Pressure Washers
Problem for Pressure Washers
Generic problem for all Pressure Washers
Alternating or Pulsating pressure on Sim...
By gen_inq on Jun 22, 2009
I have Simoniz S1600 which start to acting up. Its pressure is pulsating, It is there for 10 seconds and gone for another 10 seconds and it will be back again if you keep pressing the wand.
Any idea? it is the switch, relay, sensor or the pump?
Please and Thank you,
Geninq
Best Solution
posted on Jul 05, 2009
Very Helpful)
mrfixit-jerr
Rank: Guru  Tools - Building & Power  Expert
Rating: 94%, 8028 votes
Hello sir, that is a on going problem with power washers the pump not working, than works sporadically. the main cause is leaving the pressure hose hooked up to the machine over a long period of ,not draining hose & machine, in the winter time the hose & pump willfreeze causing hose & pump to expand and burst. build up of calcium deposits from hard water clogging up pump nozzle,valves in the gun handle,clogging hose fittings and screens.one of these has to be your problem.you can find a parts brake down at KARCHER.COM.orRJ BOWERS.COM . and manuals,these are good info,sites,hope this helps, MrFixIt,oh could you please rate this solutions.thankyou )))
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Pressure Washers
Questions and Unsolved Problems for Pressure Washers
Answer
do all troy bilt pressure washers have brass pumps?
Answer
Motor stops, washer was working , full level in oil and good oil. Don't starts again, apparently... (More)
Answer
aqua pure filter has no pressure when backwashing just trickles on the backwash cycle.
Answer
i have excell 3700 pressure washer...the pump cover vibrated loose lost oil and cam melted.how do i... (More)
Answer
Where can I get seal rings and o rings for my pressure washer pump without buying an entire seal... (More)
Describe your Pressure Washers problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Pressure Washer Experts
Top Garden & Power Tool Repairmen
in , PA
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
