Question about GE Ovens
Self Cleaning over-heats, flashes F2 code and beeps until I flip the breaker. This is a wall unit.
  • 6,784 Answers
Hi, Your Control senses oven temperature above 915F-930F
If actual over temperature condition occurred: Look for welded relay contacts. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective. Check door lock switches.
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature.
Posted on Jun 23, 2009
After cleaning both ovens have received F2 code Replaced sensor on one and now sensor is bad on the other one. theoven i replaced the sensor on continues to work but i am still getting the beep and F2...
most likely you have a bad computer board or clock assy. same thing,when you self clean the oven it gets up to 1000 degrees and can and will damage the electronics in the oven,after the things i've seen i will never use the self clean again,i clean my oven with an sos pad and hot water usually it's just the floor that gets drips on it,i take the racks and floor out and clean them by hand,if anything on the walls i scrub it out,don't use the self clean on any stove the extra heat kills them.
Nov 01, 2017 | Jenn-Air JJW8230D Electric Double Oven
F4 code is displayed and oven beeps continuously
Hello Duane, I am happy to assist you. Typically, error code F4 indicates a lockout error. Try resetting the unit by unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. Wait approximately ten minutes and if the error code does not clear, I would recommend contacting a professional to proceed further. Most likely the EOC (electronic oven control) or the Lockout Control Board on the appliance will need replacing.
Aug 16, 2013 | Frigidaire 27 in. Electric Double...
Oven heats & then beeps code F2EO then stops heating
F2 - E0 Shorted keypad (also called touch pad)
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Here is that part to order.
Jun 19, 2013 | Maytag 30" Built-In Single Electric Wall...
Quit heating
Hi getalifemom - From what you have described it sounds like the unit has faulty element(s) or could possibly be experiencing a wiring issue with the EOC. Try resetting the oven by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If it proves to be ineffective, connect with a professional to accurately pinpoint any potentially more serious issues and properly diagnosis the unit.
Jan 18, 2013 | Frigidaire 30 in. Electric Gallery Series...
Flashing PF 32 error code
Hello - This manufacturer does not show to have such an error code for a wall oven. However the error codes F30/F31 indicates that the unit either has an issue with the oven sensor, wiring with the EOC or the probe connections is open or shorted. Contact a professional to move forward accurately.
Nov 10, 2012 | Frigidaire 30 in. Electric Gallery Series...
Amana Self-cleaning Oven flashes F2 and F3 and beeps. It doesn't get real hot. Although it does heat up not the appropriate temperature.
Hi, F2 error code on the Amana Oven means "Oven too hot" You have to replace Oven temperature sensor to fix it.
F3 error code means "Open or shorted oven temperature sensor". Yo also have to replace Oven temperature sensor to fix it.
Summarily, both code has to do with the temperature sensor which you need to replace...
Oct 23, 2010 | Amana Ovens
F1 ERROR
Hi. This (f-1) code represents a failed oven control board. Have this damaged board replaced asap, if possible. It has failed. Possible logic chip set failure.
Aug 22, 2009 | Frigidaire 30 in. Electric Gallery Series...
F8 CODE IS FLASHING, OVEN BEEPING AND TOP OVEN DOOR IS LOCKED
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Dec 24, 2008 | Frigidaire 27 in. Electric Double...
Oven
I used the self cleaning mode for 2 hours and the error f2 keeps flashing and beeping, I did try to power off with the breaker and left it off for about a half hour and it still continues to beep and flash f2, what should I do?
Aug 07, 2008 | Ovens
F2 error
what is solution
Dec 08, 2007 | Ovens
Ovens Logo
106 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a GE Oven Expert? Answer questions, earn points and help others
