youtube.com/watch?v=PU8QZeDRl_0
    • BY BAILSOFSTEEL
    • 5 MIN
    • 3.5K VIEWS
    2015-04-04 · Video embedded · This video shows me replacing a belt in a Whirlpool Ultimate Care II ... a broken dryer belt. ... Whirlpool ultimate care II clothes washing
  • http://www.bing.com/videos/search?q=broken+belt+of+motor+of+whirpool+wash+ultimate+care+2&FORM=HDRSC3
    Jul 15, 2016 | Washing Machines
    Any particular problems with installing whirlpool stacker washer/dryer in RV
    the main problem is how stable the foundation is for the laundry center when it goes into its spin cycle.
    Sep 11, 2012 | Whirlpool LTE5243D Top Load Stacked...
    Whirlpool ite6234d thin twin could someone tell me in detail where the belt is located in the washer?
    I can not find your model number that you posted.
    I can tell you that all whirpool thin twins up to last year were direct drive with no belt except for the dryer section. Whirlpool stackers from the early eighties did have a washer belt if yours is this old replace the entire machine.
    Jun 22, 2017 | Whirlpool LTE6234D Top Load Stacked...
    I have a Hotpoint WDF740 washer dryer. When I turn the dial it doesn't register any cycle it doesn't make any noise when the dial is turned, therefore I can't use the machine at all. Can this...
    This just happened to my hotpoint washing machine, I realise it has been a long time since this has been asked but since my answer is different from the others I thought I'd add it anyway in the hope it will be useful to someone one day. The fix was super easy, all that was wrong was the plastic knob itself, which had broken internally. I only found this out after taking the top and front covers off, which is an easy enough procedure, I did it this way: unplugged the washing machine, removed two screws from back of machine that hold top cover in place, then using a putty knife pushed between the top and front covers front to back right at the corners, thus releasing the top cover, once this was out I could unclip the front cover and get to the screws that hold the control board to the front cover. I unplugged the electrical connection to the board, removed all the screws and unclipped it from its plastic cover. At this point I could see the plastic knob had broken, I recovered the broken bit and glued it back on. After the glue dried, I just put everything back in place reverting the previous actions. Hope this helps. If you don't have glue or can't find the broken piece, you should be able to just buy another plastic knob off the internet.
    Jul 06, 2011 | Hotpoint Aquarius WD640 Front Load...
    Water is not draining?
    If you are having a problem with your top load washer then check out this tip...
    Washing Machine2_bing.gif does not Pump or Spin
    http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
    If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
    Front Load Washing Machine2_bing.gif not draining and or not spinning
    http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
    heatman101
    May 31, 2010 | GE WSM2480DWW Unitized Spacemaker Washer...
    Changing dryer belt for lse7804ade washer dryer stacker
    If the washing machine / tumble dryer / spin dryer seems to be making the right sort of noises, but the drum is not turning, unplug it, take the rear cover off and check to see if the drive belt is still intact and on the pulleys.
    Mar 09, 2010 | Washing Machines
    Water leaking from stacker unit
    No parts are replaceable within the pump. Buy a new pump.
    Jun 22, 2009 | Whirlpool LTE5243D Top Load Stacked...
    Whirlpool noise
    Ok can you take the front panel of the washer off easily?
    If you can look for the motor pump assembly. Start the washer with no load, turn the water level down to the small and fill with water when it goes into agitation does it make the noise? if not turn timer to spin and see if motor makes the noise.
    One other thought, maybe the smell is coming from the dryer?
    Let me know. I wont be on line again until Friday Sorry
    May 26, 2008 | Whirlpool LTE5243D Top Load Stacked...
    Whirlpool Thin Twin washer won't start, just makes humming sound
    The belt is broken and needs to be checked for any other part that has failed causing the belt to burn.
    May 26, 2008 | Whirlpool LTE6234D Top Load Stacked...
    Dryers Logo
    116 people viewed this question
    Top Dryers Experts
    Marvin
    Marvin
