Question about Sony DSC-T70 Digital Camera
Sony DSC T70 vibrates when it turn on - Sony DSC-T70 Digital Camera
  • 87 Answers
On Sony T100 and similar,
its the vibration canceling unit, i had the same problem.
if you have good hads you can fix it.( on your oun risk)
1) disasamble the camera, you will see black plastic box inside, this is he lens unit.
2) on the botom you see 2 scrwes, they are holding the CCD remove them and the ccd unit will come from the lens assembly
3) the next is the stabilizer unit it is the problematic one. it is located on the left side of the lens asebly and is held by 2 screws.
you can test it by puling out the cable connected to it (the conector is just under the lens) and verifign that the problem is solved. ( you can leave it this way it will shoot fine just without the anti shake)
4) to fix it take it out ,remove the plastic cover, you see the lens on a plastic mount it should be glued to the magnet under it. the problem is that the glue fals apart.
remove one of the pins on wich it slides, and take the lens and the magnet out.
5) reglue the magnet and reasemble the camera.
6) power up and test, for me that solved the problem
if you need more help you can mail me at adisarit(et)yahoo(dot)com
this is spam mail so be prepared to wait a few days for reply.
i have a document with pictures explaining the process
Posted on Jul 25, 2010
My sony DSC T70 is vibrating when I turn on the camera
Broken SteadyShot inside the camera. Can solve service personnel only.
Feb 14, 2011 | Sony DSC-T70 Digital Camera
How to disable the vibrate function in my sony cyber shot DSC-T70 and where i can find it
There is no option in the DSC-T70 Camera to enable or disable the vibrate option. The vibration in the Camera is a malfunction. The Camera may experience an issue where an abnormal internal vibration and an inability to properly focus and take pictures. Try the following troubleshooting steps and check if the issue can be resolved.
Follow the steps below to perform a manual power reset.
Turn off the Camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the Camera to remain without power for 60 seconds.
Re-insert the battery pack.
Turn on the Camera.
If the issue persists after the power reset, then reset the Camera back to factory default.
To reset the Camera back to factory default, select the INITIALIZE option under Main Settings 1 Menu of the Camera to OK. (HOME-->SETTINGS-->MAIN SETTINGS-->MAIN SETTINGS 1-->INITIALIZE-->OK).
If the issue occurs again, then service may be required.
Thanks for contacting FixYa.
We wish you a Happy Holiday Season.
Dec 18, 2010 | Sony Cyber-shot DSC-T70 Digital Camera
Why does my Sony cyber-shot model DSC-T70 vibrate and what can i do about it?
There is some steady-shot mechanism in camera lens that start vibrating due to some reason, this mechanism will be replaced to fix your camera issue.
It is not user level fix so take it in local camera repair shop.
Sep 04, 2010 | Sony Cyber-shot DSC-T70 Digital Camera
Sony dsc-t70 camara vibrates when turn on
it's actually a failure with the lens mechanism, I just experienced the same situation....Sony has another T20 that they had the same situation with and they offered to fix the cameras until July 2011..currently checking if Sony will fix this defect in this T70
what you are experiencing probably is best described by this article:
www.sonyinsider.com/.../dsc-t20-cyber-shot-camera-vibration/
Oct 25, 2009 | Sony DSC-T70 Digital Camera
My sony DSC T70 vibrates when it turn on but turns off right away
It vibrates because failure on LENS ( failure of stedy shoot function ), in service they try to repair it, in some cases they can, in another you must replace lens
Jun 16, 2009 | Sony DSC-T70 Digital Camera
Camera vibrates when it is turned on therefore pictures are blurry
seems the motorised lens of your Sony have issue.
should get it rectified without delay if still in warranty.
contact the vendor and sony support.
May 30, 2009 | Sony DSC-T70 Digital Camera
Sony DSC-T70 Digital Camera Logo
211 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
