Question about Garden
Hello, I got a Scotts lawn mower, model # 229630x8a, that won't start. I replaced the spark plug, air filter and the fuel line with a see through one. When I prime it, i can see that there isn't any gasoline going through the fuel line. I then tested starting the engine successfully by spraying engine start oil, however, it stop after a few seconds. Please help. thank you.
  • 4 more comments
  • zichau Jun 22, 2009
    Hi Longhorn294,
    thank you for helping out. the sticker on the housing has the following information.
    Tecumseh Products Co.
    engine model: OVRM120 22032E
    engine family: YTPXS.1951AA
    engine displacement: 195 D.O.M - 0291 J
    it's a Scotts Branded self propelled high rear wheeler.
    Thank you.
  • zichau Jun 23, 2009
    I removed the carb. and cleaned with it carb cleaner and cleared put it back, now when i prime it, it's leaking gas from the little pan by where the nut is. After unscrewing the nut under the pan, i see the little plaster ring that goes in between the nut and the pan is broken. Looks like i need a replacement. Know where i can get parts? do i need a new carb or carb repair kit? thank you.
    thanks for the information, but i made one using the top of a plaster container and seems to work just fine, its not leaking anymore. I am now able to prime it and the mower starts but then immediated stops. no clue to why. is the mower not getting any fuel? could be the the floater is working? thanks.
    i see holes3 on the nut, 2 on the botton, the tiny one on the top, no sure if the one iside the nut counts, if it does, it'll be 4. they were all blocked. i used a paper clip to clear the obstraction and then air sprayed it. all cleaned, i can see light through the holes.
  • Dwain Pippen May 11, 2010
    Are you going to attempt to repair this carb yourself? It will involve removal of the carb, throttle and governor linkage and disassembly of the carb itself and buying some parts. Let me know. Dwain
    Unfortunately, the mower model number doesn't provide any information about the engine because the mower was made by Murray and the engine was made by Briggs (probably).. Could you please post the model number stamped on the starter housing on the engine.
    Problem Solver:
  • 19 Answers
Clean carb in gas for a hour
Posted on Jun 22, 2009
  • 376 Answers
I think you're refering to the gasket for the nut/jet that holds the bowl on. That gasket should be availabe at any lawnmower repair shop. Tecumseh part # 27110A
Posted on Jun 23, 2009
  • Dwain Pippen Jun 23, 2009
    Usually on one of those Tecumseh engines, it's the
    bowl nut which is really the main jet. Make sure the holes are clear. There is probably one very small hole at the TOP of the threads. It''s hard to see, but it won't run if it's not open too. Check that out and let me know.
    A paperclip won't fit the tiny hole at the top of the threads. Find something smaller. It does haqve to be open or it won't run.
1 yr old -won't start this year
probably need to clean out carby and fuel tank
Jun 11, 2013 | Toro Power Lawn Mower
I have a Scotts lawn mower model # 229630X8A I am having trouble getting fuel to the carb. I have cleaned the carb. and the problem is still happening/ What part could it be?
your fuel pump bolted on left side of engine hoses are contected to engine and carb make sure they are secured and check your fuel filter maybe plugged or a pinched hose from gas tank look around
Joe
Sep 30, 2012 | Garden
Mower won't start spark plug turns black
Black carbon fouling on the plug is a sign of the engine running too rich, start by replacing the air filter and plug and try again.
Jun 16, 2012 | Toro Power Lawn Mower
Cub cadet 53bb5bbp750 zero turn won't start
check the safety switches
Apr 03, 2012 | Garden
Scotts by john deere riding mower - 220 hours, 17.5 HP, 42" cut, Briggs & stratton engine -- New Strarter, new battery, good fuel... will turn over but engine will slow down then stop, will not...
Very high likelihood you have fuel line problems. Disconnect primary fuel line from bottom of fuel filter and blow compressed air back up the fuel line to the gas tank. This will clear the line of any trash. Reconnect fuel line to filter. Then remove spark plug and spray a couple of sprays of WD-40 into the cylinder.. Re-install spark plug and then restart. WD-4- will act as a starter fuel and will start the engine for enough rounds to get fuel pump to working to normal run.. Good luck.
May 15, 2011 | Briggs & Stratton Garden
Laid mower on right side towards spark plug fixed fuel line won't start changed spark plug
if turned on side with air filter down check to see if filter is oil soaked if so replace. also carb bowl may have oil in it. clamp fuel line remove bowl nut and drain. will smoke when starts but will clear out
Jul 17, 2010 | Toro Garden
Riding mower having problems starting then runs roughly
I would bet you have a fuel problem. Either the carb is clogged and dirty or needs adjustment. Try opening the screw on the bottom of the carbuerator about a half turn see if that improves it. Also check the air filter and clean it.
Jun 25, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Lawnmower wont start
Possible Causes Corrective actions
Unit will not start Control handle is not engaged Engage control handle spacer.gif spacer.gif
Spark plug wire is disconnected Connect spark plug wire spacer.gif spacer.gif
Fuel tank empty or stale fuel Replace with clean, fresh gas spacer.gif spacer.gif
Air filter filled with dirt or debris Replace or clean air filter
May 23, 2009 | Mtd 22" Yard Machine Push Mower
Garden Logo
613 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
