Question about Whirlpool ET1MHKXM Top Freezer Refrigerator
Whirlpool ET1MHKXMB Refrigerator, freezer thawed yesterday
We thought that it was just the freezer that had gone out yesterday but today the refrigerator has reached almost room temperature. The fan is running, the coils are clean and the compressor is cool to the touch.
  • 400 Answers
SOURCE: Whirlpool Top-Mount Refrigerator Freezer warm, cracking noise
8yr old? Buy a new one. The cracking sound is from expansion and contraction of the cabinet and ice cooling or defrosting. It can be as simple as a bit of a top up of refrigerant, but can also be that your compressor has worn down the valve plates and therefore is not producing sufficient pressure throught the system.
Posted on Mar 06, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: The fan is running, but the refrigerator and freezer are not cooling. We cleaned the coils... any other suggestions?
Check the compressor and the relay. Make sure they are working when you turn on freezer and fridge to the max. If the compressor does not start then you need a new relay. If the compressor starts then it is your thermostat that has gone bad and must be replaced. you can find the parts on repairclinic.com and order them with instructions on how to remove the bad part and install the new part
Posted on May 20, 2009
  • 18 Answers
SOURCE: Refrigerator NOISE
Replace the evaporator fan motor.
Posted on May 29, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Compressor too hot to touch
Just make sure that all fans are running when the compressor is working. The compressor is a real fine built model to be 35 years old. The problem with machines and people, they just tend to wear out. If that refrigerator is something you want to keep and the compressor is worn out I would consider replacing the compressor. But the cost may not be something you would want to pay. I do this a lot and usual charge for parts, labor and warranty is $300.00
Hope you well on that Whirlpool!
Thanks, Sea Breeze
projdoc
  • 2237 Answers
SOURCE: it looks like whirlpool refrigerator compressor's
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Posted on Aug 28, 2009
Kitchen aid superba architrend series s/s refrigerator purchased in 2001 when house built. Everything in freezer thawed today, pulled, took cardboard off back and cleaned with sweeper then replugged and...
Call someone to look at it. There is a fuse that can be replaced but I have no idea what was damaged. $200 repair if possible $85 tech visit if no repair possible
Jan 27, 2011 | KitchenAid Superba Architect KSCS25INSS...
I have a Kitchen-Aid refrigerator in my garage that is about 15 years old. Food in the top has been thawing some and the bottom stays frozen. I put a thermostat in the freezer and it seems to vary from...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 23, 2011 | KitchenAid Refrigerators
Fridge threw breaker yesterday. Breaker reset and refrigerator appeared to be operating normally but today freezer food and ice thawed and refrigerator at 44 instead of 37. Reset with digital control but...
throw it away ,sounds like the motor is shorting out inside ,check the wires first in case a mouse had breakfast but i would say the motor is packing up
Dec 31, 2010 | Refrigerators
Side by side Amana freezer/refrigerator thawing.
The doors not being shut can make it freeze up,Just thaw again and make sure the doors get shut each time and see what happens,just post back details if it doesn't work after thawing
Aug 05, 2009 | Amana ASD2625KE Side by Side Refrigerator
My whrilpool freezer and refrigerator stop working after defrosting
1Plugged coils (lint and dirt) cutting off air flow will cause the problem you describe; Also
2 Fan that will not run underneath the box
3 Defective compressor
4 Compressor starting components, are the 1st items that come to mind with a description like yours.
But first check your controls inside and make sure they are set to mid range.
2 types of controls in refrigerators 1 for on off and 1 for air flow. If this control you mentioned has "off" on it this is the thermostat. Look for the other one and set it to mid range
If this has helped you please rate me as high as you can and thank you for using fixya..
Sep 03, 2008 | Whirlpool ED0GTQXMQ Side by Side...
Whirlpool ET1MHKXM Top Freezer Refrigerator Logo
88 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
