Question about Goldstar Heating & Cooling
Motor broke where can I get one, how much it cost
  • nafkman Jun 22, 2009
    Thanks, but it is a split unit Model LS - D2420CL
  • Goldstar Master
  • 4,654 Answers
If a window unit it would better to replace the complete air conditioner than to replace the compressor. Compressors new cost a good bit and you need to pay labor too. You need to consider that the old compressor may have been a burnout contaminating the complete sealed system with an acid and carbon. Sea Breeze
Posted on Jun 22, 2009
  • John Tripp
    John Tripp Jun 22, 2009
    Where is your location. In the South East USA I use C.C. Dickson Co. All they need is the numbers on top of the compressor to get you a replacement. I did not know a split unit was involved. Hope this information helps. Baker Brothers is another large co.
    http://www.ccdickson.com/ccdlocations.as...
How much does it cost to replace a broken timing belt on a 2005 kia sorento
Not much but what happened to the engine when it broke is a lot. Doesn't always destroy a motor but often bends and warps thing. The cost of the new timing belt should be the least of your worries.
Sep 06, 2010 | 2005 Kia Sorento
There is a plastic bushing with plastic pins 4. It is between gearbox and eletric motor. It is broke but is still working. Can get another assemble th replace it.
that is called your motor coupling,can get 1 from your nearest appliance shop or order from REPAIRCLINIC.com , cost about 14.00
Feb 13, 2010 | Washing Machines
Timing belt Broke are valves worped?
Hello momma_green: My name is Roger and I will help you. The 2005 Chevy Aveo 1.6 engine is a interference motor. That means if the timing belt breaks.The valves will be bent. I have one in my shop now that the belt broke on it. Bent all 16 valves and damaged all 4 pistons. This is not a forgiving motor. I wish I could tell you good news but I cant. Should you need further help please just ask. Please rate the answer you received. Thank You for using Fix Ya. Roger
Oct 30, 2009 | 2005 Chevrolet Aveo
How much will it cost to fix my drivers window? i recently bought a 200 pontiac grand am gt but the window on drivers side doesnt work - there is something in side of it holding it in place. do you know...
remove door panel inside car and check motor with test light.
check window regulator/track window rides on, for proper operation, check cable is not broke.
replace motor if bad buy a new one, replace regulator from junk yard, new is pricey. 250.00 dealer cost.
350-400 for the whole job :(
Oct 10, 2009 | 2000 Pontiac Grand Am GT
Washing machine will not spin, when re-trying it filled up with water but will not agitate
Can you here the motor running? If not check the lid safety switch,and power. If so then the motor/gear box coupling may be broke...did it get overloaded recently? If the coupling is broke it will only cost you minimal $ if you fix it yourself, google your model no. Let me know if this helps
Sep 04, 2009 | Maytag Washing Machines
Timing Belt Broke. 2002 Volkswagen Passat . Time for a new car?
i would go with the mechanics advice and allow them to fix it. 1200 to 1500 beats spending 4000 on another motor if that one can be saved
Jan 26, 2009 | 2002 Volkswagen Passat
ENGINE (MONTERO 1995)
probably about 700 for a used motor at salvage a new one would cost about 1500
Jan 08, 2009 | 1995 Mitsubishi Montero
Ticking sound
Hi,yes your engine does have a timing belt inside,shoul cost from $150,00 to$ 250,00 to replace ,be sure you take it to a recogniced shop, to get it check ,and to have the work done,.may be something else making that .(.noise.) good luck......
Jul 08, 2008 | 2004 Chevrolet Cavalier
Heating & Cooling Logo
Top Goldstar Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Dan Webster
Dan Webster
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
