Question about Weather King 10AJA6001AH Air Conditioner
A/c pipe froze up and a/c blows warm air
    Sergeant:
  • 340 Answers
Turn off defrost unit likely dirty clean evaporator and condenser normal operation pipe that is froze should be cold and sweating. little pipe should be warm good luck. Tom
Posted on Jun 22, 2009
Get the heater to blow hot air into my x trail the matrix gets hot and vent flaps are ok but it only blows warm
If the blend door is properly working then you may have thermostat that is stuck open
Jan 19, 2015 | 2006 Nissan X-Trail 2.2
My air conditioner isnt blowing cold air
is the ac a manual one or automatic? if it's manual then it froze and will no longer work. it froze and is all done working. time for a new one. I bought one 12 years ago and apparently I was suppose to turn on and off. The ac couldn't do that. IF it works on it's own maybe the circuit isn't the higher amp for 220 ac units.
Sep 07, 2012 | tranexp.com Computers & Internet
Ac unit isn't blowing
It sounds like your freezing up at the coil, which in turn, blocks airflow across coil and only a small amount of air comes out of the vents. This also explains the cold air coming from fan on the outside unit, since the system cannot absorb the heat from the inside of the house through the coil. Your air outside is usually blowing out warm to hot air because thats the heat it rejects out of your system. I would turn the thermostat to "OFF" and turn just the fan setting to "ON" instead of Auto, this thaws the system out faster. Give it time to fully thaw, make sure filters are clean, and check airflow. If airflow is back to normal, your problem is more than likely the charge of refrigerant. If you have to call a technician out, make sure the unit is not frozen at all before they get there, they would not be able to do anything with the system froze. Hope this helps and good luck!
Jun 18, 2012 | Heating & Cooling
Heater does not get warm air
Check your anti-freeze level. 9 out of 10 times, it's just low on antifreeze. Your heater takes the heat from the warmed antifreeze,once the engine is warm, and blows the heat off and into the car. If the anti-freeze is low or the motor is cold you wont have heat.
Nov 20, 2009 | 2000 Ford Focus
No heat air is blowing cold
First you have to identify what causes the problem.
To do this you have to:
1) When engine is cold check the level of coolant. If it is low fill it up.
2) Start engine and check if engine reaches regular temperature. If your engine is not heated enough it means your thermostat does not work properly and should be replaced.
3) If engine temperature is normal, then check the temperature of pipes that go to/from heater core. These pipes are located up the fire wall (easier access is from the passenger side). If pipe/pipes are cold (even engine is worm) it means you heater core is plugged and should be flushed. Keep in mind, flushing the whole cooling system is different from flushing heater core.
4) If pipe/pipes are hot/warm, turn off the fan, switch controller to the hot position, wait for 3-4 minutes and turn on the fan. Note if the cold air blows first or warm air blows first but it cools down in 5-10 seconds. If the air blows cold than it is most probably the problem with blend door or blend door actuator.
5) If air blows warm first and then cools down, then while running engine and remaining the transmission in PARKING position, press on the gas pedal until your engine reaches 3,000 RPM. Check if your heater blows warm/hot air. If it does, then your water pump does not work properly and should be replaced. If the air still cold, I would suggest to flush the heater core.
Oct 22, 2009 | 1998 Ford Taurus
MY 1998 FOR TARUS HEATER WILL NOT WORK.WAS DRIVING
It is most probably the problem with blend door or blend door actuator. But just in case I would suggest to follow the entire procedure:
3) If engine temperature is normal, then check the temperature of pipes that go to/from heater core. These pipes are located up the fire wall (easier access is from the passenger side). If pipe/pipes are cold (even engine is warm) it means you heater core is plugged and should be flushed. Keep in mind, flushing the whole cooling system is different from flushing heater core.
5) If air blows warm first and then cools down, then while running engine and remaining the transmission in PARKING position, press on the gas pedal until your engine reaches 3,000 RPM. Check if your heater blows warm/hot air. If it does, then your water pump does not work properly and should be replaced. If the air still cold, I would suggest flushing the heater core.
Oct 17, 2009 | 1998 Ford Taurus
Heater not working
No heat on passenger side and warm air on drivers side
heater radiator blocked or partially blocked,drain antifreeze and save ,remove the inlet and outlet pipes for teh heater and flush in both directions repeatedly .brown rust should come out,if not a lot comes out then fit two pieces of pipe about a foot long to heater unit pipes and mix some caustic soda and pour in one pipe with a funnel till it comes up in other pipe leave for a while then flush again and you might need to repeat this two or three times
Dec 16, 2008 | 1998 Cadillac DeVille
Weather King 10AJA6001AH Air Conditioner Logo
Top Weather King Heating & Cooling Experts
John Tripp
John Tripp
acrman404a
Level 1 Expert
Bill Long
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
