Question about Hunter (25417) Ceiling Fan
Fan stuck on LOW speed
My Hunter fan will only work on low speed or when I pull the chain to the "off" setting. The fan is 6 years old and has been doing this since the day I pulled it out of the box.
I've seen other postings when the fan stuck on high... I wish that were the case with mine. It is mounted on a 12 foot ceiling and not easy to get to.
The fan stays on low speed until I pull the chain enough times for it to land in the off position.
David in Austin (103 degrees today!)
    Problem Solver:
  • 13 Answers
It seems to me you have a faulty switch or the internal wiring is wrong. You can access the switch from the bottom of the fanwhere the light kit is connected. the wiring could have gotten mixed up when the light kit was installed.
Posted on Jun 22, 2009
  • 34 Answers
Is your problem over?
Posted on May 08, 2010
Fan only runs on slow speed
The receiver in the fan housing may have failed.
Apr 20, 2017 | Hunter Dryers
High and Medium don't work, only low
Check your capacitors to see if they're bad. That's the black box near the pull chain switch with wires going to the switch. If bad call 1-888-830-1326 Hunter parts.
2 wire part # 74132-01-000 ( probably not this one)
Other capacitor part # 74133-05-000 (probably this one)
Jun 02, 2013 | Hunter Dryers
Ceiling fan stuck on low
in order for the remote control to work properly the fan has to be on its highest speed using the pull chain ... after setting the pull chain in the proper position you can tie up the chain or remove it to prevent others from changing the setting .. the remote will control the speed from then on ..
Jun 07, 2010 | Hampton Bay 24002 Ceiling Fan
My hunter remote control ceiling fan doesn't go real fast. the highest speed is what a normal fan would do on medium. is there a fix?
if you have pull chain switches in addition to the remote control, your pull chain switch may be set to Medium, which would make the fan run on a maximum of medium speed.
May 16, 2010 | Hunter 52" Ceiling Fan With Light And...
Wire diagram for pull chain on ceiling fan hunter original
if you indeed have a 23852 hunter original...
Black goes to L, High is Red, Gray is medium and yellow is low. Make sure you have the right switch.
Mar 21, 2009 | Hunter 23852 Classic Original Ceiling Fan
3-speed switch replaced with hampton bay switch. Only low speed works.
The cause to the problem was replacing a HUNTER fan switch with a Hampton Bay switch. Before removing the old switch, I noted and marked the color and position of the 4 wires. I then duplicated the connections to the new switch.
But the wire positions of Hampton Bay vs Hunter are not identical, therefore 2 wires
were crossed.
The correct way is to note the color of the wires with the corresponding NUMBER
marked on the switches, then duplicate this on the new one.
Du-uh!
Jul 23, 2008 | Hunter 23852 Classic Original Ceiling Fan
Hunter ceiling speed.
A fan that old has a muilti speed capacitor. It could be that or the swicth. First thing to do is test the swicth with a voltage tester to see if power is switched to different posts if it does switch it is prob. the cap. Good luck trying to find one.
Apr 06, 2008 | Hunter Low Profile III 20807 Ceiling Fan
Hunter (25417) Ceiling Fan Logo
1,086 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
