Question about Honeywell Programmable Thermostat Heater
Going from a six wire to a five wire thermostat
    President:
  • 3,433 Answers
There should be a little brass u shaped jumper you put between two of the terminals.. Ck the instruction book but I believe it jumps the R to the RC terminal R=red RC= red/cool
Posted on Jun 22, 2009
  • Ned C Cook
    Ned C Cook Jun 22, 2009
How to wire six wire to three wire termenal
I'm pretty sure this thermostat uses digital communications with a dometic control board. In other words, there are no contacts in the digital thermostat to turn something on and off. Even if you ran a 12VDC wire to the thermostat for power, it won't work to replace a "real" thermostat. I bought one to replace my old analog thermostat and it's not going to work for me.
Oct 10, 2015 | Dometic 3313192.000 White Single Zone LCD...
How do i connect the wires on a westinhouse Freestyle upright freezer thermostat...ther is a five pin plug and it has the green earth wire connected but the ...blue .. brown..black..orange and red are not...
I'd be looking for a wiring diagram on the back of the unit or inside the bottom rear cover. The wire colors and numbers on the thermostat would guide on where to connect what
Feb 04, 2015 | Freezers
Blower fan only runs in positions 1-3, not on 4; relay or resistor?
Remove blower motor resistor and check to see if it discolored or melted. if so then replace blower motor resistor, also blower motor speeds 1-4 go through resistor, 5 goes direct from switch to blower motor. check wire harness connector at resistor, it should have six wires five power wires that corralate with the five settings on switch, so in each switch setting one wire should have power. the sixth wire is the ground. also harness connector to resistor it may be melted, if so go to dealer with vin number and get new harness connector with resistor.
I hope this helped.
Dec 17, 2011 | 1998 GMC Jimmy
I am trying to install a Honeywell programmable thermostat and am having trouble with the instructions. The old thermostat connections are identified by wire color, six of them, W, O, G, R, C, Y, but the...
It sounds like you have a heat pump, o (orange) is usually used to power a reversing valve in your outdoor unit for cooling. But just in case you don't here is a little info Rh-power for the heating circuit, W- completes heating circuit, Y to your outdoor unit for cooling, Rc- power for the cooling circuit, and G power to your high speed fan.
O for your heatpump
C is 24v common for cooling circuit
If you do have a heat pump, you will have to get a thermostat that is compatable with heat pumps. Hope this helps
Jul 12, 2009 | Honeywell Heat/Cool Thermostat
Replacing old thermostat with new digital
Wire nut or tape the black off. The red is normally 24volt supply power to the t-stat. Blue may or may not be the common. Have a voltmeter?
Jun 24, 2009 | Goodman CKL30AR30 Air Conditioner
Stuck in defrost mode after changing timer and thermostat
Amana adaptive defrost:
Press refrigerator light switch five times in six seconds to initiate defrost cycle. Pressing five more times within six seconds will cancel defrost and go straight into the run mode. Similar operation on both bottom mount and SxS refrigerators. After the defrost terminator/thermostat opens, six minutes of dwell time occurs before the compressor and condenser fan motor will operate. After defrost terminator/thermostat open, 10 minutes of dwell time occurs before the evaporator fan motor will operate.
May 05, 2009 | Amana 25.8 cu. ft. Side-by-Side...
Control board reset?
Amana version of adaptive defrost : Press refrigerator light switch five times in six seconds to initiate defrost cycle. Pressing five more times within six seconds will cancel defrost and go straight into the run mode. Similar operation on both bottom mount and SxS refrigerators. After the defrost terminator/thermostat opens, six minutes of dwell time occurs before the compressor and condenser fan motor will operate. After defrost terminator/thermostat open, 10 minutes of dwell time occurs before the evaporator fan motor will operate.
May 04, 2009 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Wiring from thermostat to furnace
Typically you normally will have five wires controlling your furnace and airconditioning. R Y W G C. If you get some thermostat wire. Connect them like this---- red wire will go to R(this is your 24V to thermostat)----yellow wire will go Y(Y is your cooling)----white wire will go W(W is for heating)---green wire to G(green is your fan)---black can go to C(this is your common to supply 24Vto thermostat)
Jan 18, 2009 | Coleman Propane Forced Air Heater...
LEC Fridge Freezer
clean up your condenser it's gotta be dirty and check your thermostat put it on the coldest setting and check your freezer fan.
if t ain't running check to see if wired with defrost thermostat if it is suspect it defective.
Dec 17, 2007 | Freezers
Heating & Cooling Logo
161 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
