Question about Panasonic Microwave Ovens
I Need a replacement glass for a panasonic Inverter the Genius sensor model no#5A68160017 can anyone help as to where you buy this from
  • Panasonic Master
  • 9,098 Answers
That's not the model number of the oven.
Check the tag around the control panel frame. It will be something like NNS-542BAW, etc.
You can order parts from Encompass here or you can call them toll-free at 866-779-5835.
Posted on Jun 24, 2009
I need user manual for Panasonic Genius Prestige microwave oven with inverter technology and sensor cook
You will need to list the model number, not the series name. They dont list the manuals by those numbers. Sorry!! How old is the unit?? If it is a problem with the inverter it can often be a problem with the mag and inverter. If you are having a problem with the machine, probably better to replace. You are only asking for a manual not giving any problems with the unit So do not know what kind of help to offer. Sorry.
Oct 03, 2017 | Panasonic Microwave Ovens
Manual for Panasonic sensor 1250w
Do you mean a Panasonic 1250W microwave with 'Genius Sensor' technology? If so, you should check the model number on your microwave to find the correct manual.
Panasonic has several models with sensor modes. The manual will usually be on the product page. Search for the model from http://shop.panasonic.com and scroll down to the manuals section. Alternately, go to http://shop.panasonic.com/support , then do the model search. This will automatically go the the Owner's Manual section on the product page.
A manual for the NN-SN933 (and several other models) is here: ftp://ftp.panasonic.com/microwaveoven/om/nn-sn943_nn-sn933_nn-sn743_nn-sn733_en_om.pdf . This is a 2.2 cu. ft. model that was advertised on target.com as a Genius Sensor microwave.
I hope this helps. Please add a comment with the model number of your microwave if you need a different manual.
Aug 23, 2017 | Panasonic Microwave Ovens
Panasonic genius inverter 1250w door stuck
Sounds like a spring let go, or the plastic piece that the spring hooks onto broke. Either way, the top cover will have to come off. Could be an easy fix unless something broke.
Jan 25, 2014 | Microwave Ovens
1200 watt panasonic genius shuts down
If it stops after 7 seconds, it has a problem with the inverter.
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter, controller, magnetron, or a bad connection from one or the other.
Display codes H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
That may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
May 26, 2010 | Panasonic Microwave Ovens
My Panasonic Inverter Genius Sensor 1250W Lights
microwave is in lock mode. How do you unlock to use?
Feb 17, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Panasonic inverter genius sensor 1250w, turns on for about 3 sec. then goes off, no codes.
try locating the primary door sensor. this is probably burned. replace the door sensor with appropriate amp rating - usually 16A (or higher) 123vac
Feb 09, 2010 | Panasonic Microwave Ovens
Need to replace Panasonic NE8070 model, 15in dia,microwave plate
hi my name is mark, i found panasonics part website follow link http://www.pstc.panasonic.com/Epartr/PartsListChoice.asp?validate=1 if this helps please rate how i did. thanks for you question.
Mar 18, 2009 | Microwave Ovens
Scrape or fix? Panasonic inverter genius sensor 1250 watt
In most cases, this is a problem with the inverter but it may be a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 06, 2007 | Microwave Ovens
Microwave Ovens Logo
76 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
