2006 Ford Freestyle Logo
m
mike grinsell Posted on May 04, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How is the headlight switch wired?
Need diagram, fog lights inop
Auto Repair Help
Level 3:
  • Ford Master 1,420 Answers
  • Posted on May 04, 2014
Auto Repair Help
Ford Master
Level 3:
Answers
1420
Questions
0
Helped
667436
Points
4361
I can send to you but for some reason I send images at 100 percent and fixya re-sizes them down. So I will try If you can not read diagram please see me at my website.
how is the headlight switch wired? - db2870f0-5d6d-4362-bbb5-8bd57b6e7561.png Ask Automotive Repair Questions
Thank you for using Fixya.com
Master Tech Lee www.autorepairhelp.us
3 Related Answers
Anonymous
  • Posted on Aug 30, 2008
SOURCE: head light switch wiring
I hope this diagram works...I'm not great with MS Paint.
Anonymous
  • 984 Answers
  • Posted on Jan 28, 2011
SOURCE: I need the wiring diagram
This is the diagram for the fog lamps ( headlamp is a different cell ).
If you are trying to add them to the existing wiring, do not expect the headlamp switch to cab fuse panel wiring to be there ( that is usually what is missing when you can find the fog lamp connectors under the front of the truck ).
File Save as so you can magnify it with the JPEG viewer you use.
Close up of switch
Testimonial: "Thanks for the diagram, I'll have a pro install the needed wiring."
fordexpert
  • 5692 Answers
  • Posted on Sep 18, 2012
SOURCE: 2007 Ford F150 STX, I need the Wiring Diagram for Lights (Headlights, Running/Parking/Turn-Signal)
Go to either Autozone.com and register your vehicle for free, or alldatadiy.com for the same wiring diagrams. Powerbox layouts are also provided.
Now I want to add that if the new lights are like the HID factory type, you may need 2 Relays and heavier wiring to the lamps. Now sure if the Alternators are the same either.
I hope my solution helps.
Wiring diagram for a 1994 olds cutlass supreme instrument lights
Power comes from headlamp / dimmer switch . Go here for free wiring diagrams http://bbbind.com/free_tsb.html Enter vehicle info year ,make , model ,engine size ! Under system click on lighting then under subsystem click interior light dimming .
1helpful
Wiring diagrams bosch fog lights
I suspect that there is a replacement headlight switch that includes the fog light function.
Location of foglight wiring harness
The Easiest Way is to Get the Wiring Harness Diagram with the Colors and Verify that you plugged the Fog Lights into the Correct Harness. I once had a FORD that had a Fuse BOX that had a FOG LIGHT and No Power to that Fuse.
Make sure you test the Fuse at the Box and then Trace the wires and if the Switch was wired at the Factory, you should be all set
1helpful
I need the wiring diagram for a 2006 ford f150 xlt super crew headlight in order to wire oem fog light harness to headlight harness to get my fog lights to work.
Close up of switch
1helpful
Wiring for Bosch Hologen Fog Lights? Wiring harness has 5 wires from relay, Red to battery, 2 Black - 1 to each light?, 1 Yellow to?, 1 Blue to?, & where do the xtra Black and Green wires go to? These...
Look on the relay for the terminal numbers.
Terminal 30 goes to the battery positive.Red Wire
The two terminal 87 go to the fog lights.Black Wires
Match the color wire with what you have on the relay connection for the rest of the wires.
Terminal 86 should connect to your low beam headlight.
Terminal 85 should go to the fog light switch.
The fog light switch should connect to the terminal 85 and the other terminal on the switch will connect to ground.
1helpful
2answers
I want to install aux. backup lights and not wiring them to the jeeps backup ligts. I don't understand the switch. It has three prongs on the back The diagram shows one is power coming from the relay one...
What diagram? What switch? Are you using a switch that salready in the Jeep, or a switch that you bought? You really need a relay to handle th ecurrent of the lights. The relay will have 4 terminals, The relay is really just a remote switch. Let the relay take the power, not the switch. Buy a relay for fog lights and it should have a diagram you can use.
1helpful
2answers
My headlights on bright and fog light is not working. I have changed the bulbs and they still don't work. The fuses seem to look okay. What else should I look for? Do they have another fuse or circut fuse...
Most fog lights turn off when you put your brights on. Check their operation in normal mode first, if they turn off when you turn your brights on... this is normal.
To disable this you need the wiring diagram for your car, you will have to cut 1 wire to be able to have all your lights on at the same time.
Headlights ok, but instrument panel,fog,&parking lights don't
Maybe a relay but maybe and more probably a broken wire Get a diagram Chilton or Haynes manual
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
