I can't make the safari program in i pod touch 2 gen work. No connection can be found. What can I do?
    Scholar:
  • 94 Answers
Well, there are many factors that may cause this problem.
First, check if you have your own home wireless network. If you don't then that might mean there are no wireless networks for your iTouch to connect to.
Then, check to make sure your wireless LAN is enabled on your Ipod's settings.
Hope this helps! ^_^
Posted on Jun 22, 2009
I forgot my i pod touch lock code
Try connecting your iPod with the first computer you used it with and open iTunes. If that doesn't work you will have to restore your iPod
Oct 01, 2011 | Apple iPod touch Second Gen (8 GB,...
Tip
How to JAILBREAK all iDevices (iPhone 4, 3GS, 3G, iPod touch, iPad, and the...
This will guide you in jailbreaking the following iDevices with iOS 4.0.1 or 4.0:
iPhone 4, 3GS, 3G
iPod touch 3rd gen and 2nd gen
iPad
Click here for instructions on how to jailbreak the iPhone 3G and iPod touch 2nd gen with iOS 4.0.2
What you'll need:
  1. your device (e.g. iPhone 4) running on the latest iOS version 4.0.1
  2. a stable WiFi connection
NO NEED FOR A COMPUTER! Everything will be done directly from the device.
As mentioned, your device must be running on iOS 4.0.1 or 4.0. If you don't have it yet, no chance.
Here are the steps on JAILBREAKING:
Make sure you are connected to the WiFi signal then follow this:
1. Open Safari (from your iDevice)
2. Go to: JAILBREAKME.COM
3. Slide to jailbreak, wait and sit tight.
4. Tap OK and that's it! It's that simple!
Congratulations! Have fun with your jailbroken iDevice!
If you need to UNLOCK your iPhone, CLICK HERE.
on Aug 03, 2010 | Apple iPhone Smartphone
I pod touch 4th gen. wont work with numark librarian on idj 2
will iPod touch 4th generation work for idj2? Can you mix and scratch with it?
Mar 30, 2011 | Numark iDJ2 - DJ iPOD Mixer Docking...
Connection to I Pod touch from PC desktop computer Unable to connect
1.- You must verify that the desktop computer works without problem in wireless way with the D-Link device.-
2.- The I Pod touch device is an external unit to the desktop computer, so you have be shure of the first condition.-
3.- If the destop computer don`t work in wireless conditions, the fail is in the configuration of the LanWireless, you must check both, D-Link device and computer configurations.-
4.- If the computer works ok, the problem is only in the I Pod touch only.- You muts to check fisical connections and I Pod hardware.-
Sep 02, 2010 | D-Link DI 514 Wireless Router (DI-514)
How do I delete pictures from my Ipod Touch
steps on how to delete pictures from your i-pod touch are stated below. This will work with any iPod touch whether it be a 8gb or 16gb or 32gb. This will also work for both 1st gen and 2nd gen.
This is the first step and will definantly be the easiest. Take your link cable, and plug it into the notch into the computer. Take the end of your cable and plug it up into the I-pod. The side that has the gray circle on the cable will be plugged up face up.
This is the second step. Go into either internet explorer or safari and then go into your files. Go into the file that your store all of your pictures in on your iPod. Then delete the pictures you don't want on your iPod. Or move the pictures to a different folder.
This is the final step. Go into I-tunes and sync your folder with all of your pictures. It will remove the photos you deleted from your iPod.
Good luck.
Apr 20, 2010 | Apple iPod touch Second Gen (8 GB,...
Need help hooking up my ipod touch to the network, will work every where but here at the house. wrt54g2 my wife has the same ipod touch as i do, 16gb, 2nd gen;her's works on the net, mine keeps saying can...
This is going to be one of those frustating things that is hard to solve - or it will just solve itself!
I was out doing a service call with a client with the same router. Accidentally the router had been reset and the SSID had returned to netgear and the security had been turned off.
Resetting the SSID and wireless security is straightforward and at the end I could connect easily with my iPod Touch (1st gen) - however, the client's eMac couldn't connect - he constantly got "It was not possible to connect" messages. Noting that there were about a dozen other transmitters of varying strengths being picked up I decided to change the channel that the netgear was using. This worked - he could now connect but the emac kept saying that the password he was sending was incorrect. (I'm still connected). After some umming and arring we decided to switch the password back to one that had been using when the system was first installed. Now he can connect but my pod says "It was not possible to connect" - it didn't even ask for the password - it just rejected out of hand - all the other transmitters asked for the password. Even rebooting the pod had no effect.
Anyway - the job was done as it was getting him reconnected that was the issue.
Feb 06, 2010 | NetGear DG834G Router
My first gen i pod touch i disabled HELP!
connect it to itunes and restore.
if you cannot connect it to itunes try holding the power and home button until you see a disk and plug pop up the can take up to 2 mins so expect to hold them a long time. you have to keep holding the buttons the ipod will restart then again do not let go then you should be able to connect to itunes to restore
Feb 01, 2010 | Apple Audio Players & Recorders
First gen i pod touch, white blank screen
  1. Back up your iPod Touch's data to your computer before the restore to prevent losing data. You'll need to reinstall it after the restore process.
  2. Connect to the internet and install the latest version of iTunes from the Apple website.
  3. Make sure your iPod Touch is connected to your computer.
  4. Pick "iPod Touch" in the Source pane of the iTunes program.
  5. Click on the Summary tab.
  6. Choose "Check for Update."
  7. Select "Restore" and follow the instructions to finish restoring your iPod Touch.
  8. Complete an Advanced Restore
  9. If following the steps in the previous section did not work, follow these steps to perform an advanced restore. Turn off the power on the iPod Touch.
  10. Plug the iPod Touch into your computer.
  11. Power on the iPod Touch.
  12. Press the "Home" and "Sleep/Wake" buttons together for 5 seconds until the Apple logo appears.
  13. Release the "Sleep/Wake" button but continue holding down the "Home" button. The iPod Touch should reboot, and iTunes will notice the iPod Touch in recovery mode.
  14. Return to the above section and follow those steps to restore your iPod Touch.
Sep 25, 2009 | Apple iPod touch
I plugged my pod touch into usb port on a computer that doesn't have itunes on it and it now shoe a cable and disk with itunes on it. I can;t get it to do anything.
The problem is that in order to use the iPod Touch you need to connect it to a Computer with iTunes so it can install the software needed to work.
Try looking for a computer with Itunes and it should start working.
Jul 25, 2009 | Apple iPod touch Second Gen (8 GB,...
Itouch says safari has stopped because the server has stopped responding problem
So you have connection issue from your iPod Touch?
Try this:
1. Turn off your wifi connection from the iPod touch.
2. Try to reconnect to the Access Point (AP) again.
3. If this not solve your problem, make sure that you have internet connection.
May this help! PM me if there's another questions.
Jul 07, 2009 | Apple iPod touch Second Gen (8 GB,...
52 people viewed this question
 Grubhead
Grubhead
